    TreeSketch 2 for iPad [Free]
    31 Posts 10 Posters 3.5k Views 10 Watching
    • HieruH
      Hieru
      Here's a test render that should give some indication of the tree quality:
      The trunk and branches could possibly do with being higher poly, but it's not too shabby with some smoothing applied.
      www.davidhier.co.uk
      • soloS
        That's actually amazing!
        Too bad about the iPad workflow, I do not have one, or any plans to get one unless they drop under $200.
        • fuzzionF
          fuzzion
          [attachment=0:2vm95tfl]<!-- ia0 -->TreeTest2.jpg<!-- ia0 -->[/attachment:2vm95tfl]
          πŸ’­ Post them on warehouse. Tittle them high poly trees. SO that those without the program can get even more free high quality trees. Mind you,
          Its 2011 and im still waiting for the Vray HDRI visualiser and SU tree maker plugin πŸ˜‰
          "Only the dead have seen the end of war" - Plato
          • HieruH
            Hieru
            I think that the winning quality is the flow of the branch growth - plus the human touch added via the gesture based UI.
            I'll have to check to see what the policy is regarding sharing tree models, but presuming that this isn't an issue, I'll probably upload some of my creations via the Thea forum and 3D warehouse. The only thing I'm short on is free leaf and bark textures that I can distribute with the trees.
            www.davidhier.co.uk
            • soloS
              Leaves, freeee: http://www.cgtextures.com/textures.php?t=browse&q=1763
                David can you share your technique after export?
                • HieruH
                  Hieru
                  I converted the FBX to .obj and using File>Merge I imported the tree into Thea. I then applied a stock bark material to the trunk and branches and for the leaves I added a leaf texture to the Diffuse & Translucent material slots (plus a clipping mask) - I didn't change anything else.
                  I've just tried importing into Sketchup and both .obj and .dxf result in bug splats. DAE works just fine, but the tree used in my render is 75MB, so it looks like I won't be able to upload anything to the 3D Warehouse. On top of that I don't much fancy texturing each individual leaf πŸ˜†
                  www.davidhier.co.uk
                  • soloS
                    Does Thea not import FBX?
                    • HieruH
                      Hieru
                      Doesn't look like it - unless you know something I don't πŸ˜‰
                      www.davidhier.co.uk
                        Well, if Ioannis can add .fbx import then there'll be a forest on the forums in no time
                        • soloS
                          I have never tried, I'll mention it on beta forum, hopefully we can get something organised.
                          • HieruH
                            Hieru
                            For a second there I thought that you were talking from experience and that FBX import was a new feature of the next Thea build.
                            www.davidhier.co.uk
                              SimLab have an FBX importer for Sketchup - but at $99... http://www.simlab-soft.com/3d-plugins/FBX_Importer_For_Sketchup-main.aspx
                              OR you could download one of AutoDesk's free FBX converters [various versions and OS's]
                              http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=10775920
                              http://images.autodesk.com/adsk/files/fbx_converter_2012.pdf
                              to convert it into a format that you can use... 3ds, dxf, obj, dae...
                              • N
                                notareal
                                FBX importer is a planned feature, not yet available.
                                  Oh, good news.
                                  • HieruH
                                    Hieru
                                    That'll definitely make life easier πŸ‘
                                    www.davidhier.co.uk
                                    • Bob JamesB
                                      Bob James
                                      I've been playing with TreeSketch 2.0 and it's really amazing. Too bad the output is in .fbx and, apparently, the leaves do not have any geometry.
                                      Still: Great fun!
                                      • HieruH
                                        Hieru
                                        Have you tried using the Autodesk FBX converter TIG suggested?
                                        www.davidhier.co.uk
                                        • 2 / 2
