    TreeSketch 2 for iPad [Free]
    31 Posts 10 Posters 3.5k Views 10 Watching
    • HieruH
      Hieru
      I think that the winning quality is the flow of the branch growth - plus the human touch added via the gesture based UI.
      I'll have to check to see what the policy is regarding sharing tree models, but presuming that this isn't an issue, I'll probably upload some of my creations via the Thea forum and 3D warehouse. The only thing I'm short on is free leaf and bark textures that I can distribute with the trees.
      www.davidhier.co.uk
      • soloS
        Leaves, freeee: http://www.cgtextures.com/textures.php?t=browse&q=1763
          David can you share your technique after export?
          • HieruH
            Hieru
            I converted the FBX to .obj and using File>Merge I imported the tree into Thea. I then applied a stock bark material to the trunk and branches and for the leaves I added a leaf texture to the Diffuse & Translucent material slots (plus a clipping mask) - I didn't change anything else.
            I've just tried importing into Sketchup and both .obj and .dxf result in bug splats. DAE works just fine, but the tree used in my render is 75MB, so it looks like I won't be able to upload anything to the 3D Warehouse. On top of that I don't much fancy texturing each individual leaf πŸ˜†
            www.davidhier.co.uk
            • soloS
              Does Thea not import FBX?
              • HieruH
                Hieru
                Doesn't look like it - unless you know something I don't πŸ˜‰
                www.davidhier.co.uk
                  Well, if Ioannis can add .fbx import then there'll be a forest on the forums in no time
                  • soloS
                    I have never tried, I'll mention it on beta forum, hopefully we can get something organised.
                    • HieruH
                      Hieru
                      For a second there I thought that you were talking from experience and that FBX import was a new feature of the next Thea build.
                      www.davidhier.co.uk
                        SimLab have an FBX importer for Sketchup - but at $99... http://www.simlab-soft.com/3d-plugins/FBX_Importer_For_Sketchup-main.aspx
                        OR you could download one of AutoDesk's free FBX converters [various versions and OS's]
                        http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=10775920
                        http://images.autodesk.com/adsk/files/fbx_converter_2012.pdf
                        to convert it into a format that you can use... 3ds, dxf, obj, dae...
                        • N
                          notareal
                          FBX importer is a planned feature, not yet available.
                            Oh, good news.
                            • HieruH
                              Hieru
                              That'll definitely make life easier πŸ‘
                              www.davidhier.co.uk
                              • Bob JamesB
                                Bob James
                                I've been playing with TreeSketch 2.0 and it's really amazing. Too bad the output is in .fbx and, apparently, the leaves do not have any geometry.
                                Still: Great fun!
                                • HieruH
                                  Hieru
                                  Have you tried using the Autodesk FBX converter TIG suggested?
                                  www.davidhier.co.uk
                                  • 2 / 2
