    TreeSketch 2 for iPad [Free]
    31 Posts 10 Posters 3.5k Views 10 Watching
    • soloS
      looks interesting, but begs the question....why?
      What is the point to this app? so you create a tree, then what? Is it just a doodling app?
      My point is if this is a tree creator then what are you supposed to do with the trees?
      I'd understand it if it was a PC/MAC app that then exported the tree for use in modeling/animation programs, the tree will then have a clear use.
      I also do not want to have to jailbreak my ipad in order to use the trees.
        Did you even watch the videos?
        It exports to .fbx so you can drag from iTunes to your Desktop.
        • soloS
          I watched the one you posted above.
          iTunes, oh! πŸ˜• I'll skip that one, and wait for something similar to come to a PC near me.
          • mogrenM
            mogren
            Have you tried Autodesk's FBX Converter...
            http://usa.autodesk.com/adsk/servlet/pc/item?id=10775855&siteID=123112
            ...scroll past the 3DS Max plugins to see the standalone converter for both Mac and PC.
            Thank you I'll try soon
            • HieruH
              Hieru
              Here's a test render that should give some indication of the tree quality:
              The trunk and branches could possibly do with being higher poly, but it's not too shabby with some smoothing applied.
              www.davidhier.co.uk
              • soloS
                That's actually amazing!
                Too bad about the iPad workflow, I do not have one, or any plans to get one unless they drop under $200.
                • fuzzionF
                  fuzzion
                  [attachment=0:2vm95tfl]<!-- ia0 -->TreeTest2.jpg<!-- ia0 -->[/attachment:2vm95tfl]
                  πŸ’­ Post them on warehouse. Tittle them high poly trees. SO that those without the program can get even more free high quality trees. Mind you,
                  Its 2011 and im still waiting for the Vray HDRI visualiser and SU tree maker plugin πŸ˜‰
                  "Only the dead have seen the end of war" - Plato
                  • HieruH
                    Hieru
                    I think that the winning quality is the flow of the branch growth - plus the human touch added via the gesture based UI.
                    I'll have to check to see what the policy is regarding sharing tree models, but presuming that this isn't an issue, I'll probably upload some of my creations via the Thea forum and 3D warehouse. The only thing I'm short on is free leaf and bark textures that I can distribute with the trees.
                    www.davidhier.co.uk
                    • soloS
                      Leaves, freeee: http://www.cgtextures.com/textures.php?t=browse&q=1763
                        David can you share your technique after export?
                        • HieruH
                          Hieru
                          I converted the FBX to .obj and using File>Merge I imported the tree into Thea. I then applied a stock bark material to the trunk and branches and for the leaves I added a leaf texture to the Diffuse & Translucent material slots (plus a clipping mask) - I didn't change anything else.
                          I've just tried importing into Sketchup and both .obj and .dxf result in bug splats. DAE works just fine, but the tree used in my render is 75MB, so it looks like I won't be able to upload anything to the 3D Warehouse. On top of that I don't much fancy texturing each individual leaf πŸ˜†
                          www.davidhier.co.uk
                          • soloS
                            Does Thea not import FBX?
                            • HieruH
                              Hieru
                              Doesn't look like it - unless you know something I don't πŸ˜‰
                              www.davidhier.co.uk
                                Well, if Ioannis can add .fbx import then there'll be a forest on the forums in no time
                                • soloS
                                  I have never tried, I'll mention it on beta forum, hopefully we can get something organised.
                                  • HieruH
                                    Hieru
                                    For a second there I thought that you were talking from experience and that FBX import was a new feature of the next Thea build.
                                    www.davidhier.co.uk
                                      SimLab have an FBX importer for Sketchup - but at $99... http://www.simlab-soft.com/3d-plugins/FBX_Importer_For_Sketchup-main.aspx
                                      OR you could download one of AutoDesk's free FBX converters [various versions and OS's]
                                      http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=10775920
                                      http://images.autodesk.com/adsk/files/fbx_converter_2012.pdf
                                      to convert it into a format that you can use... 3ds, dxf, obj, dae...
                                      • N
                                        notareal
                                        FBX importer is a planned feature, not yet available.
                                          Oh, good news.
                                          • HieruH
                                            Hieru
                                            That'll definitely make life easier πŸ‘
                                            www.davidhier.co.uk
