    [Plugin] #SelectionHideShow.rb v1.1
    22 Posts 13 Posters 48.1k Views 13 Watching
      AlexMozg
      @chris fullmer said:
      Alex, I have not run any tests on typename, but I use it regularly. Are you saying that it is much slower than .is_a?
      Easily to check...
      The more elements in the model - the better results script.
      SpeedTest
      is_a? - 0.36c
      kind_of? - 0.39c
      class - 0.422c
      typename - 1.313c
      Model Statistics:
      edges = 48981
      faces = 8009
      groups = 729
      components = 365
      construction_lines = 1
      construction_points = 4
      images = 3
      section_planes = 4
      texts = 4
      others = 2
      Not plugin!
        That's some interesting numbers. I've always used k ind_of? - wasn't aware of the is_a?. then again, I've never tested the speed of methods either.
        Thanks for posting this test.
          Maybe we could add this info to a new stickcy where we collect such useful tips and info?
            Thanks Alex - you've probably noticed I used the .is_a? test everywhere else in the script - however, I didn't realise it was so much slower to use typename=="". 😳
            I've also incorporated my own version of your group_miner speed-up suggestion that now avoids testing groups that area already unique... πŸ€“
            I just need to edit ALL of my other scripts to change e.typename=="" to e.is_a?() !!! 😒
            Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=161963#p161963
              AlexMozg
              @tig said:
              ...I didn't realise it was so much slower to use typename=="". 😳
              For a model ot a few kilobytes to 10 megabyte of substantial difference it is not, but my models ot 40 to 75 megabyte!
              My model statistics:
              Model 68.4 Mb:
              Edges 485016
              Faces 128906
              Component Instances 6055
              Groups 3078
              Section Planes 4
              P.S.
              It was even necessary to write the analogue of SketchUp Text tool, because a standard tool begins to work very long.
              πŸ˜’
              • B
                bianhai
                Very good 😎 !
                  Easily to check...
                  SpeedTest
                  is_a? - 0.36c
                  kind_of? - 0.39c
                  class - 0.422c
                  typename - 1.313c
                  Model Statistics:
                  edges = 48981
                  faces = 8009
                  groups = 729
                  components = 365
                  images = 3
                  section_planes = 4
                  texts = 4
                  others = 2
                  Hmm... .kind_of? is an alias for .is_a? - Is that fraction of a differences just some other random outside co-incidence?
                  http://www.ruby-doc.org/core/classes/Object.html#M000370
                    I did a somewhat larger test. By the looks of it .is_a?, .kind_of? and .class are pretty much the same. I take the differences due to other system factors at the time of execution.
                    AT - SpeedTest:
                    is_a? - 0.89c
                    kind_of? - 0.782c
                    class - 0.875c
                    typename - 2.297c
                    Model Statistics:
                    edges = 159630
                    faces = 61300
                    groups = 0
                    components = 1000
                    construction_lines = 0
                    construction_points = 0
                    images = 0
                    section_planes = 0
                    texts = 0
                    others = 0
                      Much larger test. (did have a few programs open while I did the tests.)
                      AT - SpeedTest:
                      is_a? - 16.297c
                      kind_of? - 16.141c
                      class - 18.703c
                      typename - 88.703c
                      Model Statistics:
                      edges = 8396595
                      faces = 1026520
                      groups = 52643
                      components = 526428
                      construction_lines = 2
                      images = 0
                      section_planes = 0
                      texts = 0
                      others = 0
                        3dsmax9
                        a tool bar will be very great with this script
                        • irwanwrI
                          irwanwr
                          i think i need this plugin
                          thank you in advance, sir.
                          • I
                            Ivancho
                            [highlight=#ffff40:2a81c421]NICE[/highlight:2a81c421]!! 😍
                            • H
                              hygicell
                              I have lost a component somewhere in my drawing
                              to find it, I pasted a second one in a visible place
                              when I select this, the entity info clearly says Component (2 in model)
                              with the components window context menu, I selected all components
                              I thought then, if I could hide the rest of the model, I would easily spot where the original one is
                              but view/hide rest of model doesn't work unless you are inside the component,
                              which means you can select only one of both, and the other one is deselected
                              please help
                              Frank
                                View > Hidden Geometry ON will show all hidden objects.
                                If it's on a Layer that is OFF you won't see it though...
                                The Outliner will also show all instances that are on ON Layers...
                                You can select them in the Outliner and they select in the model.
