    [Plugin] #SelectionHideShow.rb v1.1
    22 Posts 13 Posters 47.9k Views 13 Watching
      Very practical! 😎
        Mr S
        Great!
        I asked for this a while ago.
        I suggested it was something that should be a standard feature in SketchUp
        Now it is. Thanks for another great contribution.
        Regards
        Mr S
        • boofredlayB Offline
          boofredlay
          Thanks TIG. However I expected to see Reverse Faces in there too.
          • erikBE Offline
            erikB
            Thanks TIG, and I second the request made by Boofredlay.
            erikB
              Reverse and Orient faces is already built-in on the context-menu - near the top [as are some other 'select tools']... adding them would only duplicate stuff...
                AlexMozg
                ❓ Why constantly to use the method of group_miner, when in him practically is not there a necessity?
                ❓ Why to apply properties to entity, when are new properties of entity equal to the applied properties?
                These questions are linked at a speed of implementation of script on the large scenes.
                ❗ Example of considerable increase of speed of implementation of script:
                class Sketchup;;Group
                    def definition
                        self.entities.parent
                def SelectionTool;;group_miner(ents)
                    ents.each do |e|
                        if e.is_a? Sketchup;;Group
                            e.make_unique if e.definition.instances.length > 1
                            SelectionTool;;group_miner(e.entities)
                ❗ At the use of method of typename speed of implementation of script goes down in once or twice!
                It would be desirable to correct these shortages...
                • Chris FullmerC Offline
                  Alex, I have not run any tests on typename, but I use it regularly. Are you saying that it is much slower than .is_a?
                  I'd rather use the faster method too, I just never knew there was a faster one. I'm sure TIG isn't using a slow method on purpose either...
                    AlexMozg
                    Easily to check...
                    The more elements in the model - the better results script.
                    SpeedTest
                    is_a? - 0.36c
                    kind_of? - 0.39c
                    class - 0.422c
                    typename - 1.313c
                    Model Statistics:
                    edges = 48981
                    faces = 8009
                    groups = 729
                    components = 365
                    construction_lines = 1
                    construction_points = 4
                    images = 3
                    section_planes = 4
                    texts = 4
                    others = 2
                    Not plugin!
                      That's some interesting numbers. I've always used k ind_of? - wasn't aware of the is_a?. then again, I've never tested the speed of methods either.
                      Thanks for posting this test.
                        Maybe we could add this info to a new stickcy where we collect such useful tips and info?
                          Thanks Alex - you've probably noticed I used the .is_a? test everywhere else in the script - however, I didn't realise it was so much slower to use typename=="". 😳
                          I've also incorporated my own version of your group_miner speed-up suggestion that now avoids testing groups that area already unique... πŸ€“
                          I just need to edit ALL of my other scripts to change e.typename=="" to e.is_a?() !!! 😒
                          Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=161963#p161963
                            AlexMozg
                            @tig said:
                            ...I didn't realise it was so much slower to use typename=="". 😳
                            For a model ot a few kilobytes to 10 megabyte of substantial difference it is not, but my models ot 40 to 75 megabyte!
                            My model statistics:
                            Model 68.4 Mb:
                            Edges 485016
                            Faces 128906
                            Component Instances 6055
                            Groups 3078
                            Section Planes 4
                            P.S.
                            It was even necessary to write the analogue of SketchUp Text tool, because a standard tool begins to work very long.
                            πŸ˜’
                              bianhai
                              Very good 😎 !
                                Easily to check...
                                SpeedTest
                                is_a? - 0.36c
                                kind_of? - 0.39c
                                class - 0.422c
                                typename - 1.313c
                                Model Statistics:
                                edges = 48981
                                faces = 8009
                                groups = 729
                                components = 365
                                images = 3
                                section_planes = 4
                                texts = 4
                                others = 2
                                Hmm... .kind_of? is an alias for .is_a? - Is that fraction of a differences just some other random outside co-incidence?
                                http://www.ruby-doc.org/core/classes/Object.html#M000370
                                  I did a somewhat larger test. By the looks of it .is_a?, .kind_of? and .class are pretty much the same. I take the differences due to other system factors at the time of execution.
                                  AT - SpeedTest:
                                  is_a? - 0.89c
                                  kind_of? - 0.782c
                                  class - 0.875c
                                  typename - 2.297c
                                  Model Statistics:
                                  edges = 159630
                                  faces = 61300
                                  groups = 0
                                  components = 1000
                                  construction_lines = 0
                                  construction_points = 0
                                  images = 0
                                  section_planes = 0
                                  texts = 0
                                  others = 0
                                    Much larger test. (did have a few programs open while I did the tests.)
                                    AT - SpeedTest:
                                    is_a? - 16.297c
                                    kind_of? - 16.141c
                                    class - 18.703c
                                    typename - 88.703c
                                    Model Statistics:
                                    edges = 8396595
                                    faces = 1026520
                                    groups = 52643
                                    components = 526428
                                    construction_lines = 2
                                    images = 0
                                    section_planes = 0
                                    texts = 0
                                    others = 0
                                    • 3 Offline
                                      3dsmax9
                                      a tool bar will be very great with this script
                                      • irwanwrI Offline
                                        irwanwr
                                        i think i need this plugin
                                        thank you in advance, sir.
                                        • I Offline
                                          Ivancho
                                          [highlight=#ffff40:2a81c421]NICE[/highlight:2a81c421]!! 😍
                                          • H Offline
                                            hygicell
                                            I have lost a component somewhere in my drawing
                                            to find it, I pasted a second one in a visible place
                                            when I select this, the entity info clearly says Component (2 in model)
                                            with the components window context menu, I selected all components
                                            I thought then, if I could hide the rest of the model, I would easily spot where the original one is
                                            but view/hide rest of model doesn't work unless you are inside the component,
                                            which means you can select only one of both, and the other one is deselected
                                            please help
                                            Frank
