    [Plugin] #SelectionHideShow.rb v1.1
    22 Posts 13 Posters 47.9k Views 13 Watching
      AlexMozg
      ❓ Why constantly to use the method of group_miner, when in him practically is not there a necessity?
      ❓ Why to apply properties to entity, when are new properties of entity equal to the applied properties?
      These questions are linked at a speed of implementation of script on the large scenes.
      ❗ Example of considerable increase of speed of implementation of script:
      class Sketchup;;Group
          def definition
              self.entities.parent
      def SelectionTool;;group_miner(ents)
          ents.each do |e|
              if e.is_a? Sketchup;;Group
                  e.make_unique if e.definition.instances.length > 1
                  SelectionTool;;group_miner(e.entities)
      ❗ At the use of method of typename speed of implementation of script goes down in once or twice!
      It would be desirable to correct these shortages...
      • Chris FullmerC Offline
        Alex, I have not run any tests on typename, but I use it regularly. Are you saying that it is much slower than .is_a?
        I'd rather use the faster method too, I just never knew there was a faster one. I'm sure TIG isn't using a slow method on purpose either...
          AlexMozg
          Easily to check...
          The more elements in the model - the better results script.
          SpeedTest
          is_a? - 0.36c
          kind_of? - 0.39c
          class - 0.422c
          typename - 1.313c
          Model Statistics:
          edges = 48981
          faces = 8009
          groups = 729
          components = 365
          construction_lines = 1
          construction_points = 4
          images = 3
          section_planes = 4
          texts = 4
          others = 2
          Not plugin!
            That's some interesting numbers. I've always used k ind_of? - wasn't aware of the is_a?. then again, I've never tested the speed of methods either.
            Thanks for posting this test.
              Maybe we could add this info to a new stickcy where we collect such useful tips and info?
                Thanks Alex - you've probably noticed I used the .is_a? test everywhere else in the script - however, I didn't realise it was so much slower to use typename=="". 😳
                I've also incorporated my own version of your group_miner speed-up suggestion that now avoids testing groups that area already unique... 🤓
                I just need to edit ALL of my other scripts to change e.typename=="" to e.is_a?() !!! 😢
                Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=161963#p161963
                  AlexMozg
                  @tig said:
                  ...I didn't realise it was so much slower to use typename=="". 😳
                  For a model ot a few kilobytes to 10 megabyte of substantial difference it is not, but my models ot 40 to 75 megabyte!
                  My model statistics:
                  Model 68.4 Mb:
                  Edges 485016
                  Faces 128906
                  Component Instances 6055
                  Groups 3078
                  Section Planes 4
                  P.S.
                  It was even necessary to write the analogue of SketchUp Text tool, because a standard tool begins to work very long.
                    bianhai
                    Very good 😎 !
                      Easily to check...
                      SpeedTest
                      is_a? - 0.36c
                      kind_of? - 0.39c
                      class - 0.422c
                      typename - 1.313c
                      Model Statistics:
                      edges = 48981
                      faces = 8009
                      groups = 729
                      components = 365
                      images = 3
                      section_planes = 4
                      texts = 4
                      others = 2
                      Hmm... .kind_of? is an alias for .is_a? - Is that fraction of a differences just some other random outside co-incidence?
                      http://www.ruby-doc.org/core/classes/Object.html#M000370
                        I did a somewhat larger test. By the looks of it .is_a?, .kind_of? and .class are pretty much the same. I take the differences due to other system factors at the time of execution.
                        AT - SpeedTest:
                        is_a? - 0.89c
                        kind_of? - 0.782c
                        class - 0.875c
                        typename - 2.297c
                        Model Statistics:
                        edges = 159630
                        faces = 61300
                        groups = 0
                        components = 1000
                        construction_lines = 0
                        construction_points = 0
                        images = 0
                        section_planes = 0
                        texts = 0
                        others = 0
                          Much larger test. (did have a few programs open while I did the tests.)
                          AT - SpeedTest:
                          is_a? - 16.297c
                          kind_of? - 16.141c
                          class - 18.703c
                          typename - 88.703c
                          Model Statistics:
                          edges = 8396595
                          faces = 1026520
                          groups = 52643
                          components = 526428
                          construction_lines = 2
                          images = 0
                          section_planes = 0
                          texts = 0
                          others = 0
                          • 3 Offline
                            3dsmax9
                            a tool bar will be very great with this script
                            • irwanwrI Offline
                              irwanwr
                              i think i need this plugin
                              thank you in advance, sir.
                              • I Offline
                                Ivancho
                                [highlight=#ffff40:2a81c421]NICE[/highlight:2a81c421]!! 😍
                                • H Offline
                                  hygicell
                                  I have lost a component somewhere in my drawing
                                  to find it, I pasted a second one in a visible place
                                  when I select this, the entity info clearly says Component (2 in model)
                                  with the components window context menu, I selected all components
                                  I thought then, if I could hide the rest of the model, I would easily spot where the original one is
                                  but view/hide rest of model doesn't work unless you are inside the component,
                                  which means you can select only one of both, and the other one is deselected
                                  please help
                                  Frank
                                    View > Hidden Geometry ON will show all hidden objects.
                                    If it's on a Layer that is OFF you won't see it though...
                                    The Outliner will also show all instances that are on ON Layers...
                                    You can select them in the Outliner and they select in the model.
