    [Plugin] #SelectionHideShow.rb v1.1
    22 Posts 13 Posters 47.3k Views 13 Watching
    • Chris FullmerC Offline
      Alex, I have not run any tests on typename, but I use it regularly. Are you saying that it is much slower than .is_a?
      I'd rather use the faster method too, I just never knew there was a faster one. I'm sure TIG isn't using a slow method on purpose either...
        AlexMozg
        Easily to check...
        The more elements in the model - the better results script.
        SpeedTest
        is_a? - 0.36c
        kind_of? - 0.39c
        class - 0.422c
        typename - 1.313c
        Model Statistics:
        edges = 48981
        faces = 8009
        groups = 729
        components = 365
        construction_lines = 1
        construction_points = 4
        images = 3
        section_planes = 4
        texts = 4
        others = 2
        Not plugin!
          That's some interesting numbers. I've always used k ind_of? - wasn't aware of the is_a?. then again, I've never tested the speed of methods either.
          Thanks for posting this test.
            Maybe we could add this info to a new stickcy where we collect such useful tips and info?
              Thanks Alex - you've probably noticed I used the .is_a? test everywhere else in the script - however, I didn't realise it was so much slower to use typename=="". 😳
              I've also incorporated my own version of your group_miner speed-up suggestion that now avoids testing groups that area already unique... πŸ€“
              I just need to edit ALL of my other scripts to change e.typename=="" to e.is_a?() !!! 😒
              Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=161963#p161963
                AlexMozg
                @tig said:
                ...I didn't realise it was so much slower to use typename=="". 😳
                For a model ot a few kilobytes to 10 megabyte of substantial difference it is not, but my models ot 40 to 75 megabyte!
                My model statistics:
                Model 68.4 Mb:
                Edges 485016
                Faces 128906
                Component Instances 6055
                Groups 3078
                Section Planes 4
                P.S.
                It was even necessary to write the analogue of SketchUp Text tool, because a standard tool begins to work very long.
                πŸ˜’
                  bianhai
                  Very good 😎 !
                    Easily to check...
                    SpeedTest
                    is_a? - 0.36c
                    kind_of? - 0.39c
                    class - 0.422c
                    typename - 1.313c
                    Model Statistics:
                    edges = 48981
                    faces = 8009
                    groups = 729
                    components = 365
                    images = 3
                    section_planes = 4
                    texts = 4
                    others = 2
                    Hmm... .kind_of? is an alias for .is_a? - Is that fraction of a differences just some other random outside co-incidence?
                    http://www.ruby-doc.org/core/classes/Object.html#M000370
                      I did a somewhat larger test. By the looks of it .is_a?, .kind_of? and .class are pretty much the same. I take the differences due to other system factors at the time of execution.
                      AT - SpeedTest:
                      is_a? - 0.89c
                      kind_of? - 0.782c
                      class - 0.875c
                      typename - 2.297c
                      Model Statistics:
                      edges = 159630
                      faces = 61300
                      groups = 0
                      components = 1000
                      construction_lines = 0
                      construction_points = 0
                      images = 0
                      section_planes = 0
                      texts = 0
                      others = 0
                        Much larger test. (did have a few programs open while I did the tests.)
                        AT - SpeedTest:
                        is_a? - 16.297c
                        kind_of? - 16.141c
                        class - 18.703c
                        typename - 88.703c
                        Model Statistics:
                        edges = 8396595
                        faces = 1026520
                        groups = 52643
                        components = 526428
                        construction_lines = 2
                        images = 0
                        section_planes = 0
                        texts = 0
                        others = 0
                        • 3 Offline
                          3dsmax9
                          a tool bar will be very great with this script
                          • irwanwrI Offline
                            irwanwr
                            i think i need this plugin
                            thank you in advance, sir.
                            • I Offline
                              Ivancho
                              [highlight=#ffff40:2a81c421]NICE[/highlight:2a81c421]!! 😍
                              • H Offline
                                hygicell
                                I have lost a component somewhere in my drawing
                                to find it, I pasted a second one in a visible place
                                when I select this, the entity info clearly says Component (2 in model)
                                with the components window context menu, I selected all components
                                I thought then, if I could hide the rest of the model, I would easily spot where the original one is
                                but view/hide rest of model doesn't work unless you are inside the component,
                                which means you can select only one of both, and the other one is deselected
                                please help
                                Frank
                                  View > Hidden Geometry ON will show all hidden objects.
                                  If it's on a Layer that is OFF you won't see it though...
                                  The Outliner will also show all instances that are on ON Layers...
                                  You can select them in the Outliner and they select in the model.
