    [Plugin] #SelectionHideShow.rb v1.1
    22 Posts 13 Posters 47.9k Views 13 Watching
      Thanks Alex - you've probably noticed I used the .is_a? test everywhere else in the script - however, I didn't realise it was so much slower to use typename=="". 😳
      I've also incorporated my own version of your group_miner speed-up suggestion that now avoids testing groups that area already unique... πŸ€“
      I just need to edit ALL of my other scripts to change e.typename=="" to e.is_a?() !!! 😒
      Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=161963#p161963
        AlexMozg
        @tig said:
        ...I didn't realise it was so much slower to use typename=="". 😳
        For a model ot a few kilobytes to 10 megabyte of substantial difference it is not, but my models ot 40 to 75 megabyte!
        My model statistics:
        Model 68.4 Mb:
        Edges 485016
        Faces 128906
        Component Instances 6055
        Groups 3078
        Section Planes 4
        P.S.
        It was even necessary to write the analogue of SketchUp Text tool, because a standard tool begins to work very long.
        πŸ˜’
          bianhai
          Very good 😎 !
            @alexmozg said:
            @chris fullmer said:
            Alex, I have not run any tests on typename, but I use it regularly. Are you saying that it is much slower than .is_a?
            Easily to check...
            The more elements in the model - the better results script.
            SpeedTest
            is_a? - 0.36c
            kind_of? - 0.39c
            class - 0.422c
            typename - 1.313c
            Model Statistics:
            edges = 48981
            faces = 8009
            groups = 729
            components = 365
            construction_lines = 1
            construction_points = 4
            images = 3
            section_planes = 4
            texts = 4
            others = 2
            Hmm... .kind_of? is an alias for .is_a? - Is that fraction of a differences just some other random outside co-incidence?
            http://www.ruby-doc.org/core/classes/Object.html#M000370
              I did a somewhat larger test. By the looks of it .is_a?, .kind_of? and .class are pretty much the same. I take the differences due to other system factors at the time of execution.
              AT - SpeedTest:
              is_a? - 0.89c
              kind_of? - 0.782c
              class - 0.875c
              typename - 2.297c
              Model Statistics:
              edges = 159630
              faces = 61300
              groups = 0
              components = 1000
              construction_lines = 0
              construction_points = 0
              images = 0
              section_planes = 0
              texts = 0
              others = 0
                Much larger test. (did have a few programs open while I did the tests.)
                AT - SpeedTest:
                is_a? - 16.297c
                kind_of? - 16.141c
                class - 18.703c
                typename - 88.703c
                Model Statistics:
                edges = 8396595
                faces = 1026520
                groups = 52643
                components = 526428
                construction_lines = 2
                images = 0
                section_planes = 0
                texts = 0
                others = 0
                • 3 Offline
                  3dsmax9
                  a tool bar will be very great with this script
                  • irwanwrI Offline
                    irwanwr
                    i think i need this plugin
                    thank you in advance, sir.
                    • I Offline
                      Ivancho
                      [highlight=#ffff40:2a81c421]NICE[/highlight:2a81c421]!! 😍
                      • H Offline
                        hygicell
                        I have lost a component somewhere in my drawing
                        to find it, I pasted a second one in a visible place
                        when I select this, the entity info clearly says Component (2 in model)
                        with the components window context menu, I selected all components
                        I thought then, if I could hide the rest of the model, I would easily spot where the original one is
                        but view/hide rest of model doesn't work unless you are inside the component,
                        which means you can select only one of both, and the other one is deselected
                        please help
                        Frank
                          View > Hidden Geometry ON will show all hidden objects.
                          If it's on a Layer that is OFF you won't see it though...
                          The Outliner will also show all instances that are on ON Layers...
                          You can select them in the Outliner and they select in the model.
                          • 2 / 2
