    [Plugin] #SelectionHideShow.rb v1.1
    22 Posts 13 Posters 43.5k Views 13 Watching
      AlexMozg
      @tig said:
      ...I didn't realise it was so much slower to use typename=="". 😳
      For a model ot a few kilobytes to 10 megabyte of substantial difference it is not, but my models ot 40 to 75 megabyte!
      My model statistics:
      Model 68.4 Mb:
      Edges 485016
      Faces 128906
      Component Instances 6055
      Groups 3078
      Section Planes 4
      P.S.
      It was even necessary to write the analogue of SketchUp Text tool, because a standard tool begins to work very long.
      πŸ˜’
        bianhai
        Very good 😎 !
          @alexmozg said:
          @chris fullmer said:
          Alex, I have not run any tests on typename, but I use it regularly. Are you saying that it is much slower than .is_a?
          Easily to check...
          The more elements in the model - the better results script.
          SpeedTest
          is_a? - 0.36c
          kind_of? - 0.39c
          class - 0.422c
          typename - 1.313c
          Model Statistics:
          edges = 48981
          faces = 8009
          groups = 729
          components = 365
          construction_lines = 1
          construction_points = 4
          images = 3
          section_planes = 4
          texts = 4
          others = 2
          Hmm... .kind_of? is an alias for .is_a? - Is that fraction of a differences just some other random outside co-incidence?
          http://www.ruby-doc.org/core/classes/Object.html#M000370
            I did a somewhat larger test. By the looks of it .is_a?, .kind_of? and .class are pretty much the same. I take the differences due to other system factors at the time of execution.
            AT - SpeedTest:
            is_a? - 0.89c
            kind_of? - 0.782c
            class - 0.875c
            typename - 2.297c
            Model Statistics:
            edges = 159630
            faces = 61300
            groups = 0
            components = 1000
            construction_lines = 0
            construction_points = 0
            images = 0
            section_planes = 0
            texts = 0
            others = 0
              Much larger test. (did have a few programs open while I did the tests.)
              AT - SpeedTest:
              is_a? - 16.297c
              kind_of? - 16.141c
              class - 18.703c
              typename - 88.703c
              Model Statistics:
              edges = 8396595
              faces = 1026520
              groups = 52643
              components = 526428
              construction_lines = 2
              images = 0
              section_planes = 0
              texts = 0
              others = 0
              • 3 Offline
                3dsmax9
                a tool bar will be very great with this script
                • irwanwrI Offline
                  irwanwr
                  i think i need this plugin
                  thank you in advance, sir.
                  • I Offline
                    Ivancho
                    [highlight=#ffff40:2a81c421]NICE[/highlight:2a81c421]!! 😍
                    • H Offline
                      hygicell
                      I have lost a component somewhere in my drawing
                      to find it, I pasted a second one in a visible place
                      when I select this, the entity info clearly says Component (2 in model)
                      with the components window context menu, I selected all components
                      I thought then, if I could hide the rest of the model, I would easily spot where the original one is
                      but view/hide rest of model doesn't work unless you are inside the component,
                      which means you can select only one of both, and the other one is deselected
                      please help
                      Frank
                        View > Hidden Geometry ON will show all hidden objects.
                        If it's on a Layer that is OFF you won't see it though...
                        The Outliner will also show all instances that are on ON Layers...
                        You can select them in the Outliner and they select in the model.
                        • 2 / 2
