    [Plugin] Edge Tools
    211 Posts 74 Posters 323.4k Views 74 Watching
    • N
      nicasiojoel
      Thom, Thanks a lot. This should be a must on all sketchup user. A very useful plug. It makes work easier and faster.
        2.0.4 - 11.07.2011
        • Close All Edge Gaps: Heals closed edges.
        • Close All Edge Gaps: Undoable.
        • Close All Edge Gaps: Inputbox store values correctly.
          πŸ‘
          • EarthMoverE
            EarthMover
            Nice update. Thanks Thomthom!! πŸ‘
            Content Creator at Skapeup
            • mitcorbM
              mitcorb
              Hi, ThomThom:
              Thank you again for this excellent tool. And thank you for the 2.0.4 update. Will you be inserting info on the update in the first post?
                hm.. was just a minor update, really needed?
                  MartinK
                  Thanks for the plugin. I'm getting ready to try the simplify curves routine on a large number of contours. As always, these plugins you and others generously make available are great time savers, and I appreciate your efforts. Thanks again. πŸ‘
                  • xiombargX
                    xiombarg
                    Man, I am just amazed. Your plugins are the zen that I've wished Sketchup had. Great work, seriously.
                      rock1
                      on dividing a face with lines is there a way that the divisions go at a fixed distance. for. e.g. we copy one line at 1m and repeat copy it, we press 6x to make 6 copies for it. the same thing i want to do with this plugin, hw is this possible ❓
                      Signature removed by SCF Admin
                        By using the VCB - similar to how you use the native Move tool.
                        • C
                          chango70
                          Very useful, thank you!
                          • jeff hammondJ
                            jeez 😲 .. i missed this plugin too.. some awesome stuff in there!
                            thanks.
                            re: this post:
                            404 Not Found
                            (forums.sketchucation.com)
                            i think what i'd like for it to do might complicate the 'simplify curves' option.. it works great now in many cases (setting to 0 which joins all applicable edges)
                            what i'd like to be able to do is have it weld everything except there would be some sort of filter(?) in place that won't weld anything less than a certain angle... like if the angle between two edges is sharper than, say, 1 radian then the edges won't be joined..
                            just an idea and one that i personally wouldn't use very often (and i imagine i'd use it more than most people.. maybe once or twice during a heavy modeling session..)
                            if you like the idea then go for it.. otherwise, don't sweat it πŸ˜„
                            • H
                              hhdk
                              So useful! it's also perfect for solving line problems that occurs on autocad imports.
                              • guanjinG
                                guanjin
                                The first tool, if the offset of the linear, such as CAD
                                CAD.gifPowerful, can change? Perhaps my request is too much! ! πŸ˜„
                                  That you can do with the native Move - using the copy array modifier.
                                  • guanjinG
                                    guanjin
                                    Not quite understand,Can only offset the surface line,As above, and CAD functions.I'm just too greedy,Tool itself is very strong
                                      SketchUp's Move Tool
                                      http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94867
                                      You just need to do a linear array to do what you showed in the CAD animation.
                                      • guanjinG
                                        guanjin
                                        Thank you thom thom
                                        This is very complex, πŸ˜„ πŸ˜„
                                        • brookefoxB
                                          brookefox
                                          Please see the image for a use of 'face divide' for quickly uniformly hatching a face. It works very well for this as I understand it: click an edge, move to the farthest edge to check distance (and alternatively input a distance), then divide by a number which will result in the size hatch you want.
                                          Thank you.
                                          FORGET THIS: Any chance for a mod so it can be used like copy multiple, thereby saving a step, or is this already possible? I see up above that you say it is... I guess your way only takes two steps, just like copy multiple. So, yeah, forget it.edge tools -1.JPG
                                          With this hatch roads to be abandoned are indicated. The potential transparency of such edge hatches reads much better than textures, IMO. Yes, I agree, it is surely not the best way to do this, creating as it does 500 or so new edges.edge tools -2.JPG
                                          ~ Brooke
                                          • F
                                            function
                                            Hi, I updated to ttLib 2.6 and the new edge tool and it no longer gives me thr heads up display or red circles 😞
                                            • 11
                                            • 7 / 11
