    [Plugin] Edge Tools
    211 Posts 74 Posters 328.0k Views 74 Watching
      if I want to choose a different solution than the recommended, how do I get about doing that?
      There isn't any way for that at the moment. Sorry.
      • H
        HFM
        Hey Thomas, thanks for this plugin [it is saving me a heap of time redrawing a city map ๐Ÿ˜„ ]
        I do have one question though, is there a way for the plugin to ignore lines outside the component or group when splitting faces in two? At the moment I'm redrawing a map to have nice 90o corners [which makes pulling up to 3d a hell of a lot easier ๐Ÿ˜„] And while it usually is very clear which line is which, when an original line comes close to the 90o that I want it is harder to see which line you're continuing.
        http://forums.sketchucation.com/download/file.php?mode=view&id=65863&sid=1128763a1204bff415e7b7098ae972ee
          hm... your image isn't loading for me...
          • H
            HFM
            Oh well, it wasn't related to the question.
            http://forums.sketchucation.com/download/file.php?mode=view&id=65877&sid=1f1005ae594012dd65bf0057585f6022
            I just thought you deserved it! ๐Ÿ˜„
              Ah - I see.
              I didn't quite understand the question so I thought it was related.
              You're saying the tool picks up edges from outside the current context?
              • H
                HFM
                Well, here's an image to make things clearer.
                I have a map of a city, imported from Autocad with homes drawn on it. For the scale the .dwg is normally printed at it doesn't matter if a corner is not exactly 90o [this is my replacement for a degrees symbol btw ๐Ÿ˜„ ]. So, in Sketchup I create a group on top of this map, use TIG's plugin from 2D tools to create a rectangle and then fill it, or divide it, with your tool. Using this method I take one edge of the rectangle and recreate this inside the rectangle. The only problem, as mentioned before, is that if the new line is getting close to an old line, there is a change you can click a line that is not 90o with the rest of the rectangle. This would later in my process prevent me from easily drawing roofs on these houses.
                So the question was, is there a way for you plugin to look only inside the group/component when selecting the first line you want to recreate inside a shape?
                Hope this clears things up ๐Ÿ˜„
                • EarthMoverE
                  EarthMover
                  Thom, just finished a project where the Edge Tools came in so handy. What a time saver you've created. Thanks again.
                  I was wondering if it would be possible to create an additional tool that acts like the Divide Face tool, but does it simultaneously on two opposing faces connected by a shared (corner) edge. I do a lot of corner trim and siding details that require this and do it manually at the moment. It would also be handy for subdividing purposes. Something simple that does like in the image in a single click with a distance input. I guess you could say it's an "offset corner". I figured I'd ask you first as it seems like a logical addition to this toolset.
                  Content Creator at Skapeup
                    Lately I've not had as much time as I used to. So I don't feel I can commit to anything right now. Sorry. ๐Ÿ˜ž
                    • dereiD
                      derei
                      Well, this feature would be nice to be added to Artisan! ๐Ÿ˜„ As a free-update. Maybe somebody reads this! ๐Ÿ’š
                      DESIGNER AND ARTIST DEREI.UK
                      • EarthMoverE
                        EarthMover
                        No worries bro. Just a thought for the next update whenever you get around to it.
                        • H
                          harnstein
                          Just wanted to say thanks! Comes in very handy!
                          Great work you're doing, man ๐Ÿ˜„
                          still sketchin'
                            rock1
                            wow!!! ๐Ÿ˜ฎ ๐Ÿ˜ฒ Truly out of the world. The most useful one I found was that this plugin automatically detects edges and heals them ๐Ÿ˜ . Thanks a lot thomthom!!
                            Signature removed by SCF Admin
                              Thom,
                              when using 'split faces into multiple' then inputting an array only # works (not #). Not a major thing but thought you'd like to know.
                              It's the same for #/
                                Thom,
                                hmm... never knew that was a input format. That shouldn't be too hard to add.
                                  Strange thing is I never knew the other method of input until I used this tool.
                                  Anyway it's no biggie as I'm sure you're up to your eyes as it is.
                                    I've had an update lingering for this anyway (small compatibility fix). So I need to get it out anyway.
                                    • K
                                      kizner
                                      THANK A LOT - I WAS LOOKING FOR YOUR PLUGINS- THIS IS MUST HAVE IN ALL SKP.
                                      EVERY BODY SHOULD TRY
                                        # 2.0.3 - 10.05.2011
                                        #		 * VCB input now accepts all array format variants.
                                        #		 * Fixed namespace compatibility with TT_Lib 2.5.4
                                        Requires TT_Lib 2.5.4
                                          ๐Ÿ‘
                                          Thanks Thom
                                            That one was for you Rich! ๐Ÿ˜‰
                                            • 11
                                            • 5 / 11
