    Help making this 3d ornament
    28 Posts 9 Posters 2.2k Views 9 Watching
      hhhmmmmmmmmmmmm πŸ˜’ not quite. but my head hurts thinking about it
        Aaaaaahhhhhh...... πŸŽ‰
          dajohn
          Thanks everybody for your suggestions. Tig, I tried your method and it works great. Is it possible to make rounded edges? Also, I tried to run the profile edge off the second rail, but it broke in two. I separated it and made it a curve and it worked great. Except for the round edges the results look perfect. Thanks again!
          leaf ornament.skp
            Did you look at this?
            Although it isn't exactly the same, I think you could make the rounded edge in the same way I made the narrower parts of the finial.
              I'm seeing a completely different shape than the rest?
                boofredlay
                That is funny because the shape I see in my mind is different than any of the examples. πŸ˜†
                  To me it looks like leaf with two different larger bends and the edge curled over. I was only suggesting the finals I drew as an illustration of the way to get the main part and the curl on the edge. Maybe it's too hard for others to see the connection between what I did and the leaf. Should I remove it?
                    dajohn
                    Thanks Dave. I hadn't seen that video. I have other ornaments to make and I think I can use those same principles.
                      Hmmm, with only one refernce image it's hard to understand the actual shape.
                      This is what I think...
                        fellas, i think it's more along these lines... πŸ˜‰
                        ornament.skp
                        click pic -> bigger
                          @Pete
                          Nice mapping can I see another view?
                          @Jeff
                            @Jeff
                              @Jeff
                              πŸ˜’
                                πŸ˜•
                                Sorry Rich, I never saved it.
                                  @Jeff
                                  πŸ˜’
                                  I never know how to interpret roll eyes.
                                  But yeah, the thing is shaped like the skp/picture I posted.
                                    I was saying your .skp looked like this ❓ smiley
                                    I roll my eyes at my shit joke.
                                    Where's the 'hang my head in shame' smiley?
                                      boofredlay
                                      Here
                                      http://msnsmileys.net/b/smileys/Blacky_Small/Shame.png
                                        i think it's a peace lily or similar
                                        as to drawing it, i used BezierSpline to trace, move & rotate to place the splines, then curviloft's Loft with the method set to Bezier curves -- Respect tangency then used the tension controls on the segments..
                                          dajohn
                                          I started quite the debate. Thanks again for all the input. Some of these ideas I haven't even thought of. If you look at my second posting of the skp that is how the client imagined it to me - I haven't added the stem on the top like Solo did yet(at least I hope so - now I'm a little worried). If I'm wrong or my customer is wrong, I have a lot of ideas to work from. Unfortunately there's no second perspective image to look at. The coloring on it is more for effect than actual dimensioning. If you look at the coloring on the top lip, it suggests the same coloring on the back side - the blue on the left is just arbitrary coloring - festive, huh? I have another of the series that I could use some help with if you don't mind my picking the collective brain one more time. I'll post that one as a separate thread.
