    Help making this 3d ornament
    28 Posts 9 Posters 2.6k Views 9 Watching
      This isn't exactly what you want... but shows how to use several compound curves as profiles/rails in ExtrudeEdgesByRails to achieve comparable results...Capture.PNG
        dajohn
        Hi Tig. I tried your loft by rails, but I got a convoluted compound face that doubled back on itself. I also used edges by rails, but got much the same as you did. I then used TGI3d create mesh and got what you see in the file. It seems to work fairly well, but I don't know how to round over the edges and the inside curved surface doesn't have quite the volume I need. I couldn't get soap skin and bubble to work on it either. I also used the joint push pull plugin, but as you can see, it only gave me one extruded face.
        leaf ornament.skp
          Here's a version of your form split to make a profile and two rails and EEbyRails, Copy and EEbyVector to for edge-faces...Capture.PNG
            Would something like these be close to the right idea?
            http://farm6.static.flickr.com/5299/5417915921_68b4480c2f.jpg
              hhhmmmmmmmmmmmm πŸ˜’ not quite. but my head hurts thinking about it
                Aaaaaahhhhhh...... πŸŽ‰
                  dajohn
                  Thanks everybody for your suggestions. Tig, I tried your method and it works great. Is it possible to make rounded edges? Also, I tried to run the profile edge off the second rail, but it broke in two. I separated it and made it a curve and it worked great. Except for the round edges the results look perfect. Thanks again!
                  leaf ornament.skp
                    Did you look at this?
                    Although it isn't exactly the same, I think you could make the rounded edge in the same way I made the narrower parts of the finial.
                      I'm seeing a completely different shape than the rest?
                      • boofredlayB
                        boofredlay
                        That is funny because the shape I see in my mind is different than any of the examples. πŸ˜†
                          To me it looks like leaf with two different larger bends and the edge curled over. I was only suggesting the finals I drew as an illustration of the way to get the main part and the curl on the edge. Maybe it's too hard for others to see the connection between what I did and the leaf. Should I remove it?
                            dajohn
                            Thanks Dave. I hadn't seen that video. I have other ornaments to make and I think I can use those same principles.
                            • soloS
                              Hmmm, with only one refernce image it's hard to understand the actual shape.
                              This is what I think...
                              • jeff hammondJ
                                fellas, i think it's more along these lines... πŸ˜‰
                                ornament.skp
                                click pic -> bigger
                                  @Pete
                                  Nice mapping can I see another view?
                                  @Jeff
                                  • jeff hammondJ
                                    @Jeff
                                      @Jeff
                                      πŸ˜’
                                      • soloS
                                        πŸ˜•
                                        Sorry Rich, I never saved it.
                                        • jeff hammondJ
                                          @Jeff
                                          πŸ˜’
                                          I never know how to interpret roll eyes.
                                          But yeah, the thing is shaped like the skp/picture I posted.
                                            I was saying your .skp looked like this ❓ smiley
                                            I roll my eyes at my shit joke.
                                            Where's the 'hang my head in shame' smiley?
