How to put a SketchUp model on a website?
They have a free version, too, but what I do not like is that it uses Java.
Yeah i don't like the use of Java either, i'd also like to avoid the use of any visible interface. Again, i keep harking back to this example: http://maemo.nokia.com/n900/360/ of just a very simple, but great looking 360' rotation embedded into the webpage. I can't believe there is not a simple way to do this?
Solo mentioned rendering 100+ images around the model, which is fine, but how could they be pieced together to create a rotation like that?
With that exact same SU Webexporter that would otherwise use images exported straight from SU.
Alan that looks like it might work and $10 bucks is cheap.
Has anybody here tried it?
s
It looks like a good solution.
I'll give it a try
Except for the difficulty trying to figure out the documentation, this does have a chance.
http://www.renderplus.com/htm/360-renders/sources/webpage.htm
Its going the wrong way!!
Nice Al. I rather like that built-in drop shadow effect it has.
Yes, from the comments on that thread, it didn't seem to be the most comprehensively documented piece of scripting. -
I grabbed a 360-degree scene making script by wikii (creat360view.rb) , and modified it to save an image for each view. I just need to reverse the direction of the views.
The "trick" to using the SWF stuff is to modify their XML file (not try to use one with a different name), and then figure out how to put everything on a web page.
I will post more stuff when I get it all working properly.
I've been following this discussion because I'd consider doing something similar. However, it would be great if it didn't even require Flash, like the most recent option under consideration. Something that is server-side, like PHP, would be better. I haven't done any web scripting for quite some time, but conceptually it is straight forward. Any PHP scripters out there?
When they first added the spinning models to the 3D Warehouse I looked at it and it was a Javascript/HTML only solution. I'll have to try to drag that up again.
Java suffers from the same problem that Flash does: it requires the user to have a browswer plugin. Most people have them, even if they don't know it. However, I always prefer solutions that require next to nothing from the user. I generally only use interactive features on my website if I can make it server-side only. So far, these are all very good solutions, though.
not java, but javascript, which is probably more acceptable
My bad. I misread your post. Yes, javascript is quite acceptable. That would be a great solution IMO. Thanks for clarifying and I hope you can find it!
Here is a sample. It should be easy to make it work. I'll try later
http://solar.physics.montana.edu/ypop/Intermission/Images/feb98eclipse_event1_j.html
This sample does't use a mouse. But I seem to remember one which did.
@solo said:
I just completed two of those for Wired magazine (this months issue) for iPad.
I used Thea render and 120 renders (BSD 1min 30sec each frame)
I submitted them in images, Liam one of our members is a Mac user and he did the compilation, not sure what sofware he used however.
Very cool Solo. Which graphics are they? I just downloaded the April Issue.
Nathan, they are the Och hydraulic watchbox and the Glenmorangie whiskey in mechanical case.
I don't have an iPad so I never saw the finished product.
Here's a Javascript viewer/player for objects and panoramas: http://jquery.vostrel.cz/reel
Using js and JQuery, and it can do multi-row. Look at that Mini. -
Here is a JavaScript only example: Playground
The mouse doesn't work as well as I would like. But it will give you an idea of what is possible.
{Edit: This example works great in IE, but it does not track the mouse smoothly in Firefox]
So far, the jQuery Reel Plugin is the winner, IMO. Al, your Javascript-only implementation is nice, too, but doesn't have the polish yet. I'm going to do some render tests soon and see how it works.
With your input, this post could be even better š
