    How to put a SketchUp model on a website?
    54 Posts 15 Posters 13.1k Views 15 Watching
      tallbridgeguy
      Alan that looks like it might work and $10 bucks is cheap.
      Has anybody here tried it?
      s
      Nielsen
      http://www.tallbridgeguy.com/
      • Al HartA Offline
        Al Hart
        It looks like a good solution.
        I'll give it a try
        Al Hart
        IRender nXt from Render Plus
        • Al HartA Offline
          Al Hart
          Except for the difficulty trying to figure out the documentation, this does have a chance.
          Page not found – Render Plus Software
          (www.renderplus.com)
          Al Hart
          • Alan FraserA Offline
            Alan Fraser
            Its going the wrong way!! 😉
            Nice Al. I rather like that built-in drop shadow effect it has.
            Yes, from the comments on that thread, it didn't seem to be the most comprehensively documented piece of scripting.
            3D Figures
            • Al HartA Offline
              Al Hart
              I grabbed a 360-degree scene making script by wikii (creat360view.rb) , and modified it to save an image for each view. I just need to reverse the direction of the views.
              The "trick" to using the SWF stuff is to modify their XML file (not try to use one with a different name), and then figure out how to put everything on a web page.
              I will post more stuff when I get it all working properly.
              Al Hart
                ledisnomad
                I've been following this discussion because I'd consider doing something similar. However, it would be great if it didn't even require Flash, like the most recent option under consideration. Something that is server-side, like PHP, would be better. I haven't done any web scripting for quite some time, but conceptually it is straight forward. Any PHP scripters out there?
                • Al HartA Offline
                  Al Hart
                  When they first added the spinning models to the 3D Warehouse I looked at it and it was a Javascript/HTML only solution. I'll have to try to drag that up again.
                  Al Hart
                    ledisnomad
                    Java suffers from the same problem that Flash does: it requires the user to have a browswer plugin. Most people have them, even if they don't know it. However, I always prefer solutions that require next to nothing from the user. I generally only use interactive features on my website if I can make it server-side only. So far, these are all very good solutions, though.
                    • Al HartA Offline
                      Al Hart
                      not java, but javascript, which is probably more acceptable
                      Al Hart
                        ledisnomad
                        My bad. I misread your post. Yes, javascript is quite acceptable. That would be a great solution IMO. Thanks for clarifying and I hope you can find it!
                        • Al HartA Offline
                          Al Hart
                          Here is a sample. It should be easy to make it work. I'll try later
                          Javascript Movie Player
                          (solar.physics.montana.edu)
                          This sample does't use a mouse. But I seem to remember one which did.
                          Al Hart
                          • focptF Offline
                            focpt
                            @solo said:
                            I just completed two of those for Wired magazine (this months issue) for iPad.
                            I used Thea render and 120 renders (BSD 1min 30sec each frame)
                            I submitted them in images, Liam one of our members is a Mac user and he did the compilation, not sure what sofware he used however.
                            Very cool Solo. Which graphics are they? I just downloaded the April Issue.
                            • Nathan
                              http://www.focalpointstudio.net
                            SU8, VRay 1.49
                            • soloS Offline
                              Nathan, they are the Och hydraulic watchbox and the Glenmorangie whiskey in mechanical case.
                              I don't have an iPad so I never saw the finished product. 😞
                                bjornkn
                                Here's a Javascript viewer/player for objects and panoramas: http://jquery.vostrel.cz/reel
                                Using js and JQuery, and it can do multi-row. Look at that Mini.
                                • Al HartA Offline
                                  Al Hart
                                  Here is a JavaScript only example: Playground
                                  The mouse doesn't work as well as I would like. But it will give you an idea of what is possible.
                                  {Edit: This example works great in IE, but it does not track the mouse smoothly in Firefox]
                                  Al Hart
                                    ledisnomad
                                    So far, the jQuery Reel Plugin is the winner, IMO. Al, your Javascript-only implementation is nice, too, but doesn't have the polish yet. I'm going to do some render tests soon and see how it works.
                                    • soloS Offline
                                      How do youn install/use jquery?
                                      • Al HartA Offline
                                        Al Hart
                                        You just download the basic JQuery, and store it on your web server, and ink to it in the HTML, and then download the special JQuery piece you want to use.
                                        It took me a while to get it working the first time. But the trick to speed things up is to view the page source of their working page to see just what they used and set.
                                        e.g.
                                        <script charset='utf-8' src='http://code.jquery.com/jquery-latest.min.js' type='text/javascript'></script>
                                            <script charset='utf-8' src='http://code.vostrel.cz/jquery.reel-edge-bundle.js' type='text/javascript'></script>
                                        I'll try to make a JReel example if I get a chance.
                                        Al Hart
                                        • soloS Offline
                                          That sounds like this:
                                          你刚才下载的基本jQuery和存储在您的Web服务器中,以及油墨的HTML,然后下载的特殊JQuery的一块你要使用的。
                                          I guess I'm gonna keep looking for an easier solution.
                                          • Al HartA Offline
                                            Al Hart
                                            I know, it was a little scary the first time - (I used a datepicker JQuery script.
                                            After I make a sample, you can just download the JQuery stuff, and copy things from the sample HTML.
                                            Also, if we ever find a solution we like, we plan to add it to RpTools, RPS 3D PDF, and IRender nXt to generate the web pages automatically
                                            Al Hart
                                            • 2 / 3
