    How to put a SketchUp model on a website?
    54 Posts 15 Posters 13.7k Views 15 Watching
      lewislovedale
      Unfortunately i'm on a Mac so i can't use that .exe exporter. What resolution does it display to and is it possible to remove the clunky-looking interface on the SketchUp viewer?
      I was after a very sleek, rendered image with a transparent background, if that's possible with a SketchUp model. I image it would require using flash? This is pretty much exactly what i'm going for: http://maemo.nokia.com/n900/360/
      Thanks for the help so far.
      • soloS Offline
        I just completed two of those for Wired magazine (this months issue) for iPad.
        I used Thea render and 120 renders (BSD 1min 30sec each frame)
        I submitted them in images, Liam one of our members is a Mac user and he did the compilation, not sure what sofware he used however.
          lewislovedale
          I'd thought rendering a series of images would probably be the way to get the best result aesthetically. Although my knowledge of rendering is pretty poor this would probably be a good place to start. Is there an automatic feature on most rendering software to do a batch making up a full rotation or did you do all 120 separately?
          Nonetheless, it's the piecing of these images into a rotation i'd be clueless on...
          Thanks again for the help so far.
            tallbridgeguy
            I would like that 3d thingy as well. I would like to rotate around a bridge model.
            Is this related?
            3d flash?
            Page Introuvable - erreur 404 | Musée des Arts et Métiers
            La page que vous recherchez n’est plus en ligne (ou ne l’a jamais été).
            musée des Arts et Métiers (www.arts-et-metiers.net)
            Nielsen
            http://www.tallbridgeguy.com/
            • Al HartA Offline
              Al Hart
              Here's a website with a SketchUp 3D model embedded in it: Embedded Model
              http://wiki.renderplus.com/images/7/79/Embdeed_pdf_sample.jpg
              Al Hart
              IRender nXt from Render Plus
                lewislovedale
                tallbridgeguy, the page you linked to is an interior model. I'm after producing an exterior model with as little necessity for plugins/downloads/complex controls as possible. Like the Nokia example one i posted earlier (http://maemo.nokia.com/n900/360/), which plays intuitively without asking any questions.
                Basically, the model i have produced is a piece of agricultural equipment and not to generalise, i expect the majority of people who look at the website it will (hopefully) appear on will be less computer-savvy than most here, so it needs to be as simple as pie whilst looking very sexy. If that's possible.
                I tried your link Al but unfortunately it just came up with this: http://img859.imageshack.us/f/screenshot20110423at115.png/ maybe incompatibility between mac and PC again. I'm also trying avoid a link but rather embedding the rotatable model or a series of renders that give that impression on the webpage.
                Solo, is there any opportunity to see the iPad model you'd mentioned? It sounds like it's what i'm after and if so, i'll attempt to copy your method.
                Thanks again.
                  tallbridgeguy
                  I found this site. Demicron and they have a free download.
                  江南在线-官网
                  2026世界杯专属平台 世界杯游戏 健康体育娱乐平台 哈斯卡诚信推荐,永久域名:tiyu1688.com,,年企业注册资金8亿元,总资98亿元。江南在线承担着推动城市更新、改造和提升工作,推动民生产业发展和做优做强做大,确保国有资产持续稳定保值、增值,致力于成为宁波城市发展的综合运营商。
                  (www.demicron.com)
                  Anybody use it?
                  3D examples.
                  http://www.demicron.com/gallery/mediterranean/mediterranean.html
                  http://www.demicron.com/gallery/perceuse/perceuse.html
                  Nielsen
                  • Al HartA Offline
                    Al Hart
                    Very impressive graphics and interaction.
                    I was looking to see if they had an interface to SketchUp. But before I got that rd I checked the price - $1,495.00 and was a bit put off.
                    Al
                    江南在线-官网
                    (www.demicron.com)
                    Anybody use it?
                    3D examples.
                    Al Hart
                      They have a free version, too, but what I do not like is that it uses Java.
                        lewislovedale
                        Yeah i don't like the use of Java either, i'd also like to avoid the use of any visible interface. Again, i keep harking back to this example: http://maemo.nokia.com/n900/360/ of just a very simple, but great looking 360' rotation embedded into the webpage. I can't believe there is not a simple way to do this?
                        Solo mentioned rendering 100+ images around the model, which is fine, but how could they be pieced together to create a rotation like that?
                          With that exact same SU Webexporter that would otherwise use images exported straight from SU.
                          • Alan FraserA Offline
                            Alan Fraser
                            A lot of that Nolia type stuff is done with Swift3D...which is probably far more than you need.
                            There is a cheap little script here that seems to fit the bill.
                            3D Figures
                              tallbridgeguy
                              Alan that looks like it might work and $10 bucks is cheap.
                              Has anybody here tried it?
                              s
                              Nielsen
                              • Al HartA Offline
                                Al Hart
                                It looks like a good solution.
                                I'll give it a try
                                Al Hart
                                • Al HartA Offline
                                  Al Hart
                                  Except for the difficulty trying to figure out the documentation, this does have a chance.
                                  Page not found – Render Plus Software
                                  (www.renderplus.com)
                                  Al Hart
                                    Alan Fraser
                                    Its going the wrong way!! 😉
                                    Nice Al. I rather like that built-in drop shadow effect it has.
                                    Yes, from the comments on that thread, it didn't seem to be the most comprehensively documented piece of scripting.
                                    3D Figures
                                    • Al HartA Offline
                                      Al Hart
                                      I grabbed a 360-degree scene making script by wikii (creat360view.rb) , and modified it to save an image for each view. I just need to reverse the direction of the views.
                                      The "trick" to using the SWF stuff is to modify their XML file (not try to use one with a different name), and then figure out how to put everything on a web page.
                                      I will post more stuff when I get it all working properly.
                                      Al Hart
                                        ledisnomad
                                        I've been following this discussion because I'd consider doing something similar. However, it would be great if it didn't even require Flash, like the most recent option under consideration. Something that is server-side, like PHP, would be better. I haven't done any web scripting for quite some time, but conceptually it is straight forward. Any PHP scripters out there?
                                        • Al HartA Offline
                                          Al Hart
                                          When they first added the spinning models to the 3D Warehouse I looked at it and it was a Javascript/HTML only solution. I'll have to try to drag that up again.
                                          Al Hart
                                            ledisnomad
                                            Java suffers from the same problem that Flash does: it requires the user to have a browswer plugin. Most people have them, even if they don't know it. However, I always prefer solutions that require next to nothing from the user. I generally only use interactive features on my website if I can make it server-side only. So far, these are all very good solutions, though.
                                            • 1 / 3
