    How to put a SketchUp model on a website?
    54 Posts 15 Posters 13.6k Views 15 Watching
      ledisnomad
      I've been following this discussion because I'd consider doing something similar. However, it would be great if it didn't even require Flash, like the most recent option under consideration. Something that is server-side, like PHP, would be better. I haven't done any web scripting for quite some time, but conceptually it is straight forward. Any PHP scripters out there?
      • Al HartA Offline
        Al Hart
        When they first added the spinning models to the 3D Warehouse I looked at it and it was a Javascript/HTML only solution. I'll have to try to drag that up again.
        Al Hart
        IRender nXt from Render Plus
          ledisnomad
          Java suffers from the same problem that Flash does: it requires the user to have a browswer plugin. Most people have them, even if they don't know it. However, I always prefer solutions that require next to nothing from the user. I generally only use interactive features on my website if I can make it server-side only. So far, these are all very good solutions, though.
          • Al HartA Offline
            Al Hart
            not java, but javascript, which is probably more acceptable
            Al Hart
              ledisnomad
              My bad. I misread your post. Yes, javascript is quite acceptable. That would be a great solution IMO. Thanks for clarifying and I hope you can find it!
              • Al HartA Offline
                Al Hart
                Here is a sample. It should be easy to make it work. I'll try later
                Javascript Movie Player
                (solar.physics.montana.edu)
                This sample does't use a mouse. But I seem to remember one which did.
                Al Hart
                • focptF Offline
                  focpt
                  @solo said:
                  I just completed two of those for Wired magazine (this months issue) for iPad.
                  I used Thea render and 120 renders (BSD 1min 30sec each frame)
                  I submitted them in images, Liam one of our members is a Mac user and he did the compilation, not sure what sofware he used however.
                  Very cool Solo. Which graphics are they? I just downloaded the April Issue.
                  • Nathan
                    http://www.focalpointstudio.net
                  SU8, VRay 1.49
                  • soloS Offline
                    Nathan, they are the Och hydraulic watchbox and the Glenmorangie whiskey in mechanical case.
                    I don't have an iPad so I never saw the finished product. 😞
                      bjornkn
                      Here's a Javascript viewer/player for objects and panoramas: http://jquery.vostrel.cz/reel
                      Using js and JQuery, and it can do multi-row. Look at that Mini.
                      • Al HartA Offline
                        Al Hart
                        Here is a JavaScript only example: Playground
                        The mouse doesn't work as well as I would like. But it will give you an idea of what is possible.
                        {Edit: This example works great in IE, but it does not track the mouse smoothly in Firefox]
                        Al Hart
                          ledisnomad
                          So far, the jQuery Reel Plugin is the winner, IMO. Al, your Javascript-only implementation is nice, too, but doesn't have the polish yet. I'm going to do some render tests soon and see how it works.
                          • soloS Offline
                            How do youn install/use jquery?
                            • Al HartA Offline
                              Al Hart
                              You just download the basic JQuery, and store it on your web server, and ink to it in the HTML, and then download the special JQuery piece you want to use.
                              It took me a while to get it working the first time. But the trick to speed things up is to view the page source of their working page to see just what they used and set.
                              e.g.
                              <script charset='utf-8' src='http://code.jquery.com/jquery-latest.min.js' type='text/javascript'></script>
                                  <script charset='utf-8' src='http://code.vostrel.cz/jquery.reel-edge-bundle.js' type='text/javascript'></script>
                              I'll try to make a JReel example if I get a chance.
                              Al Hart
                              • soloS Offline
                                That sounds like this:
                                你刚才下载的基本jQuery和存储在您的Web服务器中,以及油墨的HTML,然后下载的特殊JQuery的一块你要使用的。
                                I guess I'm gonna keep looking for an easier solution.
                                • Al HartA Offline
                                  Al Hart
                                  I know, it was a little scary the first time - (I used a datepicker JQuery script.
                                  After I make a sample, you can just download the JQuery stuff, and copy things from the sample HTML.
                                  Also, if we ever find a solution we like, we plan to add it to RpTools, RPS 3D PDF, and IRender nXt to generate the web pages automatically
                                  Al Hart
                                  • Al HartA Offline
                                    Al Hart
                                    Actually it is raw "Web Exporter".
                                    Perhaps if there is some interest, SketchUp can work on it some more.
                                    Al Hart
                                    • soloS Offline
                                      Thanks to Focpt (Nathan) who has an iPad and took this video of the rotation thingy-majiggy for Wired Magazine.
                                      Liam would need to find a stopping point (busy bastard), log onto SCF and explain how he used my images to create this.
                                      [flash=700,500:ncd100sp]http://www.youtube.com/v/tyxHSBd9bCg&feature=youtu.be[/flash:ncd100sp]
                                      I modeled it with Sketchup and rendered it with Thea, 120 renders each model at 30 degree increments.
                                        d12dozr
                                        👍 That's cool!
                                        http://goo.gl/f7ooYh
                                          Jim
                                          Google's Swivel Viewer is open-source here - it is the same (I think) as the 3D Warehouse viewer. This is now a built-in feature of Picasa WebAlbums, also.
                                          Also, here is one made for Blender, although SU could create the images instead of Blender - all that matters is the image name. I believe there are some old and new plugins (TIG's nudge orbit?) that could be made to work easily.
                                            driven
                                            I've been using a 'hacked' version of web exporter on my mac,
                                            I made a .skp template with a scene/layer a generator I'm working on, I swap out the component and export the animation back into a hacked version of SU Web Exporter.
                                            this version is rotating the camera, but I'm wanting to rotate the object normally which is why I need the layers.
                                            I'm producing 192 imgs from 36 scenes
                                            on the mac the choice for export allows jpg's, png's, or tif's, the examples a 800 x 454 jpg, but 1200x681 png's with transparency look great.
                                            Is it possible to put up a working example here? (in an iframe)
                                            ...MODEL from 3D warehouse...
                                            should I make this into a plugin?
                                            • 2 / 3
