    How to put a SketchUp model on a website?
    54 Posts 15 Posters 13.7k Views 15 Watching
    • Al HartA Offline
      Al Hart
      Very impressive graphics and interaction.
      I was looking to see if they had an interface to SketchUp. But before I got that rd I checked the price - $1,495.00 and was a bit put off.
      Al
      @tallbridgeguy said:
      I found this site. Demicron and they have a free download.
      江南在线-官网
      2026世界杯专属平台 世界杯游戏 健康体育娱乐平台 哈斯卡诚信推荐,永久域名:tiyu1688.com,,年企业注册资金8亿元,总资98亿元。江南在线承担着推动城市更新、改造和提升工作,推动民生产业发展和做优做强做大,确保国有资产持续稳定保值、增值,致力于成为宁波城市发展的综合运营商。
      (www.demicron.com)
      Anybody use it?
      3D examples.
      http://www.demicron.com/gallery/mediterranean/mediterranean.html
      http://www.demicron.com/gallery/perceuse/perceuse.html
      Al Hart
      IRender nXt from Render Plus
        They have a free version, too, but what I do not like is that it uses Java.
          lewislovedale
          Yeah i don't like the use of Java either, i'd also like to avoid the use of any visible interface. Again, i keep harking back to this example: http://maemo.nokia.com/n900/360/ of just a very simple, but great looking 360' rotation embedded into the webpage. I can't believe there is not a simple way to do this?
          Solo mentioned rendering 100+ images around the model, which is fine, but how could they be pieced together to create a rotation like that?
            With that exact same SU Webexporter that would otherwise use images exported straight from SU.
            • Alan FraserA Offline
              Alan Fraser
              A lot of that Nolia type stuff is done with Swift3D...which is probably far more than you need.
              There is a cheap little script here that seems to fit the bill.
              3D Figures
                tallbridgeguy
                Alan that looks like it might work and $10 bucks is cheap.
                Has anybody here tried it?
                s
                Nielsen
                http://www.tallbridgeguy.com/
                • Al HartA Offline
                  Al Hart
                  It looks like a good solution.
                  I'll give it a try
                  Al Hart
                  • Al HartA Offline
                    Al Hart
                    Except for the difficulty trying to figure out the documentation, this does have a chance.
                    Page not found – Render Plus Software
                    (www.renderplus.com)
                    Al Hart
                      Alan Fraser
                      Its going the wrong way!! 😉
                      Nice Al. I rather like that built-in drop shadow effect it has.
                      Yes, from the comments on that thread, it didn't seem to be the most comprehensively documented piece of scripting.
                      3D Figures
                      • Al HartA Offline
                        Al Hart
                        I grabbed a 360-degree scene making script by wikii (creat360view.rb) , and modified it to save an image for each view. I just need to reverse the direction of the views.
                        The "trick" to using the SWF stuff is to modify their XML file (not try to use one with a different name), and then figure out how to put everything on a web page.
                        I will post more stuff when I get it all working properly.
                        Al Hart
                          ledisnomad
                          I've been following this discussion because I'd consider doing something similar. However, it would be great if it didn't even require Flash, like the most recent option under consideration. Something that is server-side, like PHP, would be better. I haven't done any web scripting for quite some time, but conceptually it is straight forward. Any PHP scripters out there?
                          • Al HartA Offline
                            Al Hart
                            When they first added the spinning models to the 3D Warehouse I looked at it and it was a Javascript/HTML only solution. I'll have to try to drag that up again.
                            Al Hart
                              ledisnomad
                              Java suffers from the same problem that Flash does: it requires the user to have a browswer plugin. Most people have them, even if they don't know it. However, I always prefer solutions that require next to nothing from the user. I generally only use interactive features on my website if I can make it server-side only. So far, these are all very good solutions, though.
                              • Al HartA Offline
                                Al Hart
                                not java, but javascript, which is probably more acceptable
                                Al Hart
                                  ledisnomad
                                  My bad. I misread your post. Yes, javascript is quite acceptable. That would be a great solution IMO. Thanks for clarifying and I hope you can find it!
                                  • Al HartA Offline
                                    Al Hart
                                    Here is a sample. It should be easy to make it work. I'll try later
                                    Javascript Movie Player
                                    (solar.physics.montana.edu)
                                    This sample does't use a mouse. But I seem to remember one which did.
                                    Al Hart
                                    • focptF Offline
                                      focpt
                                      @solo said:
                                      I just completed two of those for Wired magazine (this months issue) for iPad.
                                      I used Thea render and 120 renders (BSD 1min 30sec each frame)
                                      I submitted them in images, Liam one of our members is a Mac user and he did the compilation, not sure what sofware he used however.
                                      Very cool Solo. Which graphics are they? I just downloaded the April Issue.
                                      • Nathan
                                        http://www.focalpointstudio.net
                                      SU8, VRay 1.49
                                      • soloS Offline
                                        Nathan, they are the Och hydraulic watchbox and the Glenmorangie whiskey in mechanical case.
                                        I don't have an iPad so I never saw the finished product. 😞
                                          bjornkn
                                          Here's a Javascript viewer/player for objects and panoramas: http://jquery.vostrel.cz/reel
                                          Using js and JQuery, and it can do multi-row. Look at that Mini.
                                          • Al HartA Offline
                                            Al Hart
                                            Here is a JavaScript only example: Playground
                                            The mouse doesn't work as well as I would like. But it will give you an idea of what is possible.
                                            {Edit: This example works great in IE, but it does not track the mouse smoothly in Firefox]
                                            Al Hart
                                            • 1 / 3
