    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.0m Views 183 Watching
      bentleykfrog
      Ohh, I forgot to post an example of how I've used the tool. I used Polyline divide in the image below on the lines that set out the rows of vines, then I used Chris Fullmer's Component Stringer to set out the vine components along these paths. Very happy with the result β˜€
      Polyline Divide usage example
      • fredo6F Offline
        @bentleykfrog said:
        cool tool, just one suggestion. It would be helpful to reverse the direction of the polyline divide function so you can choose which end the dividing starts at. Currently, for curves that have an incorrect start and end, I have to explode my curve, then recreate the curve using the classic bezier curve tool, then use polyline divide.
        Sorry for my ignorance if this feature already exists.
        The feature does not exist in BezierSpline, but you can use the plugin RevertCurve to inverse the direction of the curve.
          bentleykfrog
          Ahh! awesome, thanks again Fredo6
            mimarhamza
            Hi Fredo This toolbar is great.My question is that I couldnt find out how to snap x y z axes like hold the shift key down draw line and also hard to snap endpoint when creating or editing curves?
            • F Offline
              function
              hi - I had a feature request for the Courbette tool.: can we have an option to specify a uniform division of vertexes over the whole curve while retaining the same control points? or possibly even better, to modify the S value between control points. As far as I have been able to understand, the S value affects the whole curve which causes facets with shallow slopes and over-division with high slopes (see image). Trying to up the S value to compensate for the faceting then simultaneously overpopulates higher slopes with far too many vertexes. This tool is very intuitive and great to work with, however I find myself attempting workarounds to create a more uniform distribution.
              • fredo6F Offline
                If the plugin created equal divisions, then it would adjust on the minimum ones, which would make the curve divided into a possibly big number of segments (in your exmaple you would have probably over 100).
                I think the best is that you resample the curve (or portions of the curve) with Polyline Divider or Polyline Segmentor (also included in BezierSpline) in order to have even segmentation and better control the result depending on the situation.
                • F Offline
                  function
                  πŸ‘ thanks for the quick response
                  • H Offline
                    herbert2000
                    i have a probleme, I have install this version an still impossible to edit polylign. help !
                      Was the polyline created with this plugin?
                        khanhvu86
                        thanks
                        • H Offline
                          herbert2000
                          yes, i draw it with the plugin,...and sketchup pro ! i have XP PRO and an old PC, may be my config is too old . I will try with an old version of sketchup ! thanks for the response !
                            Once you've drawn your polyline and finished it, right click on it and choose Edit Polyline. Then you should be able to move the points of the line around. If you can't do this, please describe what part of it you can't do.
                            • I Offline
                              ivreich
                              New feature Suggestion
                              Dear Fredo
                              Do you think it would be useful/possible to have bezierspline incorporate a function to blend 2 bsplines by curvature/tangents in the same way that the "blend" command in rhino does?
                              currently it's possible to do it manually by placing construction lines along the end segments of each bspline to simulate tangent guides, so i'm assuming it could be automated?
                              Cheers,
                              Joel
                              • jeff hammondJ Offline
                                Hey Joel
                                Yeah, I think that would be very useful. (blend curve by bezier -- or whatever it may be called)
                                It be sweet if the first control point in on each end of the line were subsequently locked to the direction of the line being blended to. (ie- the construction line or guide if doing the blend manually)
                                • fredo6F Offline
                                  Hey Joel
                                  Jeff and Joel,
                                  Very good idea. I will do something in a frefresh of BezierSpline.
                                    nice! i'm glad you're into the idea.
                                    i think it will be great and i'm sure a bunch of other people will be into it once they see what it does.
                                      d12dozr
                                      Sounds like a great addition to an excellent tool! πŸ‘ Good idea, guys.
                                      http://goo.gl/f7ooYh
                                        More is the friend of Better! πŸ˜‰
                                        • I Offline
                                          ivreich
                                          Sweeeet. fredo responded to my post! im a little starstruck now...
                                          • H Offline
                                            herbert2000
                                            it's impossible for me to edit polylign....
                                            • 11
                                            • 12
                                            • 22
                                            • 23
                                            • 10 / 23
