[Plugin] BezierSpline - v2.2a - 22 Apr 21
thanks for the quick response -
i have a probleme, I have install this version an still impossible to edit polylign. help !
Was the polyline created with this plugin?
thanks
yes, i draw it with the plugin,...and sketchup pro ! i have XP PRO and an old PC, may be my config is too old . I will try with an old version of sketchup ! thanks for the response !
Once you've drawn your polyline and finished it, right click on it and choose Edit Polyline. Then you should be able to move the points of the line around. If you can't do this, please describe what part of it you can't do.
New feature Suggestion
Dear Fredo
Do you think it would be useful/possible to have bezierspline incorporate a function to blend 2 bsplines by curvature/tangents in the same way that the "blend" command in rhino does?
currently it's possible to do it manually by placing construction lines along the end segments of each bspline to simulate tangent guides, so i'm assuming it could be automated?
Cheers,
Joel
Hey Joel
Yeah, I think that would be very useful. (blend curve by bezier -- or whatever it may be called)It be sweet if the first control point in on each end of the line were subsequently locked to the direction of the line being blended to. (ie- the construction line or guide if doing the blend manually)
Hey Joel
Jeff and Joel,
Very good idea. I will do something in a frefresh of BezierSpline.
nice! i'm glad you're into the idea.
i think it will be great and i'm sure a bunch of other people will be into it once they see what it does. -
Sounds like a great addition to an excellent tool!
Good idea, guys. -
More is the friend of Better!
Sweeeet. fredo responded to my post! im a little starstruck now...
it's impossible for me to edit polylign....
NEW FEATURE SUGGESTION: "MEAN CURVE"
Hi again Fredo
I know it hasn't been long since my last feature suggestion ("blend curve by bezier"), but here's another one you might be interested in:
The "mean curve" command in Rhino creates an intermediate or "average" curve between two existing curves, which is especially useful for adding detail to contour maps and such. Is it possible for Bezierspline to do the same?
I have attached an image showing how I imagine it would be done manually; i.e. draw connecting lines linking corresponding vertices on the two original curves, then drawing a third curve linking all the midpoints of those connecting lines to create an "average" curve.
What do you reckon? The added advantage of Bezierspline automating this is that the generated curve would be an editable bspline as well. Does anyone else think this is a good idea?
Cheers,
Joel
merci fredo!!!!!
Does anyone else think this is a good idea?Cheers,
Joel
hey Joel
i'm not quite convinced that your manual method is actually giving a mean curve.. i assume you're just connecting vertices then drawing segments through the midpoints.. i guess it sort of looks ok in the example you posted but it's not going to always work out that way.. see these two curves (well, one curve that's been copy/flipped)..try your manual method on those and you'll soon run into problems.
while it might be possible to make a plugin that can do an actual mean curve (or something close to it) in sketchup, i think it's going to be much more difficult then simply playing connect the dots. -
Hi Jeff
Thanks for replying. You're right; the manual method is simply "connecting the dots" as you say. It was the most logical way of illustrating my point. I think I see your point though; the manual method presumes a more regular spacing/matching of vertices between the two curves.
I suppose complex pairs of curves would have to be "rebuilt" (pardon the Rhino lingo; I've just finished working at a firm where Rhino is pretty much a religion: if it isn't built in Rhino it isn't worth looking at) to match each other's vertices before the manual method can be used.
I don't know the math behind creating mean curves, it was just an idea that popped into my head one day at work. Any other suggestions?
Cheers,
Joel
this is where sketchup really starts to breakdown as far as trying to make it nurbs like..
you can, in essence, rebuild a curve using this plugin.. if you right click on one of the curves in the mean.skp then go BZ- Convert To --> Polyline Divider (or polyline segmentor) then you'll be able to set the curve's vertices to an equal spacing (or to an evenly divided # of segments)..the problem is, you end up with too many vertices in the looser parts of the curve Or too few in the tighter areas. (at least in the example sketchup.. these commands come in very handy for many situations)..
re: mean curve in rhino.. personally, i don't use it or have a use for it (that i know of
)but one thing that sort of surprises me is that illustrator actually has a mean curve command that is seemingly superior to rhino's.. with illustrator, you can choose the amount of divisions (ie- 2 new mean curves in between the original ones).. you can do it with rhino by repeating the command as long as you want an odd amount of average curves but even then, it takes a lot longer than doing it once..but hey, i guess i'm going way off topic here
It's relatively easy to do it.
Actually, I have this type of function embedded in Curviloft
The only remaining part would be to build a decent GUI for selecting the curves.Fredo
