    SU 9 Wishlist
    436 Posts 99 Posters 151.9k Views 99 Watching
      Gjenio
      I'd just love to see in the next release two very time saving improvements:
      1. LIVE SOLID TOOLS:
        As I've already suggested here http://forums.sketchucation.com/viewtopic.php?f=15&t=22286&start=45 we need some option among the new released Solid Tools that let their operators (intersection, subtraction, union...) to be done "live", without losing component's identity. Somethig like what already happens with the cut opening's option within the components: As long as the component is stiched to a face it cuts a hole in it, then when the component is removed the hole disappear. Easy and terribly useful
      2. INTELLIGENT TAG SYSTEM:
        Expecially for architects, retriving tags from elements such doors, windows, rooms is extremaly important. Sketchup hasn't yet such a powerful tool. Yes, of course there is LO where you can finalize your drawing with all annotations and tags. But you have to do it manually and in some cases that means wasting tones of time. And if you then have to do some changes to your model? what happened to the already placed Layout tags? You need to remake and replace them completely. What about of an intelligent tag system instead? I love the dimensioning system of Sketchup. You pick the first point, then the second and your dymension automatically updates if a change in these two anchor points happens. Great! So you don't fear that if some change in the model occur you have to redimension your model entirely again. You focus only on the modeling! That's what a tag system should try to achive too. You pick a reference to the geometry in your model, then you freely place a tag linked with that reference and it updates automatically if any change should occur. This could be very useful for tagging doors and windows: you pick 2 reference points for the lenght and place a tag, then other 2 for the height and place the second tag. Than you make a component out of the window and the tags so that if the window changes, its tag changes automatically too. That would come in handy also for tagging window/floor surface ratios, voulume of rooms, length and surface of archs and vaults.
      One example can explain better of thousand words how this two ideas combined together could benefit in terms of time saving.
      Let's assume to create 5 windows in a wall. I create a window dynamic component with a couple of editable parameters such as height, lenght, number of frames and mullions... In the same component I put also the two tags for the lenght and the height of the window (as I explained above). Finally I assign to the component the propriety to "live" subtract solids. Than I copy the component 4x and that'all.
      Any change in my dynamic component would immediatly affect the tag system and the "dynamic" subtract system of the "Live solid tools".
      I made a video trying to explain better what I mean. In this movie in which I used the Gaieus trick of duble nested cutting components remains however the problem of creating a hole in the back face of the wall without having to explode the dynamic component and losing therefore its editable references. That could be solved introducing some kind of "Live solid tools"!
      [flash=853,560:3mpqavwd]http://www.youtube.com/v/K6go40GGl68&hd=1&fs=1[/flash:3mpqavwd]
      • utilerU Offline
        utiler
        Eugenio,
        You are on the same page as I!!! This is on top of my list of improvements that I will forward to Google for discussion. Live Boolean tools should be the obvious next step for Solid tools.....
        πŸ‘ πŸ‘ πŸ‘
        Just Curious...
          Aizen
          β˜€ hello everyone.
          I'm a user of SU & VFSU for many years. Recently, i had a problem with a VFSU rendering coz VFB wont come out after i enter the render button. They said due SU is a 2GB application (or something like that) so, its very often to had that kind of problem coz the memory limitation (or also something like that) πŸ˜„
          I only had this kind of problem when my polygon counts reach at 1 million or 2 millions. So, who should i refer to? SU team? VFSU team? Nowadays every client wanted a rendered perspective.
          So, my wishlist is :
          1. Should SU teams & VFSU teams sit together and workout something? Coz truly i dont know anything bout the limitation of the software, so i wont request something like 64bit, 32bit..i dont care, even if 1bit application can solved that problem, i'm ok with it. πŸ˜†
          2. A faster exporting process (still image, animation & 3D model). Sometime i had an issue when i'm exporting a PNG files at 3k pixel with shadows & no edges line, it took more than 15mins just to get it done. But when i try to view the image, its like being chopped somehow. πŸ˜•
          iZAN
          RizArcDesign
          • utilerU Offline
            utiler
            VFSU?
            Just Curious...
              VfSU = V-Ray for SketchUp
              @Aizen: with SU8M1 you can now use up to 4GB RAM if you have 64bit Windows and you have more than 4GB RAM.
              • utilerU Offline
                utiler
                @Thomas - πŸ‘
                Just Curious...
                • fuzzionF Offline
                  fuzzion
                  If I had only one wish, that would be to get
                  SU google HR department to hire Fredo,thom,TIG,Whaat
                  and perhaps a few more of our top plugin makers to
                  transform SU into something thrice as superior over 3dsmax.
                  β˜€
                  "Only the dead have seen the end of war" - Plato
                  • utilerU Offline
                    utiler
                    β˜€
                    You wouldn't be the first one to request that one, Josh. πŸ‘
                    Just Curious...
                    • jbacusJ Offline
                      jbacus
                      We are hiring Software Engineers in Boulder, if you'd like to apply:
                      "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
                      John Bacus
                      jbacus@sketchup.com
                      • Chris FullmerC Offline
                        Come on John, most of us are architects and 3d modelers (sound familiar? πŸ˜„ ) turned software programmers - a far cry from a "software engineer". Working for the Google SketchUp team would be a dream job, but I fear I would not be versatile enough.
                        Though it won't keep me from applying πŸ‘ πŸ˜„
                          I think I also lack some of the required skills (not to speak about written qualifications) namely
                          • BS, MS, or PhD in Computer Science or related technical discipline (or equivalent)
                          • Extensive programming experience C++ or Java.
                          • Several years of large systems software development experience, or client application development
                          • Working knowledge of development tools on Windows, Mac OS X and / or Unix/Linux
                          • A solid foundation in computer science, with strong competencies in data structures, algorithms, and software design
                          • Coding skills in Python or Javascript/AJAX, database design and SQL, and/or knowledge of TCP/IP and network programming are a plus
                          • Good knowledge of Web standards and protocols including Javascript, HTML, CSS, HTTP a plus
                            πŸ˜’
                            A Csaba said... the perfect job for me... except for one problem... I do not have any of the attributes [bar perhaps one] or the qualifications listed in the ad πŸ˜’
                            • mitcorbM Offline
                              mitcorb
                              I assume these are the qualifications for the Google job?
                              Where would knowledge of Python be used? I thought Ruby was the preferred tool?
                              • O Offline
                                otb designworks
                                Simple request: Please for all that is holy, why can't we arrange layers the way we want them instead of just alphabetically?
                                This has been driving me nuts since the beginning...
                                Cheers, Chuck
                                OTB Designworks is on Youtube
                                • fuzzionF Offline
                                  fuzzion
                                  πŸ’­ What I mean Jbacus, is that YOU should handpick some of our top plugin makers that show desire to innovate and propel by personally sending an Email to those that you think have talent. Remember, most of the Industries gifted programmers are either drop outs or self taught Geniuses πŸ˜‰
                                  I.e. Bill Gates,John Carmack, etc.
                                    davidheim1
                                    Solid Components that work with more than 2 components at once.
                                    daviod
                                      davidlouis
                                      I am trying to do some solar analysis animations on a building and have set up a view with a series of dates and times during the year.
                                      I now want to change the view in question but keep all the settings for dates and times but can't...
                                      I would thus like to see a function where one might be able to:
                                      1.Overide/update all scenes with current viewpoint (thus keeping date and time info as already set)
                                      2.Overide / update all date and time info for project scenes / views with a single set of settings so as to avoid having to switch through each one and update manually...
                                      If there is a way of doing the above.... please someone enlighten me.
                                      Dave
                                      • jbacusJ Offline
                                        jbacus
                                        For what it is worth, I don't have a Phd in CompSci either... I have an BArch from Cooper Union and an MArch from Rice University. The SketchUp team is populated by a wide range of folks with unusual backgrounds by Google standards– Lighting, structural and architectural engineers are much more common on our team than pure CompSci folks. No need to argue the merits of looking for talent outside the box to me.
                                        Historically, we have brought on gifted Ruby developers (remember Dynamic Components?) who came up with cool add-ons for SketchUp. We may do it again in the future if that is the most efficient way to launch new features that we think everyone will benefit from having in SketchUp.
                                        John Bacus
                                        jbacus@sketchup.com
                                          Dave
                                          Use Scene Manager and bulk-edit selected Scenes so certain aspects don't update...
                                          • jgbJ Offline
                                            jgb
                                            I've mentioned this before, elsewhere.....
                                            Make SU aware of extra mouse buttons.
                                            Wheels are now standard with side motion; SU is oblivious to that.
                                            My Logitech MX 600 has a total of 10 button/wheel actions.
                                            2 main buttons, wheel rotation, wheel down, wheel left/right, zoom in/out, plus 3 other buttons that I have programmed for various functions, such as double click and browser back.
                                            SU only recognizes 4, 2 main, wheel rotation and wheel down. It does recognize my double click (left) button, but only because the mouse sends it out as a double click.
                                            I have also made significant use of keyboard shortcuts, using almost all the keys my left hand can pick easily, but here again I am faced with an SU shortcoming.
                                            SU only recognizes Shift, Ctrl and Alt as extender buttons.
                                            There is also the Tab and the Windows keys that can be used as extenders, as they have no other function in SU.
                                            I would really like to be able to use some other extender key to duplicate the R,G & B arrow keys on the left side of the KB.
                                            jgb
                                            • 21
                                            • 22
                                            • 6 / 22
