    SU and Dual Monitors - Worth the Trouble?
    21 Posts 14 Posters 6.7k Views 14 Watching
    • hellnbakH
      hellnbak
      Well, I gave it a try, but quickly decided this would work a lot better with smaller monitors, and I don't like small monitors. With large monitors there's too much head turning and too far to go with the mouse. Just too distracting from the work. Not to mention the huge amount of desktop real estate eaten up. Well, now I know.
      Thanks for everyone's input.
        dtrarch
        hellnback
        Dual monitors are a must. ๐Ÿ‘
        I have a 26 inch for modeling and a 22 for other apps that are running and SU menus.
        Any of the items listed in the SU [Windows]from Model info to and including Instructor can be opened and dragged to the second monitor if it is setup as a "dual view" (nvidia)
        One can open and close as needed and both screen setups will stick on re-open of SU.
        Use the second screen full screen and you can also stick the menus at the top of the screen and they will stay put.
        Some will stack and others will just overlay.
        Just save as the default untitled.skp or better yet as your default template.
        Hope this helps with the real estate. ๐Ÿ‘
        dtr
        • T
          tim
          I use a 24" iMac and 20" second screen with no problems. I keep the tool palettes etc on the secondary screen, along with my various communications apps like iChat/skype/MSN etc. So basically, a 3520x1200 screen ๐Ÿ˜‰
          I'm hoping to upgrade to a 27" octo-core iMac + second 27" display later this year - ie 5120x1440 screen.
          • L
            liam887
            I use a 17" mac book pro connected to a 15" LCD screen to keep all my toolbars, shadow settings etc (I find the smaller screen size helps keep system resources down for the laptop)
            VISIT MY ONLINE GALLERY
            • P
              putnik
              I'm running Windows7 Pro, my card is Quadro 600, 2 monitors. I can't seem to run more than 1 instance of SketchUp (8 Pro). If I attempt to run a second instance, the first one crashes every time. Has anyone come across this issue?
              http://keshas.info
                That's very strange. I will frequently have three or four instances of SketchUp open at once. I'm running XP Pro but I would think Windows7 should be able to handle that, too. Have you looked at the computer's performance graph in the Task Manager (I assume that's still available in Windows 7) when you are running SketchUp and open the second session?
                • tpstigersT
                  tpstigers
                  I'm running Windows 7 Ultimate, and I've never had a problem running multiple instances of SketchUp (7 or 8).
                  And yes, Win7 still has the Task Manager, and it still allows you to get at it the easy way (Ctrl/Shift/Esc).
                  โ€œI have an existential map; it has 'you are here' written all over itโ€
                  • pmolsonP
                    pmolson
                    Do it.
                    Now!
                    p
                    • pmolsonP
                      pmolson
                      Do it.
                      Now!
                      p
                      • hellnbakH
                        hellnbak
                        I really can't justify having to use smaller monitors just to get this setup to work. I buy large monitors because I don't like small monitors, and having to force myself to look at two small monitors all day just to make a dual screen setup function is simply not worth it. To me.
                          So, HNB, here's just a FWIW. I made a screen shot of my SketchUp setup. This is on a 25" monitor. the drawing window is about 1600 pixels wide and 1015 high. I think there's plenty of room for drawing and for the stuff I've put on the side. I don't think you'll have a problem with that sort of layout. I rarely ever find any need for a wider view when I'm working in SketchUp. It's slightly wider (longer) than a standard sheet of paper which is usually what I need to fit my images to anyway.
                          http://farm5.static.flickr.com/4146/5437658896_07731e87a0_z.jpg
                          If you add a second screen, you can use it for references while you draw on your main screen.
                          • tpstigersT
                            tpstigers
                            I have a dual monitor setup - sort of. My primary monitor plugs into my main computer. My secondary monitor plugs into a four-channel KVM. My main computer uses one of the four channels, the other three go to other machines. While I will often use the secondary monitor as a reference, I usually do so through a separate machine (so as to conserve resources on my primary computer). As time has gone on, I have found that I rarely use my dual monitor setup in a 'true' fashion (both monitors driven by one machine).
                            At the end of the day, though, I feel that this is all just a matter of personal preference. Some people have a workflow that demands dual monitors. Some prefer to work with one monitor and multiple windows. I think the best idea is the one you explored earlier - try it out in a variety of ways and see which one works for you.
                              Anaardvark
                              I couldn't possibly go back to a single monitor again. Both at home and at work, I use a dual 24" monitor setup. 1920x1080 at work, 1920x1200 at home.
                              It allows you to full screen one app and use another thing such as a web browser on the 2nd. I can also drag my materials box and anything else over there so it's out of the way of my main window.
                              Only problem is now that when I use my laptop, I find it really hard to adjust back to the single screen.
                              404 Not Found
                              (img291.imageshack.us)
                                designerstuart
                                if you can't scroll all that way (!) back and forth between monitors...... sounds like you need to use shortcuts!
                                dual screens is waaaaay better (for me) i do it just the way you mention - one clear screen with just model and everything else in the other. oh and i have a keyboard and mouse on my desk. ๐Ÿ˜‰
                                • honoluludesktopH
                                  honoluludesktop
                                  My preference is a single 30" display with 2560x1600 resolution and 16:10 aspect ratio for clear images and exceptional multitasking.
                                  http://i.dell.com/images/global/products/monitors/monitors_highlights/monitor-dell-u3011-overview3.jpg
