    [Plugin] CleanUp
    974 Posts 217 Posters 981.9k Views 217 Watching
      dedmin
      • CAntonisC Offline
        CAntonis
        This is one of the best plugs ever! Great job and much appreciated!
        Thank you!
        • plot-parisP Offline
          plot-paris
          Thomthom, thats really perfect now! you made me a happy man!
            rv1974
            http://www.youtube.com/watch?v=RyUf7r_9yNs&feature=player_embedded
            Is this you Thom?
            Never thought the chill boosts the productivity so much 🙂
                Seems that I introduced a bug in 3.1.0 - the scope isn't properly selected. 😞
                Fixing...
                  Version 3.1.1
                  • Fixed bug where the current scope wasn't correctly pre-selected
                  • bagateloB Offline
                    bagatelo
                    Great. I loved. But Now sometimes I have code error:
                    C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;952;in `remove_materials'
                    C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;915;in `merge_similar_materials'
                    C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;477;in `cleanup!'
                    C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;420;in `show_cleanup_ui'
                    C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;419;in `call'
                    C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;160;in `initialize'
                    C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;155;in `call'
                    C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;143;in `close'
                    C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;143;in `initialize'
                    C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;131;in `call'
                    What is happening? Thanks thomthom for your efforts.
                      Can you reproduce that in 3.1.1? (if so can you repost the message so the line numbers match with the latest version?)
                      Also, it seems that part of that error message is missing...
                        And you mention it occurs some times - got a sample model where it always occurs?
                          Version 3.1.2
                          • Fixed missing operation wrappers.
                          • Fixed merge materials.
                          Recommended update!
                          • jim smithJ Offline
                            jim smith
                            Thanks for the update TT - I use this a lot! Excellent plugin, excellent improvements. 👍
                            "Out of clutter find simplicity,
                            from discord find harmony,
                            In the middle of difficulty lies opportunity"
                            Albert Einstein
                            • bagateloB Offline
                              bagatelo
                              I have updated to version 3.1.1 and no error show me, at this time.
                                3.1.2 is now the latest. 😉
                                • daleD Offline
                                  dale
                                  Your plugins always install and work flawlessly for me. Thank you again.
                                    DIEGO-RODRIGUEZ
                                    thom hello.
                                    I run this tool generates random lines.
                                    this may be a bug?
                                    after.skp
                                    before.skp
                                    • bagateloB Offline
                                      bagatelo
                                      @diego-rodriguez said:
                                      thom hello.
                                      this may be a bug?
                                      [attachment=0:27ta70jd]<!-- ia0 -->silla - test.jpg<!-- ia0 -->[/attachment:27ta70jd]
                                      Search for "erase lonely edges"
                                        Diego, why do you have the bottom edge of the table leg split as you do? See the attached image. The highlighted segments are welded and there's a separate line segment between the two along the bottom. Even after trying to fix those, I am getting the same lines you get so there's something odd going on.
                                          thom hello.
                                          this may be a bug?
                                          What settings did you use, please?
                                            I'm seeing this now. It's related to the Repair Broken Edges feature. Doesn't happen to all models. Seems to be related to Curves.
                                            Looking into it.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 48
                                            • 49
                                            • 12 / 49
