    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
      DIEGO-RODRIGUEZ
      as usual. excellent work. very professional.
      thank you very much
        @bagatelo said:
        @thomthom said:
        @bagatelo said:
        @thomthom said:
        @bagatelo said:
        Maybe we can run other older version of this fantastic plugin as well. Is it possible? Remeber: I love You!!!
        Why?
        Because of the window popping up?
        The old version has some flaws which is fixed in V3.
        Because the possibility to clean unneeded edges.
        That exists in CleanUp3.
        YES! I know it. But the problem is keyboard shortcuts. Maybe you can make possible to assign shortcuts for every option in the menu. The possible for set shortcut for unneeded edges and Merge identical materials can be great. Thank you.
        That's an interesting idea.
          Version 3.1.0
          • Added menu item for repeating last cleanup. (scope not remembered.)
          • Added menus for each cleanup sub-routine.
            dedmin
            • CAntonisC
              CAntonis
              This is one of the best plugs ever! Great job and much appreciated!
              Thank you!
              • plot-parisP
                plot-paris
                Thomthom, thats really perfect now! you made me a happy man!
                  rv1974
                  http://www.youtube.com/watch?v=RyUf7r_9yNs&feature=player_embedded
                  Is this you Thom?
                  Never thought the chill boosts the productivity so much 🙂
                      Seems that I introduced a bug in 3.1.0 - the scope isn't properly selected. 😞
                      Fixing...
                        Version 3.1.1
                        • Fixed bug where the current scope wasn't correctly pre-selected
                        • bagateloB
                          bagatelo
                          Great. I loved. But Now sometimes I have code error:
                          C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;952;in `remove_materials'
                          C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;915;in `merge_similar_materials'
                          C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;477;in `cleanup!'
                          C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;420;in `show_cleanup_ui'
                          C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;419;in `call'
                          C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;160;in `initialize'
                          C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;155;in `call'
                          C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;143;in `close'
                          C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;143;in `initialize'
                          C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;131;in `call'
                          What is happening? Thanks thomthom for your efforts.
                            Can you reproduce that in 3.1.1? (if so can you repost the message so the line numbers match with the latest version?)
                            Also, it seems that part of that error message is missing...
                              And you mention it occurs some times - got a sample model where it always occurs?
                                Version 3.1.2
                                • Fixed missing operation wrappers.
                                • Fixed merge materials.
                                Recommended update!
                                • jim smithJ
                                  jim smith
                                  Thanks for the update TT - I use this a lot! Excellent plugin, excellent improvements. 👍
                                  "Out of clutter find simplicity,
                                  from discord find harmony,
                                  In the middle of difficulty lies opportunity"
                                  Albert Einstein
                                  • bagateloB
                                    bagatelo
                                    I have updated to version 3.1.1 and no error show me, at this time.
                                      3.1.2 is now the latest. 😉
                                      • daleD
                                        dale
                                        Your plugins always install and work flawlessly for me. Thank you again.
                                          DIEGO-RODRIGUEZ
                                          thom hello.
                                          I run this tool generates random lines.
                                          this may be a bug?
                                          after.skp
                                          before.skp
                                          • bagateloB
                                            bagatelo
                                            @diego-rodriguez said:
                                            thom hello.
                                            this may be a bug?
                                            [attachment=0:27ta70jd]<!-- ia0 -->silla - test.jpg<!-- ia0 -->[/attachment:27ta70jd]
                                            Search for "erase lonely edges"
                                            • 11
                                            • 12
                                            • 13
                                            • 48
                                            • 49
                                            • 11 / 49
