    [Plugin] CleanUp
    974 Posts 217 Posters 1.1m Views 217 Watching
      Can you reproduce that in 3.1.1? (if so can you repost the message so the line numbers match with the latest version?)
      Also, it seems that part of that error message is missing...
        And you mention it occurs some times - got a sample model where it always occurs?
          Version 3.1.2
          • Fixed missing operation wrappers.
          • Fixed merge materials.
          Recommended update!
          • jim smithJ Offline
            jim smith
            Thanks for the update TT - I use this a lot! Excellent plugin, excellent improvements. 👍
            "Out of clutter find simplicity,
            from discord find harmony,
            In the middle of difficulty lies opportunity"
            Albert Einstein
            • bagateloB Offline
              bagatelo
              I have updated to version 3.1.1 and no error show me, at this time.
                3.1.2 is now the latest. 😉
                • daleD Offline
                  dale
                  Your plugins always install and work flawlessly for me. Thank you again.
                    DIEGO-RODRIGUEZ
                    thom hello.
                    I run this tool generates random lines.
                    this may be a bug?
                    after.skp
                    before.skp
                    • bagateloB Offline
                      bagatelo
                      @diego-rodriguez said:
                      thom hello.
                      this may be a bug?
                      [attachment=0:27ta70jd]<!-- ia0 -->silla - test.jpg<!-- ia0 -->[/attachment:27ta70jd]
                      Search for "erase lonely edges"
                        Diego, why do you have the bottom edge of the table leg split as you do? See the attached image. The highlighted segments are welded and there's a separate line segment between the two along the bottom. Even after trying to fix those, I am getting the same lines you get so there's something odd going on.
                          thom hello.
                          this may be a bug?
                          What settings did you use, please?
                            I'm seeing this now. It's related to the Repair Broken Edges feature. Doesn't happen to all models. Seems to be related to Curves.
                            Looking into it.
                              Important!
                              Update TT_Lib2 to version 2.5.2 which fixes a bug affecting repair edges.
                                That was a speedy fix, Thomas. Thank you.
                                • bagateloB Offline
                                  bagatelo
                                  I thought about the possibility to resize textures that are too large, in the scene, for some maximum given value. Automatically.
                                    DIEGO-RODRIGUEZ
                                    Thank you all for the answers.
                                    thom hello.
                                    thank you very much for the update.
                                    you are right, the problem is with the option to "repair split edges. "
                                    Now it works better, but still generates some lines.
                                    Surely the problem is a geometry "badly drawn" (edges overlapping and converson to polyline tool to fredo)
                                    Greetings
                                      Yea I noticed there are still some issues. I'm working on a new patch.
                                        Might be possible with SU8M1 to make such a thing. I'll put it on the lsit to investigate. Though it won't be soon. I need to get some other projects out of the way.
                                          Important!
                                          Update TT_Lib2 to version 2.5.3 which re-fixes a bug affecting repair edges.
                                            Thank you Thomas. I just ran it on that chair and it looks like it worked just fin.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 48
                                            • 49
                                            • 12 / 49
