    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
    • bagateloB
      bagatelo
      @thomthom said:
      @bagatelo said:
      @thomthom said:
      @bagatelo said:
      Maybe we can run other older version of this fantastic plugin as well. Is it possible? Remeber: I love You!!!
      Why?
      Because of the window popping up?
      The old version has some flaws which is fixed in V3.
      Because the possibility to clean unneeded edges.
      That exists in CleanUp3.
      YES! I know it. But the problem is keyboard shortcuts. Maybe you can make possible to assign shortcuts for every option in the menu. The possible for set shortcut for unneeded edges and Merge identical materials can be great. Thank you.
        DIEGO-RODRIGUEZ
        as usual. excellent work. very professional.
        thank you very much
          @bagatelo said:
          @thomthom said:
          @bagatelo said:
          @thomthom said:
          Why?
          That's an interesting idea.
            Version 3.1.0
            • Added menu item for repeating last cleanup. (scope not remembered.)
            • Added menus for each cleanup sub-routine.
              dedmin
              • CAntonisC
                CAntonis
                This is one of the best plugs ever! Great job and much appreciated!
                Thank you!
                • plot-parisP
                  plot-paris
                  Thomthom, thats really perfect now! you made me a happy man!
                    rv1974
                    http://www.youtube.com/watch?v=RyUf7r_9yNs&feature=player_embedded
                    Is this you Thom?
                    Never thought the chill boosts the productivity so much 🙂
                        Seems that I introduced a bug in 3.1.0 - the scope isn't properly selected. 😞
                        Fixing...
                          Version 3.1.1
                          • Fixed bug where the current scope wasn't correctly pre-selected
                          • bagateloB
                            bagatelo
                            Great. I loved. But Now sometimes I have code error:
                            C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;952;in `remove_materials'
                            C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;915;in `merge_similar_materials'
                            C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;477;in `cleanup!'
                            C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;420;in `show_cleanup_ui'
                            C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;419;in `call'
                            C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;160;in `initialize'
                            C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;155;in `call'
                            C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;143;in `close'
                            C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;143;in `initialize'
                            C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;131;in `call'
                            What is happening? Thanks thomthom for your efforts.
                              Can you reproduce that in 3.1.1? (if so can you repost the message so the line numbers match with the latest version?)
                              Also, it seems that part of that error message is missing...
                                And you mention it occurs some times - got a sample model where it always occurs?
                                  Version 3.1.2
                                  • Fixed missing operation wrappers.
                                  • Fixed merge materials.
                                  Recommended update!
                                  • jim smithJ
                                    jim smith
                                    Thanks for the update TT - I use this a lot! Excellent plugin, excellent improvements. 👍
                                    "Out of clutter find simplicity,
                                    from discord find harmony,
                                    In the middle of difficulty lies opportunity"
                                    Albert Einstein
                                    • bagateloB
                                      bagatelo
                                      I have updated to version 3.1.1 and no error show me, at this time.
                                        3.1.2 is now the latest. 😉
                                        • daleD
                                          dale
                                          Your plugins always install and work flawlessly for me. Thank you again.
                                            DIEGO-RODRIGUEZ
                                            thom hello.
                                            I run this tool generates random lines.
                                            this may be a bug?
                                            after.skp
                                            before.skp
                                            • 11
                                            • 12
                                            • 13
                                            • 48
                                            • 49
                                            • 11 / 49
