    [Plugin] CleanUp
    974 Posts 217 Posters 1.2m Views 217 Watching
      Version 3.1.0
      • Added menu item for repeating last cleanup. (scope not remembered.)
      • Added menus for each cleanup sub-routine.
        dedmin
        • CAntonisC Offline
          CAntonis
          This is one of the best plugs ever! Great job and much appreciated!
          Thank you!
          • plot-parisP Offline
            plot-paris
            Thomthom, thats really perfect now! you made me a happy man!
              rv1974
              http://www.youtube.com/watch?v=RyUf7r_9yNs&feature=player_embedded
              Is this you Thom?
              Never thought the chill boosts the productivity so much 🙂
                  Seems that I introduced a bug in 3.1.0 - the scope isn't properly selected. 😞
                  Fixing...
                    Version 3.1.1
                    • Fixed bug where the current scope wasn't correctly pre-selected
                    • bagateloB Offline
                      bagatelo
                      Great. I loved. But Now sometimes I have code error:
                      C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;952;in `remove_materials'
                      C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;915;in `merge_similar_materials'
                      C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;477;in `cleanup!'
                      C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;420;in `show_cleanup_ui'
                      C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;419;in `call'
                      C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;160;in `initialize'
                      C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;155;in `call'
                      C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;143;in `close'
                      C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;143;in `initialize'
                      C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;131;in `call'
                      What is happening? Thanks thomthom for your efforts.
                        Can you reproduce that in 3.1.1? (if so can you repost the message so the line numbers match with the latest version?)
                        Also, it seems that part of that error message is missing...
                          And you mention it occurs some times - got a sample model where it always occurs?
                            Version 3.1.2
                            • Fixed missing operation wrappers.
                            • Fixed merge materials.
                            Recommended update!
                            • jim smithJ Offline
                              jim smith
                              Thanks for the update TT - I use this a lot! Excellent plugin, excellent improvements. 👍
                              "Out of clutter find simplicity,
                              from discord find harmony,
                              In the middle of difficulty lies opportunity"
                              Albert Einstein
                              • bagateloB Offline
                                bagatelo
                                I have updated to version 3.1.1 and no error show me, at this time.
                                  3.1.2 is now the latest. 😉
                                  • daleD Offline
                                    dale
                                    Your plugins always install and work flawlessly for me. Thank you again.
                                      DIEGO-RODRIGUEZ
                                      thom hello.
                                      I run this tool generates random lines.
                                      this may be a bug?
                                      after.skp
                                      before.skp
                                      • bagateloB Offline
                                        bagatelo
                                        @diego-rodriguez said:
                                        thom hello.
                                        this may be a bug?
                                        [attachment=0:27ta70jd]<!-- ia0 -->silla - test.jpg<!-- ia0 -->[/attachment:27ta70jd]
                                        Search for "erase lonely edges"
                                          Diego, why do you have the bottom edge of the table leg split as you do? See the attached image. The highlighted segments are welded and there's a separate line segment between the two along the bottom. Even after trying to fix those, I am getting the same lines you get so there's something odd going on.
                                            thom hello.
                                            this may be a bug?
                                            What settings did you use, please?
                                            • 11
                                            • 12
                                            • 13
                                            • 48
                                            • 49
                                            • 11 / 49
