    SU 9 Wishlist
    436 Posts 99 Posters 125.1k Views 99 Watching
      kydbmaster
      @tfdesign said:
      @serge.n said:
      Which announcements?
      This one.
      But I guess being a Windows user, you probably would have missed that? ๐Ÿ˜„
      Autodesk big announcement huh? That is not so big. They have already abandoned that platform once. And there would have to be a lot of 3rd party stuff for AutoCAD make the jump to the Mac as well for it to become a serious platform. From the reports I have seen it is buggy.
      I have a better Idea... Add the necessary tools to SU layout so we don't need AutoCad in the first place! It is time for a new Sheriff (Google) to come to town (CAD world)! Anyone that has had to deal with the likes of AutoDesk should be able to confirm this!
      64 bit would be nice
      Support for the complete .rpc file format would be even better though!
        kydbmaster
        @serge.n said:
        Yes, I did. Well I'd rather write that I didn't realized that's such a big achievement. And what about Revit? Indeed, I imagine Autodesk still have Autocad on Windows due to legacy issue. If they could they would have made everybody switch for Revit or Inventor.
        Yeah Autodesk certainly desires everyone one to switch to Revit and Civil3d. They have no Intellicad competition there and the price is double that of AutoCAD. From a Landscape Architects point of view that idea is a huge waste of money. Especially since Revit has no way to deal with curbs! I think Autodesk has been sniff'n a little to much of it's own marketing poop!
          davidlouis
          Its simple for me....
          incorporate some of the wonderful plugins developed in this forum as 'standard'... then pay those developers a huge lump of cash or perhaps give them some google shares for making sketchup better... ๐Ÿ˜† and thats it.
          There are so many good ideas floating around here that I often wonder why the 'collective' of plugin writers haven't got together to develop their own system/software... it could be good.
          Dave
            Catmando
            Anyone else wishing for an easy way to bisect angles? ๐Ÿ˜›
            • jeff hammondJ Offline
              there's already a sorta easy way to to that.
              what's you're current method?
              (just in case your current method is the same one i'm thinking and you're just wanting an even easier method ๐Ÿ˜„ )
                Make a guide-line through one line...
                Select the guide-line and Rotate+Ctrl to rotate-copy it about the apex point [intersection of two guides, if needed you should have made both] from its location back to the second line - immediately type /2 and you have bisected the angle [/3 in thirds etc...][attachment=0:n9n4l6m9]<!-- ia0 -->Capture.png<!-- ia0 -->[/attachment:n9n4l6m9]
                  Yeah, same technique as I was thinking though I generally wouldn't use a guideline. Just select one of the lines forming the angle then copy/rotate it to the other. Then /2
                    Fine if you want to repeat the line at half angle.
                    My method returns a guide that's the bisector, for more general use... ๐Ÿ˜‰
                    Depends what he wants to do - either one is pretty simple - I find it hard to image a simpler way... I could write a script... activate tool, pick apex, pick first line, pick second line etc... as many picks as the rotate-copy method ? with less options for what you are getting... ๐Ÿ˜’
                      @escapeartist said:
                      64 bit support
                      Have you ever had SU run out of memory? (just pure SketchUp, no render engine plugin.)
                      @escapeartist said:
                      Dare I beat the multi-core horse one more time?
                      Why not just ask for better performance? That's what you want, right? Instead of asking for a particular technical implementation that can't be applied to most tasks. (most 3d apps that boost this feature refer to the render engine they bundle.)
                        dacad
                        Like exporting giant images, or heavy calculations operations (intersect) on giant models, or maybe for a better platform for developers to program for?
                        Like multipe frame export in movie sequences, or any calculation that can be paralelized (like multiples modeling operations - multiples faces push pull, and doing better modeling tools in the process...and i've just make this up...can't imagine what a paid professional could do) or maybe (again) for a better platform for developers to program for? (since right now users seem more dependent on plugins developers like you ๐Ÿ˜‰ than google)
                        But right now i would trade any of that for real UV/Maping tools... ๐Ÿ˜ž
                          You've run out of memory while intersecting? You've seen Sketchup.exe reach 2GB+? (or in the case of SU8M1 under 64bit OSX, over 4GB?)
                          How does 64bit make it a better platform?
                          I gives you more memory to play with - but which plugins has had that problem?
                          Fair enough, this has been an issue where memory seemed to be an issue. But in M1 they made SU LAA and in addition they changed the method they used to export the images. And now you can export larger images. But, this is the clue, how are you use 64bit is the solution? Maybe a different algorithm in whatever you have problems with will work much better than just adding more RAM.
                          For developers it's better to hear the feature, end result of what the users want - not to be just told to do a technical implementation without knowing what the user expects from it.
                          So many times when people have asked for 64bit they appear to be under the impression that 64bit makes everything run faster. While in reality it might as well just make things slower.
                          You see, there's the core of it. That's what you want faster. Straight to the point instead of just an ambiguous request for multicore.
                          You're sure this can be parallelized because...?
                          I'm poking at this not to be mean, but because 64bit and mulitcore request is always just a cloak for something else - something more concrete where people has just made the assumption that 64bit or multicore is the solution. And as long as one clings to these assumptions and keep on hoping that they'll be there in the next release one only puts oneself up for disappointment.
                          Concrete requests like "Faster exports", "Faster explode", "Faster intersect", "Being able to export larger images" is so much more relevant and useful to the developers. Let them take care of the technical.
                          • EscapeArtistE Offline
                            EscapeArtist
                            @thomthom said:
                            @escapeartist said:
                            64 bit support
                            Yes. I've had occasions where implementing a plugin has consumed 3+ GB of my 4 GB system. SU crashes or I have to kill the process and restart what I was doing.
                            I'd be happy with that too, but with most cores in PCs these days leveling off at the ~3 GHz range and the status quo seems to be implementing more cores instead of faster ones I don't know how much improvement can be obtained on a single 3 or 4 GHz core. If it can be done, great! I'm all for it.
                            Please don't take this as me knocking SU or any of the devs, I've used everything from Maya to 3DSM and lots inbetween, this is by far the best and easiest to learn modeling app out there, and with all the free plugins there is simply no comparison. While I have no desire to turn SU into Maya, I think that would defeat the purpose behind SU, I keep wondering if there aren't ways to provide some similar functions and performance as these higher end application while maintaining the spirit and intent behind SU.
                              EscapeArtist
                              I'll keep it simple and post my wishes:
                              Advanced UV Tools and mapping. (sooo important)
                              64 bit support
                              Support higher polycount
                              Consider working with the plugin devs here on the forums to integrate some of them and make it seamless.
                              EDIT: Add tools to better perform organic modeling (includes higher polycount). I don't necessarily mean NURBS, but any tools and performance enhancement to do this would be great.
                              Support quad modeling instead of tri based as a system setting. Better for animation and I personally find it easier to model organically and UV map.
                                Render plugin or normal SketchUp plugin tool?
                                  dacad
                                  @thomthom said:
                                  I don't think you're seeing the big picture thomthom. big pictures, movie exports they can use multicore/64bis, but if that something that it's in the platorm and developers can use maybe instead of big pictures there could be a plugin that would handle big pictures for textures, with real time editiing and painting with baking them in the texture map in the 3D model at the end, and instead of movies maybe a plugin for better animation that could then export the movie with more options at the codecs, or maybe a basic sculpt tools suite without the lag in the brushs that the current plugins suffer from...And the list could go on.
                                  And it seems everything around SK goes by workarounds...yes there maybe be a work around for exporting larger images (like exporting partial images and put them together after) but you will allways reach a point where that workaround brakes, a pixel is info and info takes memory and like it or not you'll need memory in the end. Workaround for texturing, workaround for shadows (thank god no more of that), work around for modeling, hell we even have workarounds for toolbars! Isn't it about time we got something a litle more professional?
                                  And Btw why does render engines plugins don't count? because the blame is from developers that should all build everything a studio apart? does that count for physics engines, fur and texture editing or baking softwares? we brag that sk is great because we can add plugins as we like but then we put others apart...
                                  Oh and i'm no programer but by following logic, if we use multicore to calculate intersections in lines (rays) from point A (light) to a point B (objects) to get a shape in the end (shadow) i think that logic can be aplied in intersecting lines in 3D models...(keep in mind i'm no programer so this could be completly wrong, but i think i remember something about luxology using multicore in intersect...)
                                    EscapeArtist
                                    I have yet to give up on a render exporter, they do consume memory like crazy though. As for "normal", do you mean stock or community created? I've had soap bubble, intersect and cleanup and a fw Of course, this occurrs on complex scenes and models.
                                    • jgbJ Offline
                                      jgb
                                      Here's one!
                                      Maybe ThomThom (or somebody) has a tool for it, but I haven't seen it.
                                      Make the "Select" tool a bit more selective; in optionally, selecting faces and edges that are only currently VISIBLE. No elements you cannot see, like objects hidden behind what you select, or the back side of the object.
                                      Maybe use the ALT key to force the restricted select.
                                      Example; suppose you have a sphere and you need to select a bunch of faces. Right now you have to hunt and pick each one. If you use the sweeping select function, it will select the faces & edges you see and want, as well as the faces & edges on the back side you do not want. Then you have to hunt and pick those back side face & edge selections to de-select them.
                                      With an "ALT-Select" it would only select the visible front faces & edges.
                                      jgb
                                        hmm... you've had CleanUp run out of memory? How large models are we talking about here?
                                        How much memory did SU consume before starting cleanup? How much did it consume while crashing?
                                        (I wonder if it's CleanUp holding too much in cache while working, or if it's SU's undo stack eating up the memory. If it's the Undo stack then there's nothing I can do, but if it's CleanUp usage of variables, then I might be able to do something. But I'd have to be able to reproduce it.)
                                          EscapeArtist
                                          Ah, wish I could help you out by handing you the model, but it's been a long while since I had the issue so I don't remember which model it was. Probably something with multiple surfaces using SD&S or some ivy. It was definitely a large/high poly model though.
                                            EscapeArtist
                                            @jgb said:
                                            Here's one!
                                            Make the "Select" tool a bit more selective; in optionally, selecting faces and edges that are only currently VISIBLE. ...
                                            That's backface culling. Very useful, and I agree. I've lost count of the occasions where I've accidentally selected something behind the area I was working on, missed deselecting it and wound up deleting or otherwise nerfing my model. Sometimes if I'm lucky I'll be able to have caught it while it's undo-able, sometimes I wind up rebuilding a lot of my model. Somewhere I think I recall seeing a backface culling plugin, though...
                                            • 21
                                            • 22
                                            • 5 / 22
