    [Tutorial > Texturing] Texturing an arch - #2
    87 Posts 18 Posters 34.3k Views 18 Watching
      So how is it going? Let's see some interesting results (I always make boring vaults only although now there is also a sugar cane I made this way)
        dominion
        hohum not working, done it all but when i click restore uv it does nothing at all 😞
          Have you got the original (not-yet-bent) shape?
            dominion
            yea got it fine looks exactly as in your tut
              You mean it looks like the one in the tut before you make the bend and the UV restore or you mean that you could do it finally?
                dominion
                i can do the bend its just the uv restore that does not work
                  If you open the Ruby Console - does it give you an error?
                  If not, any chance you can do a video capture`?
                    And any chance you can share the file, too? Beforeit's bent...
                      +1
                      • O Offline
                        Odlanier
                        This is an old issue:
                        I read long time ago about the way to change the "avatar" (male figure in the SU default template).
                        I barley remember that you can use your own pic for this.
                        Q. After I build an avatar of myself, how can I make it face the camera all the time?
                        Thanks for your help.
                        Odlanier
                        We have only one Earth, Our children maybe just a half, theirs perhaps none; do something for our planet.
                        • O Offline
                          Odlanier
                          Maybe Gaieus knows about this,since he's been working on clay bricks, and tiles for long.
                          There was an hexagonal clay floor tile in SU 6 very pretty and very realistic.
                          After I installed SU7 it went missing and instead a white hexagonal tile now appears.
                          I tried editing it to give it the natural, warm and lovely color and texture it use ti have,but it does not come out so:
                          when you select a reddish, clayey color it comes out with cherry-red spots and yellowish tint.
                          Is there a way to recover that lovely hexagonal clay tile?
                          Thanks fellows,
                          • massimoM Offline
                            massimo Moderator
                            Maybe this one? Put it in your SU's materials-->tile folder. 😉
                            Tile_Hexagon_Beige.skm
                              ...After I build an avatar of myself, how can I make it face the camera all the time?...
                              Hi Reinaldo,
                              See below video for example.
                              YouTube - Creating a Face-me component in SketchUp
                              [flash=480,385:2k210aps]http://www.youtube.com/v/VvI6A7Njw4k?fs=1&hl=en_US[/flash:2k210aps]
                              • GarethG Offline
                                Gareth
                                thanks for the Tutorial...
                                ...i am trying it out.....but have a question or two...
                                1. When you say Subdivide, do you mean Divide, as in Edge Divide...??....or is there something else i should be aware of..??
                                2. Do you Group the column at some point along the way...??....if so at what step..??
                                Thanks in advance,
                                Gareth
                                  No, by subdividing I only meant that I copied the base rectangle along the (then still straight) "column". Otherwise Fredoscale cannot "bend" it. You make as many segments as you wish to eventually have in your arch - that's all.
                                  And there is no need to group - Fredoscale will (at least temporarily?) group the whole thing. But you can group it of course (especially when working in an environment with other geometry).
                                  • O Offline
                                    Odlanier
                                    Thanks Gaieus,
                                    I almost didn't recognize you with this new avatar.
                                    Cheers!
                                      My eyes are the same!
                                      • GarethG Offline
                                        Gareth
                                        ahaaaaa.....thanks Gaieus......i get it now...!! 👍
                                          Pherim
                                          Cool tutorial, it also works for waving flags. I also use FredoScale for bending it in several directions and then apply the UV toolkit and it restores the texture correctly! Thank you very much!
                                            Yes, exactly. Waving flags - or wind blown curtains (that I also used it for) - anything. Just make sure to triangulate your faces in those cases before the transformation (so that there are no new faces created while autofolding quads)
                                            • 3 / 5
