    [Tutorial > Texturing] Texturing an arch - #2
    87 Posts 18 Posters 42.7k Views 18 Watching
    • GaieusG
      You mean it looks like the one in the tut before you make the bend and the UV restore or you mean that you could do it finally?
        dominion
        i can do the bend its just the uv restore that does not work
          If you open the Ruby Console - does it give you an error?
          If not, any chance you can do a video capture`?
          • GaieusG
            And any chance you can share the file, too? Beforeit's bent...
              +1
              • O
                Odlanier
                This is an old issue:
                I read long time ago about the way to change the "avatar" (male figure in the SU default template).
                I barley remember that you can use your own pic for this.
                Q. After I build an avatar of myself, how can I make it face the camera all the time?
                Thanks for your help.
                Odlanier
                We have only one Earth, Our children maybe just a half, theirs perhaps none; do something for our planet.
                • O
                  Odlanier
                  Maybe Gaieus knows about this,since he's been working on clay bricks, and tiles for long.
                  There was an hexagonal clay floor tile in SU 6 very pretty and very realistic.
                  After I installed SU7 it went missing and instead a white hexagonal tile now appears.
                  I tried editing it to give it the natural, warm and lovely color and texture it use ti have,but it does not come out so:
                  when you select a reddish, clayey color it comes out with cherry-red spots and yellowish tint.
                  Is there a way to recover that lovely hexagonal clay tile?
                  Thanks fellows,
                  • massimoM
                    massimo Moderator
                    Maybe this one? Put it in your SU's materials-->tile folder. 😉
                    Tile_Hexagon_Beige.skm
                    • GaieusG
                      ...After I build an avatar of myself, how can I make it face the camera all the time?...
                      Hi Reinaldo,
                      See below video for example.
                      YouTube - Creating a Face-me component in SketchUp
                      [flash=480,385:2k210aps]http://www.youtube.com/v/VvI6A7Njw4k?fs=1&hl=en_US[/flash:2k210aps]
                      • GarethG
                        Gareth
                        thanks for the Tutorial...
                        ...i am trying it out.....but have a question or two...
                        1. When you say Subdivide, do you mean Divide, as in Edge Divide...??....or is there something else i should be aware of..??
                        2. Do you Group the column at some point along the way...??....if so at what step..??
                        Thanks in advance,
                        Gareth
                        • GaieusG
                          No, by subdividing I only meant that I copied the base rectangle along the (then still straight) "column". Otherwise Fredoscale cannot "bend" it. You make as many segments as you wish to eventually have in your arch - that's all.
                          And there is no need to group - Fredoscale will (at least temporarily?) group the whole thing. But you can group it of course (especially when working in an environment with other geometry).
                          • O
                            Odlanier
                            Thanks Gaieus,
                            I almost didn't recognize you with this new avatar.
                            Cheers!
                            • GaieusG
                              My eyes are the same!
                              • GarethG
                                Gareth
                                ahaaaaa.....thanks Gaieus......i get it now...!! 👍
                                • P
                                  Pherim
                                  Cool tutorial, it also works for waving flags. I also use FredoScale for bending it in several directions and then apply the UV toolkit and it restores the texture correctly! Thank you very much!
                                  • GaieusG
                                    Yes, exactly. Waving flags - or wind blown curtains (that I also used it for) - anything. Just make sure to triangulate your faces in those cases before the transformation (so that there are no new faces created while autofolding quads)
                                    • leedeeteeL
                                      leedeetee
                                      Hey Gai,
                                      Great tutorial (and great plugin). This may be a silly question, but does this technique work when you want to apply bump maps for rendering, do you know?
                                      Thanks.
                                      • charly2008C
                                        charly2008
                                        Hi Gaieus,
                                        after reading this thread, I played again with the UV tool "Lithunwrap (FREE). I have now figured a little bit out how to adjust the model to a texture. Basically, it's very simple at least for simple surfaces. I made a arc face with Shape Bender and applied a brick texture. Then exported the model from Skettchup as a 3ds file (Options: Preseving texture coordinates).
                                        You have to rotate all faces horizontally, aftterwards move the vertices to close the gaps between the faces. This us not a tutorial but only the first steps with this tool. My result is not yet perfect. if I am better familiar with it, I will describe in more detail. You should give it a try.
                                        Charly
                                        • GaieusG
                                          Well, at least it is promising.
                                          Obviously the more segments you are working with, the smoother the UV mapping wil be (I would place those bricks vertically though).
                                          There are all these nice but essentially 3rd party tools (including plugins) for SU now but I ma sure the ultimate solution would be something natively built in.
                                          Yes, in the first post I even mentioned Twilight and Thea. The renderer uses the UV mapping derived from the diffuse map to apply it on the bump / other map(s)
                                          • C
                                            constell
                                            Very good.
                                            thanks.
                                            • 2 / 5
