    [Tutorial > Texturing] Texturing an arch - #2
    87 Posts 18 Posters 40.5k Views 18 Watching
      dominion
      hohum not working, done it all but when i click restore uv it does nothing at all 😞
        Have you got the original (not-yet-bent) shape?
          dominion
          yea got it fine looks exactly as in your tut
            You mean it looks like the one in the tut before you make the bend and the UV restore or you mean that you could do it finally?
              dominion
              i can do the bend its just the uv restore that does not work
                If you open the Ruby Console - does it give you an error?
                If not, any chance you can do a video capture`?
                  And any chance you can share the file, too? Beforeit's bent...
                    +1
                    • O Offline
                      Odlanier
                      This is an old issue:
                      I read long time ago about the way to change the "avatar" (male figure in the SU default template).
                      I barley remember that you can use your own pic for this.
                      Q. After I build an avatar of myself, how can I make it face the camera all the time?
                      Thanks for your help.
                      Odlanier
                      We have only one Earth, Our children maybe just a half, theirs perhaps none; do something for our planet.
                      • O Offline
                        Odlanier
                        Maybe Gaieus knows about this,since he's been working on clay bricks, and tiles for long.
                        There was an hexagonal clay floor tile in SU 6 very pretty and very realistic.
                        After I installed SU7 it went missing and instead a white hexagonal tile now appears.
                        I tried editing it to give it the natural, warm and lovely color and texture it use ti have,but it does not come out so:
                        when you select a reddish, clayey color it comes out with cherry-red spots and yellowish tint.
                        Is there a way to recover that lovely hexagonal clay tile?
                        Thanks fellows,
                        • massimoM Offline
                          massimo Moderator
                          Maybe this one? Put it in your SU's materials-->tile folder. 😉
                          Tile_Hexagon_Beige.skm
                            ...After I build an avatar of myself, how can I make it face the camera all the time?...
                            Hi Reinaldo,
                            See below video for example.
                            YouTube - Creating a Face-me component in SketchUp
                            [flash=480,385:2k210aps]http://www.youtube.com/v/VvI6A7Njw4k?fs=1&hl=en_US[/flash:2k210aps]
                            • GarethG Offline
                              Gareth
                              thanks for the Tutorial...
                              ...i am trying it out.....but have a question or two...
                              1. When you say Subdivide, do you mean Divide, as in Edge Divide...??....or is there something else i should be aware of..??
                              2. Do you Group the column at some point along the way...??....if so at what step..??
                              Thanks in advance,
                              Gareth
                                No, by subdividing I only meant that I copied the base rectangle along the (then still straight) "column". Otherwise Fredoscale cannot "bend" it. You make as many segments as you wish to eventually have in your arch - that's all.
                                And there is no need to group - Fredoscale will (at least temporarily?) group the whole thing. But you can group it of course (especially when working in an environment with other geometry).
                                • O Offline
                                  Odlanier
                                  Thanks Gaieus,
                                  I almost didn't recognize you with this new avatar.
                                  Cheers!
                                    My eyes are the same!
                                    • GarethG Offline
                                      Gareth
                                      ahaaaaa.....thanks Gaieus......i get it now...!! 👍
                                        Pherim
                                        Cool tutorial, it also works for waving flags. I also use FredoScale for bending it in several directions and then apply the UV toolkit and it restores the texture correctly! Thank you very much!
                                          Yes, exactly. Waving flags - or wind blown curtains (that I also used it for) - anything. Just make sure to triangulate your faces in those cases before the transformation (so that there are no new faces created while autofolding quads)
                                          • leedeeteeL Offline
                                            leedeetee
                                            Hey Gai,
                                            Great tutorial (and great plugin). This may be a silly question, but does this technique work when you want to apply bump maps for rendering, do you know?
                                            Thanks.
                                            • 2 / 5
