    [Tutorial > Texturing] Texturing an arch - #2
    87 Posts 18 Posters 40.5k Views 18 Watching
    • massimoM Offline
      massimo Moderator
      So Gai now we are waiting for a model of this... 😆
        Ah, Bernini... I have not always liked that deep Baroque but nowadays I am fine with it...
        • massimoM Offline
          massimo Moderator
          Yeah, I always preferred Borromini (who also worked a bit at that baldaquin anyway). 😉
            I pitty the brick builder. 😄
              dominion
              Sorry to be dumb but how do you subdivide? is it a plugin?
                I just copied the bottom edges along with a linear array (Ctrl+ )
                  dominion
                  er if i do that it creates faces for each section of the texture, your 2nd image shows it as one face and your first shows dotted lines for the divide my has sild edges?
                    Yes, I softened those edges so that when I turn off hidden geometry (which you can see in the first image as dotted), I can select the whole surface as one. If you select all after the array operation and right click > soften edges, check the "soften coplanar edges" box at the bottom right of the dialog.
                      dominion
                      Ah I get it thanks
                        So how is it going? Let's see some interesting results (I always make boring vaults only although now there is also a sugar cane I made this way)
                          dominion
                          hohum not working, done it all but when i click restore uv it does nothing at all 😞
                            Have you got the original (not-yet-bent) shape?
                              dominion
                              yea got it fine looks exactly as in your tut
                                You mean it looks like the one in the tut before you make the bend and the UV restore or you mean that you could do it finally?
                                  dominion
                                  i can do the bend its just the uv restore that does not work
                                    If you open the Ruby Console - does it give you an error?
                                    If not, any chance you can do a video capture`?
                                      And any chance you can share the file, too? Beforeit's bent...
                                        +1
                                        • O Offline
                                          Odlanier
                                          This is an old issue:
                                          I read long time ago about the way to change the "avatar" (male figure in the SU default template).
                                          I barley remember that you can use your own pic for this.
                                          Q. After I build an avatar of myself, how can I make it face the camera all the time?
                                          Thanks for your help.
                                          Odlanier
                                          We have only one Earth, Our children maybe just a half, theirs perhaps none; do something for our planet.
                                          • O Offline
                                            Odlanier
                                            Maybe Gaieus knows about this,since he's been working on clay bricks, and tiles for long.
                                            There was an hexagonal clay floor tile in SU 6 very pretty and very realistic.
                                            After I installed SU7 it went missing and instead a white hexagonal tile now appears.
                                            I tried editing it to give it the natural, warm and lovely color and texture it use ti have,but it does not come out so:
                                            when you select a reddish, clayey color it comes out with cherry-red spots and yellowish tint.
                                            Is there a way to recover that lovely hexagonal clay tile?
                                            Thanks fellows,
                                            • 2 / 5
