    1.3k Posts 299 Posters 2.5m Views 297 Watching
    • fredo6F Offline
      Ah oK ๐Ÿ˜„
      But that is not normal ๐Ÿ˜‰
      I cannot really say that this is normal ๐Ÿ˜†
      This is simply a small problem when the two faces are in parallel planes. It is part of the fixes I will release. The issue is just that the contours are connected in reverse directions.
        DIEGO-RODRIGUEZ
        Hi Fred.
        a question.
        is normal that generates the mesh outside the component or group that I'm working?
        • fredo6F Offline
          @diego-rodriguez said:
          Hi Fred.
          a question.
          It's part of the bug fixed but not yet released.
          This was already signaled. see that post
          • charly2008C Offline
            charly2008
            again a new Object
            Charly
            • mitcorbM Offline
              mitcorb
              @Charly: Someone has probably already said this, but your Curviloft models remind me of high style jewelry in the tradition of Faberge, perhaps, or someone like him. I would have to guess you might actually work with jewelry or decorative art in some way. Again, I salute your creativity.
              The other possibility is that you are a very discerning and talented machinist.
              However, there are dentists who like to work with jewelry.
              Now don't let this all go to your head. We won't be able to do a thing with you ๐Ÿ’š
                charly2008
                Hi mitcorb,
                at first many thanks for your nice comments. I'm just a retired mechanical engineer. I have nothing to do with jewelry. My thanks to Fredo and TIG for their wonderful plugins that allow me always to try new ideas. Curviloft inspired me again and again to construct new forms. It is not a great art, but only practice and a little visionary. In principle, everyone who deals with it can do it.
                Charly
                  jbw007
                  Hi Fredo,
                  I've download your fantastic plugin, but I'm not able to use it. I get the toolbar and menu items, and I've created the curves that I want to work on. Nothing happens at all. I've check the video 10 times and can't see what's wrong. It's the only Plugin that I have installed, after a reinstall of SU. Nothing in the Ruby console, in fact the same problem that 'Rachmatrf' have in June. I've looked through the forum for the answer to him, but failed to find the solution. Can you help ?
                  Regards
                  Jens
                  Running XP SP3, and SU8
                  • fredo6F Offline
                    Jason,
                    I had a look and yes the design is quite impressive. I see of course where you used the plugins.
                    You really should put a picture in your post.
                    • jason_marantoJ Offline
                      jason_maranto
                      Hey Fredo,
                      I am currently trying my best to learn how to use curviloft and I working on a project that I think fits alot of what the tool does -- since everyone else is sharing I thought I would too. This is a the arm for a robot from a show I watched as a child called Robotech (also known as Macross overseas).
                      http://www.spotoarts.com/jason/armandgun_posed_dc.skp (5mb download)
                      I am using curviloft, roundcorner, and JJP for alot of this -- you may also notice that this is a dynamic component and if you click on it I have rigged it to animate between 2 positions... although the poly-count is really stretching the limits of what can be animated.
                      Thank-you for your plugins!
                      ๐Ÿ’ญ I also forgot to mention I'm using your BZ toolbar set as well ๐Ÿ˜
                      Best,
                      Jason.
                      • fredo6F Offline
                        NEW RELEASE: Curviloft 1.1a - 12 Jan 11
                        Sorry for long absence. This new release hopefully includes a functional version of Loft Along Path, along with other fixes. It also support a two-phase loading.
                        Note that you will need to upgrade to LibFredo6 3.6.
                        There is still no documentation. So the best is have a look at the video:
                        [flash=640,480:3menursp]http://www.youtube.com/v/AZnVY3unWPU&hl[/flash:3menursp]
                        See main post for download
                          Thanks again Fredo6, this is an amazing tool ๐Ÿ‘
                          • utilerU Offline
                            utiler
                            Fredo, I don't know how many time I can say thank you with out it becoming monotonous but, thank you!
                            Just Curious...
                              ๐Ÿ˜ฎ Wow!
                              Thank you, thank you, thank you.
                                Daniel S
                                Thank you Fredo!!!
                                I like the respect tangency method ๐ŸŽ‰
                                But looks like the skinning option has a regression ๐Ÿ˜ž
                                Daniel S
                                skin.skp
                                • fredo6F Offline
                                  @daniel s said:
                                  [b]But looks like the skinning option has a regression ๐Ÿ˜ž
                                  Daniel S
                                  Daniel,
                                  You always find the right bugs. Thanks for that! This seems to be with 3 sides shapes.
                                  I have a look.
                                    Happy new year Fredo! ๐Ÿ˜Ž et ๐Ÿ‘
                                    • fredo6F Offline
                                      Small bug signaled by Daniel S in Skinning (on 3-side shapes) is fixed.
                                      You just need to upgrade to LibFredo6 3.6b
                                        Daniel S
                                        That was fast.. thank you again Fredo!!!
                                        Awesome plugin
                                        Daniel S
                                          Speedy SAV (in English after sales service ) ๐Ÿ’š
                                          ๐Ÿ˜Ž
                                            jason_maranto
                                            Hi Fredo,
                                            Thank-you again for this -- I do have a slight request... I have some re-occurring twisting and if I take the time to align the verts manually the result comes out exactly the way I want, but manually setting the verts seems a bit temperamental at this point and I was wondering if it could be possible to set the "twist" parameters to decimal increments as it would solve my problem (1 is too large a change). See attached file for example.
                                            If there is a better solution then I am very interested... I have split the profiles down the middle and successfully finished it that way.
                                            Best,
                                            Jason.
                                            twisty verts.skp
                                            • 11
                                            • 65
                                            • 66
                                            • 9 / 66
