    [Tutorial > Texturing] Texturing an arch - #2
    87 Posts 18 Posters 42.7k Views 18 Watching
    • massimoM
      massimo Moderator
      Nice one Gai. Thanks.(Thanks to ThomThom too obviously) πŸ‘
      Followed carefully the tut, however I'm only able to get what you see in the picture. What I'm doing wrong?
      -apply the texture;
      -draw the mortar's lines;
      -hidden geometry on;
      -ctrl+eraser on the lines;
      -hidden geometry off;
      -select the surface with the texture with one click;
      -UVtoolkit-->remember position;
      -bend the pillar;
      -UVtoolkit-->restore position.
      • GaieusG
        Hi Massimo,
        Can you attach the skp file (preferably beforethe bend)?
        • massimoM
          massimo Moderator
          HI Gai, here you have a model before the bend and before the UVtoolkit-->remember position.
          UV.skp
          • GaieusG
            Hm. To me, it seems to work correctly. I am on SU 8 however - don't know if that makes a difference (should try on 7 as well).
            The bend is a bit funny though as only the front face was subdivided πŸ˜„
            (This should obviously not have any effect on the UV part)
            UV.skp
            • GaieusG
              I tried in v.7 and it worked correctly, the same way.
              • massimoM
                massimo Moderator
                Have tried also with all faces with subdivisions, but the result is pretty the same. Also the result seems a bit unpredictable: sometimes nothin happens after UVtoolkit-->restore position. Maybe SU 7 is the culprit. Thanks anyway. πŸ˜„
                Edit: Oh you're too fast! So it's not SU7.
                • GaieusG
                  Here is the file saved after bending but before restoring the UV's. Try to restore from here so that we see where are the steps that went wrong.
                  UV.skp
                  • massimoM
                    massimo Moderator
                    Wait...Found it. I'm used to press F4 before bending in order to have subdivisions. If you do that it doesn't work. Thanks for the help. πŸ˜„
                    • massimoM
                      massimo Moderator
                      And it works also with multiple faces selected. πŸ‘ Even if you will need some adjustment on the corners in this particular case.
                      • GaieusG
                        In the release notes it says that once you add new geometry afterremembering the UV, the data is lost. This is why we need to subdivide first and remember next.
                        It would certainly be awesome if it somehow could remember UV's after modifying the mesh (by adding/removing faces). Maybe one day...
                        Yeah. I just select all (of the column) and run the plugin on the whole selection (including all sides).
                        Did I mention that it's an excellent plugin?
                        πŸ˜„
                        Also, it does not only work on quad faces but on triangles, too. This is very important as some operation may add further subdivision by triangulating (imagine a twist for instance)
                        • massimoM
                          massimo Moderator
                          πŸ˜„
                          Yeah, you did... πŸ˜†
                          Indeed. πŸ˜‰
                          • GaieusG
                            Now twisted AND bent. 😲
                            (This definitely needs pre-triangulation as it would be triangulated by the twist anyway)
                            Incredible!
                            UV.skp
                            • massimoM
                              massimo Moderator
                              So Gai now we are waiting for a model of this... πŸ˜†
                              • GaieusG
                                Ah, Bernini... I have not always liked that deep Baroque but nowadays I am fine with it...
                                πŸ˜„
                                • massimoM
                                  massimo Moderator
                                  Yeah, I always preferred Borromini (who also worked a bit at that baldaquin anyway). πŸ˜‰
                                    I pitty the brick builder. πŸ˜„
                                      dominion
                                      Sorry to be dumb but how do you subdivide? is it a plugin?
                                      • GaieusG
                                        I just copied the bottom edges along with a linear array (Ctrl+ )
                                          dominion
                                          er if i do that it creates faces for each section of the texture, your 2nd image shows it as one face and your first shows dotted lines for the divide my has sild edges?
                                          • GaieusG
                                            Yes, I softened those edges so that when I turn off hidden geometry (which you can see in the first image as dotted), I can select the whole surface as one. If you select all after the array operation and right click > soften edges, check the "soften coplanar edges" box at the bottom right of the dialog.
                                            • 1 / 5
