    [Tutorial > Texturing] Texturing an arch - #2
    87 Posts 18 Posters 42.7k Views 18 Watching
    • massimoM
      massimo Moderator
      And it works also with multiple faces selected. πŸ‘ Even if you will need some adjustment on the corners in this particular case.
      • GaieusG
        @massimo said:
        Wait...Found it. I'm used to press F4 before bending in order to have subdivisions. If you do that it doesn't work. Thanks for the help. πŸ˜„
        In the release notes it says that once you add new geometry afterremembering the UV, the data is lost. This is why we need to subdivide first and remember next.
        It would certainly be awesome if it somehow could remember UV's after modifying the mesh (by adding/removing faces). Maybe one day...
        Yeah. I just select all (of the column) and run the plugin on the whole selection (including all sides).
        Did I mention that it's an excellent plugin?
        πŸ˜„
        Also, it does not only work on quad faces but on triangles, too. This is very important as some operation may add further subdivision by triangulating (imagine a twist for instance)
        • massimoM
          massimo Moderator
          πŸ˜„
          Yeah, you did... πŸ˜†
          Indeed. πŸ˜‰
          • GaieusG
            Now twisted AND bent. 😲
            (This definitely needs pre-triangulation as it would be triangulated by the twist anyway)
            Incredible!
            UV.skp
            • massimoM
              massimo Moderator
              So Gai now we are waiting for a model of this... πŸ˜†
              • GaieusG
                Ah, Bernini... I have not always liked that deep Baroque but nowadays I am fine with it...
                πŸ˜„
                • massimoM
                  massimo Moderator
                  Yeah, I always preferred Borromini (who also worked a bit at that baldaquin anyway). πŸ˜‰
                    I pitty the brick builder. πŸ˜„
                      dominion
                      Sorry to be dumb but how do you subdivide? is it a plugin?
                      • GaieusG
                        I just copied the bottom edges along with a linear array (Ctrl+ )
                          dominion
                          er if i do that it creates faces for each section of the texture, your 2nd image shows it as one face and your first shows dotted lines for the divide my has sild edges?
                          • GaieusG
                            Yes, I softened those edges so that when I turn off hidden geometry (which you can see in the first image as dotted), I can select the whole surface as one. If you select all after the array operation and right click > soften edges, check the "soften coplanar edges" box at the bottom right of the dialog.
                              dominion
                              Ah I get it thanks
                              • GaieusG
                                So how is it going? Let's see some interesting results (I always make boring vaults only although now there is also a sugar cane I made this way)
                                  dominion
                                  hohum not working, done it all but when i click restore uv it does nothing at all 😞
                                  • GaieusG
                                    Have you got the original (not-yet-bent) shape?
                                      dominion
                                      yea got it fine looks exactly as in your tut
                                      • GaieusG
                                        You mean it looks like the one in the tut before you make the bend and the UV restore or you mean that you could do it finally?
                                          dominion
                                          i can do the bend its just the uv restore that does not work
                                            If you open the Ruby Console - does it give you an error?
                                            If not, any chance you can do a video capture`?
                                            • 1 / 5
