More Characters
@solo said:
Mac only...
See, there is a reason for owning a Mac.
Actually, that is no longer true. I think since they re-built the SU render engine in 7.1, PC has been able to export transparent png's.
Please elaborate and post some screen shots, Chris...
Cause I sure can't find this in the option menu...
I've tried both tif and png - and I don't see any option for selecting transparent background...@frederik said:
Well, well... thomthom's Export 2d with Alpha can make similar png's for us depending on Windows...
Really Frederik, you don't need this much. You may need to mask some glass windows too, transparency doesn't help much there. Try to assign a pure green or magenta instead. Ps can do miracles this way. From a mac user anyway.
I know, michalis...
I can make incredible things in post pro with PS for Win...
I also know about the work arounds, but if I can avoid them, it would be great...Chris F. states that transparent background is possible with SU for Win since ver. 7.1 but I can't find how/where, hence my question to Chris to post some screen shots...
Well, well... I don't want to hijack this thread...
Cause I sure can't find this in the option menu...I'd also be curious, Chris. What beta build are you using?
This is bizarre - is it seriouslly not possible? I swear I've done this a dozen times in the last week. Even wierder is I'm sure it was Gaieus who corrected me last time I said the same thing as Solo. I think I'm experiencing early onset dimentia. I suddenly am unsure of everything.
I'm on vacation now and I don't have access to SU at the moment. So when I can play with SU, I'll test it. so weird.......
First, there is no checkbox for transparent background at all so I cannot set it. When I export (even with sky and ground turned off), the white background appears, too.
I can of course export with transparent background from LayOut.
Thanks for confirming this, Csaba...
I have ver. 7 Pro, but I haven't upgraded ver. 8 to Pro...
Besides, I've never really used LayOut... -
Back to topic, more characters, this is a WIP, still got more face detail to do, it's supposed to be... why don't y'all guess, that way I know how bad it is.
Looking good, solo! Was most of this model created with the SDS2 sculpt tool? Or did you use your proxy/subdivision workflow?
Proxy base, then divide,sculpt,divide,smooth, I know it sounds like a silly workflow but once SDS2 is released most folk will understand.
Did Richard Prior and Kevin Spacey have a love-child?
Hmmm....it's either Obama or Robert Downey Jr's character in Tropic Thunder.
Obama!!!
ducks for cover
Edit: Aww, Adam beat me to it.
Give him side burns and its Shaft!
...some offtop...Obama in ZBrush.
..hapy new year again!
lol i second Robert Downey Jr's character in Tropic Thunder
Yup, it needs work, after seeing that Z-brush version I realise that I need more practice and doubt SU would handle the poly's needed to create such a mesh not to mention the UV mapping thing that SU honestly does absolutely suck at.
I would love somebody to develop precise UV tools to be used with SDS2!
that would be perfect!
