    More Characters
    Scheduled Pinned Locked Moved Organic Modelling
    71 Posts 25 Posters 42.3k Views 25 Watching
    • jeff hammondJ
      @frederik said:
      If I export a line image, the background will not be transparent...
      if you export a tiff or png which support transparency then click 'transparent background' in the export options.
      [though i'm thinking this may be a mac only feature?]
      • soloS
        Mac only... πŸ’š
        See, there is a reason for owning a Mac. πŸ˜‰
          What is it? You can it disappear into the BG
          • FrederikF
            Frederik
            @solo said:
            @Frederick and Rich, I use a white background when rendering so exporting SU lines with a white background actually helps, in PS I use 'multiply' for blend, makes lines pop better.
            Cheers, Pete...
            Just thought you had a trick in your sleeve to export the lines with transparent background, but blending using 'multiply' works just fine... πŸ‘
            Edit: I knew I had seen somewhere that you're able to get transparent background on a Mac...
            Well, well... thomthom's Export 2d with Alpha can make similar png's for us depending on Windows... πŸ˜›
            Unfortunately only the background will be transparent and not objects (not even if you paint them in the same color as the bg)...
            Cheers
            Kim Frederik
            • michaliszissiouM
              michaliszissiou
              Multiply works fine, no need for transparent background.
              If you want transparent or semi transparent exports (lets say window glass etc) apply a strong color (pure magenta or green) then use it as mask in Ps. πŸ˜‰ A nice way for fake reflections in PP.
              • Chris FullmerC
                @solo said:
                Mac only... πŸ’š
                Actually, that is no longer true. I think since they re-built the SU render engine in 7.1, PC has been able to export transparent png's.
                • FrederikF
                  Frederik
                  Please elaborate and post some screen shots, Chris...
                  Cause I sure can't find this in the option menu...
                  I've tried both tif and png - and I don't see any option for selecting transparent background...
                  Cheers
                  Kim Frederik
                  • michaliszissiouM
                    michaliszissiou
                    Really Frederik, you don't need this much. You may need to mask some glass windows too, transparency doesn't help much there. Try to assign a pure green or magenta instead. Ps can do miracles this way. From a mac user anyway.
                    • FrederikF
                      Frederik
                      I know, michalis...
                      I can make incredible things in post pro with PS for Win... πŸ˜„
                      I also know about the work arounds, but if I can avoid them, it would be great...
                      Chris F. states that transparent background is possible with SU for Win since ver. 7.1 but I can't find how/where, hence my question to Chris to post some screen shots...
                      Well, well... I don't want to hijack this thread... πŸ˜„
                      Cheers
                      Kim Frederik
                      • GaieusG
                        I'd also be curious, Chris. What beta build are you using?
                        πŸ˜†
                        • Chris FullmerC
                          This is bizarre - is it seriouslly not possible? I swear I've done this a dozen times in the last week. Even wierder is I'm sure it was Gaieus who corrected me last time I said the same thing as Solo. I think I'm experiencing early onset dimentia. I suddenly am unsure of everything.
                          I'm on vacation now and I don't have access to SU at the moment. So when I can play with SU, I'll test it. so weird....... πŸ˜•
                          • GaieusG
                            First, there is no checkbox for transparent background at all so I cannot set it. When I export (even with sky and ground turned off), the white background appears, too.
                            I can of course export with transparent background from LayOut.
                            • FrederikF
                              Frederik
                              Thanks for confirming this, Csaba... πŸ‘
                              I have ver. 7 Pro, but I haven't upgraded ver. 8 to Pro... 😳
                              Besides, I've never really used LayOut...
                              Cheers
                              Kim Frederik
                              • soloS
                                Back to topic, more characters, this is a WIP, still got more face detail to do, it's supposed to be... why don't y'all guess, that way I know how bad it is.
                                • W
                                  Whaat
                                  Looking good, solo! Was most of this model created with the SDS2 sculpt tool? Or did you use your proxy/subdivision workflow?
                                  • soloS
                                    Proxy base, then divide,sculpt,divide,smooth, I know it sounds like a silly workflow but once SDS2 is released most folk will understand.
                                      Did Richard Prior and Kevin Spacey have a love-child?
                                      • EarthMoverE
                                        EarthMover
                                        Hmmm....it's either Obama or Robert Downey Jr's character in Tropic Thunder. πŸ˜„
                                        Content Creator at Skapeup
                                          SketchUpNoobie
                                          Obama!!!
                                          ducks for cover
                                          πŸ˜†
                                          Edit: Aww, Adam beat me to it.
                                          SketchUpNoobie: the complete noob in all things SketchUp.
                                          • boofredlayB
                                            boofredlay
                                            Give him side burns and its Shaft!
                                            • 2 / 4
