    More Characters
    Scheduled Pinned Locked Moved Organic Modelling
    71 Posts 25 Posters 42.3k Views 25 Watching
    • soloS
      Mac only... πŸ’š
      See, there is a reason for owning a Mac. πŸ˜‰
        What is it? You can it disappear into the BG
        • FrederikF
          Frederik
          @solo said:
          @Frederick and Rich, I use a white background when rendering so exporting SU lines with a white background actually helps, in PS I use 'multiply' for blend, makes lines pop better.
          Cheers, Pete...
          Just thought you had a trick in your sleeve to export the lines with transparent background, but blending using 'multiply' works just fine... πŸ‘
          Edit: I knew I had seen somewhere that you're able to get transparent background on a Mac...
          Well, well... thomthom's Export 2d with Alpha can make similar png's for us depending on Windows... πŸ˜›
          Unfortunately only the background will be transparent and not objects (not even if you paint them in the same color as the bg)...
          Cheers
          Kim Frederik
          • michaliszissiouM
            michaliszissiou
            Multiply works fine, no need for transparent background.
            If you want transparent or semi transparent exports (lets say window glass etc) apply a strong color (pure magenta or green) then use it as mask in Ps. πŸ˜‰ A nice way for fake reflections in PP.
            • Chris FullmerC
              @solo said:
              Mac only... πŸ’š
              Actually, that is no longer true. I think since they re-built the SU render engine in 7.1, PC has been able to export transparent png's.
              • FrederikF
                Frederik
                Please elaborate and post some screen shots, Chris...
                Cause I sure can't find this in the option menu...
                I've tried both tif and png - and I don't see any option for selecting transparent background...
                Cheers
                Kim Frederik
                • michaliszissiouM
                  michaliszissiou
                  Really Frederik, you don't need this much. You may need to mask some glass windows too, transparency doesn't help much there. Try to assign a pure green or magenta instead. Ps can do miracles this way. From a mac user anyway.
                  • FrederikF
                    Frederik
                    I know, michalis...
                    I can make incredible things in post pro with PS for Win... πŸ˜„
                    I also know about the work arounds, but if I can avoid them, it would be great...
                    Chris F. states that transparent background is possible with SU for Win since ver. 7.1 but I can't find how/where, hence my question to Chris to post some screen shots...
                    Well, well... I don't want to hijack this thread... πŸ˜„
                    Cheers
                    Kim Frederik
                    • GaieusG
                      I'd also be curious, Chris. What beta build are you using?
                      πŸ˜†
                      • Chris FullmerC
                        This is bizarre - is it seriouslly not possible? I swear I've done this a dozen times in the last week. Even wierder is I'm sure it was Gaieus who corrected me last time I said the same thing as Solo. I think I'm experiencing early onset dimentia. I suddenly am unsure of everything.
                        I'm on vacation now and I don't have access to SU at the moment. So when I can play with SU, I'll test it. so weird....... πŸ˜•
                        • GaieusG
                          First, there is no checkbox for transparent background at all so I cannot set it. When I export (even with sky and ground turned off), the white background appears, too.
                          I can of course export with transparent background from LayOut.
                          • FrederikF
                            Frederik
                            Thanks for confirming this, Csaba... πŸ‘
                            I have ver. 7 Pro, but I haven't upgraded ver. 8 to Pro... 😳
                            Besides, I've never really used LayOut...
                            Cheers
                            Kim Frederik
                            • soloS
                              Back to topic, more characters, this is a WIP, still got more face detail to do, it's supposed to be... why don't y'all guess, that way I know how bad it is.
                              • W
                                Whaat
                                Looking good, solo! Was most of this model created with the SDS2 sculpt tool? Or did you use your proxy/subdivision workflow?
                                • soloS
                                  Proxy base, then divide,sculpt,divide,smooth, I know it sounds like a silly workflow but once SDS2 is released most folk will understand.
                                    Did Richard Prior and Kevin Spacey have a love-child?
                                    • EarthMoverE
                                      EarthMover
                                      Hmmm....it's either Obama or Robert Downey Jr's character in Tropic Thunder. πŸ˜„
                                      Content Creator at Skapeup
                                        SketchUpNoobie
                                        Obama!!!
                                        ducks for cover
                                        πŸ˜†
                                        Edit: Aww, Adam beat me to it.
                                        SketchUpNoobie: the complete noob in all things SketchUp.
                                        • boofredlayB
                                          boofredlay
                                          Give him side burns and its Shaft!
                                          • urgenU
                                            urgen
                                            ...some offtop...Obama in ZBrush. πŸ˜„ ..hapy new year again! β˜€
                                            --pupil forever...------
                                            • 2 / 4
