    More Characters
    Scheduled Pinned Locked Moved Organic Modelling
    71 Posts 25 Posters 42.3k Views 25 Watching
    • michaliszissiouM
      michaliszissiou
      Nice dog.
      Well done Pete,
      Crits? Too many polys (but its OK here) much stretching on ears area, not the best for UVs.
      • FrederikF
        Frederik
        @solo said:
        ...exported the line image...
        I've never figured how to do this...
        Please enlighten us mortals...
        If I export a line image, the background will not be transparent...
        Cheers
        Kim Frederik
          I presume he sets the blend mode to overlay in Photoshop? That's what i do anyway 😳
          • soloS
            @michal, Poly count is no issue, I dont mind high poly models, I use a studio renderer so that hurdle is overcome. I used FFD on ears so yes I stretched the mesh.
            @Frederick and Rich, I use a white background when rendering so exporting SU lines with a white background actually helps, in PS I use 'multiply' for blend, makes lines pop better.
            • jeff hammondJ
              if you export a tiff or png which support transparency then click 'transparent background' in the export options.
              [though i'm thinking this may be a mac only feature?]
              • soloS
                Mac only... πŸ’š
                See, there is a reason for owning a Mac. πŸ˜‰
                  What is it? You can it disappear into the BG
                  • FrederikF
                    Frederik
                    Cheers, Pete...
                    Just thought you had a trick in your sleeve to export the lines with transparent background, but blending using 'multiply' works just fine... πŸ‘
                    Edit: I knew I had seen somewhere that you're able to get transparent background on a Mac...
                    Well, well... thomthom's Export 2d with Alpha can make similar png's for us depending on Windows... πŸ˜›
                    Unfortunately only the background will be transparent and not objects (not even if you paint them in the same color as the bg)...
                    Cheers
                    Kim Frederik
                    • michaliszissiouM
                      michaliszissiou
                      Multiply works fine, no need for transparent background.
                      If you want transparent or semi transparent exports (lets say window glass etc) apply a strong color (pure magenta or green) then use it as mask in Ps. πŸ˜‰ A nice way for fake reflections in PP.
                      • Chris FullmerC
                        @solo said:
                        Mac only... πŸ’š
                        Actually, that is no longer true. I think since they re-built the SU render engine in 7.1, PC has been able to export transparent png's.
                        • FrederikF
                          Frederik
                          Please elaborate and post some screen shots, Chris...
                          Cause I sure can't find this in the option menu...
                          I've tried both tif and png - and I don't see any option for selecting transparent background...
                          Cheers
                          Kim Frederik
                          • michaliszissiouM
                            michaliszissiou
                            Really Frederik, you don't need this much. You may need to mask some glass windows too, transparency doesn't help much there. Try to assign a pure green or magenta instead. Ps can do miracles this way. From a mac user anyway.
                            • FrederikF
                              Frederik
                              I know, michalis...
                              I can make incredible things in post pro with PS for Win... πŸ˜„
                              I also know about the work arounds, but if I can avoid them, it would be great...
                              Chris F. states that transparent background is possible with SU for Win since ver. 7.1 but I can't find how/where, hence my question to Chris to post some screen shots...
                              Well, well... I don't want to hijack this thread... πŸ˜„
                              Cheers
                              Kim Frederik
                              • GaieusG
                                I'd also be curious, Chris. What beta build are you using?
                                πŸ˜†
                                • Chris FullmerC
                                  This is bizarre - is it seriouslly not possible? I swear I've done this a dozen times in the last week. Even wierder is I'm sure it was Gaieus who corrected me last time I said the same thing as Solo. I think I'm experiencing early onset dimentia. I suddenly am unsure of everything.
                                  I'm on vacation now and I don't have access to SU at the moment. So when I can play with SU, I'll test it. so weird....... πŸ˜•
                                  • GaieusG
                                    First, there is no checkbox for transparent background at all so I cannot set it. When I export (even with sky and ground turned off), the white background appears, too.
                                    I can of course export with transparent background from LayOut.
                                    • FrederikF
                                      Frederik
                                      Thanks for confirming this, Csaba... πŸ‘
                                      I have ver. 7 Pro, but I haven't upgraded ver. 8 to Pro... 😳
                                      Besides, I've never really used LayOut...
                                      Cheers
                                      Kim Frederik
                                      • soloS
                                        Back to topic, more characters, this is a WIP, still got more face detail to do, it's supposed to be... why don't y'all guess, that way I know how bad it is.
                                        • W
                                          Whaat
                                          Looking good, solo! Was most of this model created with the SDS2 sculpt tool? Or did you use your proxy/subdivision workflow?
                                          • soloS
                                            Proxy base, then divide,sculpt,divide,smooth, I know it sounds like a silly workflow but once SDS2 is released most folk will understand.
                                            • 1 / 4
