    More Characters
    Scheduled Pinned Locked Moved Organic Modelling
    71 Posts 25 Posters 42.3k Views 25 Watching
      I presume he sets the blend mode to overlay in Photoshop? That's what i do anyway 😳
      • soloS
        @michal, Poly count is no issue, I dont mind high poly models, I use a studio renderer so that hurdle is overcome. I used FFD on ears so yes I stretched the mesh.
        @Frederick and Rich, I use a white background when rendering so exporting SU lines with a white background actually helps, in PS I use 'multiply' for blend, makes lines pop better.
        • jeff hammondJ
          @frederik said:
          If I export a line image, the background will not be transparent...
          if you export a tiff or png which support transparency then click 'transparent background' in the export options.
          [though i'm thinking this may be a mac only feature?]
          • soloS
            Mac only... πŸ’š
            See, there is a reason for owning a Mac. πŸ˜‰
              What is it? You can it disappear into the BG
              • FrederikF
                Frederik
                Cheers, Pete...
                Just thought you had a trick in your sleeve to export the lines with transparent background, but blending using 'multiply' works just fine... πŸ‘
                Edit: I knew I had seen somewhere that you're able to get transparent background on a Mac...
                Well, well... thomthom's Export 2d with Alpha can make similar png's for us depending on Windows... πŸ˜›
                Unfortunately only the background will be transparent and not objects (not even if you paint them in the same color as the bg)...
                Cheers
                Kim Frederik
                • michaliszissiouM
                  michaliszissiou
                  Multiply works fine, no need for transparent background.
                  If you want transparent or semi transparent exports (lets say window glass etc) apply a strong color (pure magenta or green) then use it as mask in Ps. πŸ˜‰ A nice way for fake reflections in PP.
                  • Chris FullmerC
                    @solo said:
                    Mac only... πŸ’š
                    Actually, that is no longer true. I think since they re-built the SU render engine in 7.1, PC has been able to export transparent png's.
                    • FrederikF
                      Frederik
                      Please elaborate and post some screen shots, Chris...
                      Cause I sure can't find this in the option menu...
                      I've tried both tif and png - and I don't see any option for selecting transparent background...
                      Cheers
                      Kim Frederik
                      • michaliszissiouM
                        michaliszissiou
                        Really Frederik, you don't need this much. You may need to mask some glass windows too, transparency doesn't help much there. Try to assign a pure green or magenta instead. Ps can do miracles this way. From a mac user anyway.
                        • FrederikF
                          Frederik
                          I know, michalis...
                          I can make incredible things in post pro with PS for Win... πŸ˜„
                          I also know about the work arounds, but if I can avoid them, it would be great...
                          Chris F. states that transparent background is possible with SU for Win since ver. 7.1 but I can't find how/where, hence my question to Chris to post some screen shots...
                          Well, well... I don't want to hijack this thread... πŸ˜„
                          Cheers
                          Kim Frederik
                          • GaieusG
                            I'd also be curious, Chris. What beta build are you using?
                            πŸ˜†
                            • Chris FullmerC
                              This is bizarre - is it seriouslly not possible? I swear I've done this a dozen times in the last week. Even wierder is I'm sure it was Gaieus who corrected me last time I said the same thing as Solo. I think I'm experiencing early onset dimentia. I suddenly am unsure of everything.
                              I'm on vacation now and I don't have access to SU at the moment. So when I can play with SU, I'll test it. so weird....... πŸ˜•
                              • GaieusG
                                First, there is no checkbox for transparent background at all so I cannot set it. When I export (even with sky and ground turned off), the white background appears, too.
                                I can of course export with transparent background from LayOut.
                                • FrederikF
                                  Frederik
                                  Thanks for confirming this, Csaba... πŸ‘
                                  I have ver. 7 Pro, but I haven't upgraded ver. 8 to Pro... 😳
                                  Besides, I've never really used LayOut...
                                  Cheers
                                  Kim Frederik
                                  • soloS
                                    Back to topic, more characters, this is a WIP, still got more face detail to do, it's supposed to be... why don't y'all guess, that way I know how bad it is.
                                    • W
                                      Whaat
                                      Looking good, solo! Was most of this model created with the SDS2 sculpt tool? Or did you use your proxy/subdivision workflow?
                                      • soloS
                                        Proxy base, then divide,sculpt,divide,smooth, I know it sounds like a silly workflow but once SDS2 is released most folk will understand.
                                          Did Richard Prior and Kevin Spacey have a love-child?
                                          • EarthMoverE
                                            EarthMover
                                            Hmmm....it's either Obama or Robert Downey Jr's character in Tropic Thunder. πŸ˜„
                                            Content Creator at Skapeup
                                            • 1 / 4
