    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 97.5k Views 69 Watching
    • PixeroP Offline
      Pixero
      Looks great. I have the old Bezier patch plugin by Victor Liu but this looks so much better.
      Just at the end after watching it two times I realised something... 😲 ...a transform gizmo!!!
      Wow! Cant you make a version of the move, rotate and scale tools that uses the gizmo? πŸ‘
      P.S. I just hope you haven't given up on the UV Tools plugin... πŸ˜’
        Yup - the gizmo will find its way into Vertex Tools 1.1.
        Wikii got a gizmo plugin available (I've not tried it) - though it says it'll work only until 2011.
        In any case - once the gizmo is done (need to make the rotate, scale3d, scale2d and scale1d functions) it'd be easy to make a standalone gadget.
          Nope - but it also needs this manupulator gizmo. Once that is done I hope to get a first release out.
          Vertex Tools, UV Tools and Bezier Surface share some reusable components so work on one often means benefit for the other. For instance, UV Tools will be of use for Bezier Surface as bezier surfaces are predictable surfaces that makes them easier to map.
          • W Offline
            Whaat
            Looks awesome Thomthom!
            • mitcorbM Offline
              mitcorb
              I guess this is an inevitable next step after Vertex Tools. You have proven you are a master, already.
              • Bob JamesB Offline
                Bob James
                Sign me up
                Gizmos in Vertex Tools πŸŽ‰
                  Panga
                  As a vertex tool user, I'm also looking forward for this plugin !! Thanks in advance for this one !!
                  • N Offline
                    nektares
                    Great Job! i must buy it when itΒ΄s ready!
                    • N Offline
                      notareal
                      Looking good so far.
                      • FrederikF Offline
                        Frederik
                        Godt gjort, Thomas...!
                        I'm definitely going to purchase this one... πŸ˜„
                        Cheers
                        Kim Frederik
                        • utilerU Offline
                          utiler
                          Way cool TT!!!
                          One question; will you be able to inference selected points with others? I see in the video where you have selected outside points and stretched them up then selected another few and moved then too. will you be able to move them to, say inference with the outside points as they were int he original position?
                          Looking forward to the release!!!
                          Just Curious...
                            Good question. I have an idea for how to do so - I'm just not sure how it'll work performance wise. (Backup plan would be to add CPoints in the positions of the control points - so SU's infere3nce engine will find them. But I hope I don't have to resort to that. I want to make a custom inference engine that prioritize the control points over the normal inference.)
                            • H Offline
                              hebeijianke
                              Its amazing
                              THX
                              • 1 Offline
                                123zxy
                                esto es tambien muy interesante
                                http://www.geepers.co.uk/media/flash/software/bezier_patch_explorer.swf
                                • utilerU Offline
                                  utiler
                                  Thanks Thom, looking forward to seeing the end result. πŸ‘
                                  Just Curious...
                                  • EdsonE Offline
                                    Edson
                                    http://www.mahfuz.arq.br
                                    • X Offline
                                      xrok1
                                      how's it going πŸ˜‰
                                        chloesdad
                                        ThomThom,
                                        I can't wait for this. Your plugins are well written and thought out. I have confidence in your efforts. I've been wanting this kind of capability for a long time. I think I may have said this once before: Quality plugins take time and effort, and creativity to develop. Reasonable fees for them are completely appropriate, IMHO.
                                        Thanks in advance!
                                        • X Offline
                                          xrok1
                                          maybe this could become part of vertex tools to make it more attractive now that artisan has added vertex tools. πŸ˜‰
                                            Thom's Vertex Tools has a wider range of selection modes than Artisan's. They are similar but also slighty different. Albeit both are excellent!
                                            • 12
                                            • 13
                                            • 2 / 13
