    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 97.5k Views 69 Watching
      @gaieus said:
      I don't care for cars and aeroplanes but like ships. Old ships especially.
      πŸ˜„
      How about old cars? πŸ˜„
      @chloesdad said:
      I purchased Vertex Tools, because it works, and I want to support the efforts of those of you who create quality plugins. It is, what makes SU a more powerful, useful product. I can't wait for Bezier Surface to become available. Fantastic, thanks in advance for your efforts!
      Cheers! πŸ˜„ πŸ‘
        Well, they are nice, indeed. πŸ˜†
          About coons surface πŸ˜‰
          And scroll you have even the code (button "Show code" πŸ˜‰
          • boofredlayB Offline
            boofredlay
            Looking forward to this one Thomas.
            • jason_marantoJ Offline
              jason_maranto
              Wow, that looks like a cross between SDS and Sketchy FFD, I can see this useful for many things but especially cloth modelling. 😍
              Best,
              Jason.
              • PixeroP Offline
                Pixero
                Looks great. I have the old Bezier patch plugin by Victor Liu but this looks so much better.
                Just at the end after watching it two times I realised something... 😲 ...a transform gizmo!!!
                Wow! Cant you make a version of the move, rotate and scale tools that uses the gizmo? πŸ‘
                P.S. I just hope you haven't given up on the UV Tools plugin... πŸ˜’
                  Yup - the gizmo will find its way into Vertex Tools 1.1.
                  Wikii got a gizmo plugin available (I've not tried it) - though it says it'll work only until 2011.
                  In any case - once the gizmo is done (need to make the rotate, scale3d, scale2d and scale1d functions) it'd be easy to make a standalone gadget.
                    Nope - but it also needs this manupulator gizmo. Once that is done I hope to get a first release out.
                    Vertex Tools, UV Tools and Bezier Surface share some reusable components so work on one often means benefit for the other. For instance, UV Tools will be of use for Bezier Surface as bezier surfaces are predictable surfaces that makes them easier to map.
                    • W Offline
                      Whaat
                      Looks awesome Thomthom!
                      • mitcorbM Offline
                        mitcorb
                        I guess this is an inevitable next step after Vertex Tools. You have proven you are a master, already.
                        • Bob JamesB Offline
                          Bob James
                          Sign me up
                          Gizmos in Vertex Tools πŸŽ‰
                            Panga
                            As a vertex tool user, I'm also looking forward for this plugin !! Thanks in advance for this one !!
                            • N Offline
                              nektares
                              Great Job! i must buy it when itΒ΄s ready!
                              • N Offline
                                notareal
                                Looking good so far.
                                • FrederikF Offline
                                  Frederik
                                  Godt gjort, Thomas...!
                                  I'm definitely going to purchase this one... πŸ˜„
                                  Cheers
                                  Kim Frederik
                                  • utilerU Offline
                                    utiler
                                    Way cool TT!!!
                                    One question; will you be able to inference selected points with others? I see in the video where you have selected outside points and stretched them up then selected another few and moved then too. will you be able to move them to, say inference with the outside points as they were int he original position?
                                    Looking forward to the release!!!
                                    Just Curious...
                                      Good question. I have an idea for how to do so - I'm just not sure how it'll work performance wise. (Backup plan would be to add CPoints in the positions of the control points - so SU's infere3nce engine will find them. But I hope I don't have to resort to that. I want to make a custom inference engine that prioritize the control points over the normal inference.)
                                      • H Offline
                                        hebeijianke
                                        Its amazing
                                        THX
                                        • 1 Offline
                                          123zxy
                                          esto es tambien muy interesante
                                          http://www.geepers.co.uk/media/flash/software/bezier_patch_explorer.swf
                                          • utilerU Offline
                                            utiler
                                            Thanks Thom, looking forward to seeing the end result. πŸ‘
                                            Just Curious...
                                            • 12
                                            • 13
                                            • 2 / 13
