    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 97.5k Views 69 Watching
      πŸ˜„ So I take it there is an interest for such a tool then - and not just me coding into oblivion. phew
      Why not coons surfaces, seems that is very similar? πŸ˜‰
      Until right now I'd never heard of coons surfaces...
      Does it possible to have more than 4 sides?
      No, there will be Tri and Quad Patches - these are combined into various configurations to create one surface. Like you do in 3DSMax's patch modelling.
      (And free or pay for ?)
      Most probable pay. This plugin is becoming rather complex. So I expect it to be something in the lines of Vertex Tools.
      @gaieus said:
      (Need a test forum, Thom? πŸ˜‰ )
      When time is ready, yes. Before that there will be a new round of Vertex Tools. πŸ˜‰
      @gaieus said:
      This is going to be great for all those who model ships for instance...
      mhm. And airplanes, cars, product designs and whatnot.
      The parametric nature of it makes it easy to model in low subdivision and then just apply a model wide multiplier right before you export your final image or render. I'm thinking it should also be possible to have a LOD setting that will adjust the subdivisions of the meshes depending on the current viewport. (components will be a challenge here...)
        OK, let me know. And wow, new vertex tools, too!
        πŸ‘
        I don't care for cars and aeroplanes but like ships. Old ships especially.
        πŸ˜„
          chloesdad
          I purchased Vertex Tools, because it works, and I want to support the efforts of those of you who create quality plugins. It is, what makes SU a more powerful, useful product. I can't wait for Bezier Surface to become available. Fantastic, thanks in advance for your efforts!
            πŸ˜„
            How about old cars? πŸ˜„
            Cheers! πŸ˜„ πŸ‘
              Well, they are nice, indeed. πŸ˜†
                About coons surface πŸ˜‰
                And scroll you have even the code (button "Show code" πŸ˜‰
                • boofredlayB Offline
                  boofredlay
                  Looking forward to this one Thomas.
                  • jason_marantoJ Offline
                    jason_maranto
                    Wow, that looks like a cross between SDS and Sketchy FFD, I can see this useful for many things but especially cloth modelling. 😍
                    Best,
                    Jason.
                    • PixeroP Offline
                      Pixero
                      Looks great. I have the old Bezier patch plugin by Victor Liu but this looks so much better.
                      Just at the end after watching it two times I realised something... 😲 ...a transform gizmo!!!
                      Wow! Cant you make a version of the move, rotate and scale tools that uses the gizmo? πŸ‘
                      P.S. I just hope you haven't given up on the UV Tools plugin... πŸ˜’
                        Yup - the gizmo will find its way into Vertex Tools 1.1.
                        Wikii got a gizmo plugin available (I've not tried it) - though it says it'll work only until 2011.
                        In any case - once the gizmo is done (need to make the rotate, scale3d, scale2d and scale1d functions) it'd be easy to make a standalone gadget.
                          Nope - but it also needs this manupulator gizmo. Once that is done I hope to get a first release out.
                          Vertex Tools, UV Tools and Bezier Surface share some reusable components so work on one often means benefit for the other. For instance, UV Tools will be of use for Bezier Surface as bezier surfaces are predictable surfaces that makes them easier to map.
                          • W Offline
                            Whaat
                            Looks awesome Thomthom!
                            • mitcorbM Offline
                              mitcorb
                              I guess this is an inevitable next step after Vertex Tools. You have proven you are a master, already.
                              • Bob JamesB Offline
                                Bob James
                                Sign me up
                                Gizmos in Vertex Tools πŸŽ‰
                                  Panga
                                  As a vertex tool user, I'm also looking forward for this plugin !! Thanks in advance for this one !!
                                  • N Offline
                                    nektares
                                    Great Job! i must buy it when itΒ΄s ready!
                                    • N Offline
                                      notareal
                                      Looking good so far.
                                      • FrederikF Offline
                                        Frederik
                                        Godt gjort, Thomas...!
                                        I'm definitely going to purchase this one... πŸ˜„
                                        Cheers
                                        Kim Frederik
                                        • utilerU Offline
                                          utiler
                                          Way cool TT!!!
                                          One question; will you be able to inference selected points with others? I see in the video where you have selected outside points and stretched them up then selected another few and moved then too. will you be able to move them to, say inference with the outside points as they were int he original position?
                                          Looking forward to the release!!!
                                          Just Curious...
                                            Good question. I have an idea for how to do so - I'm just not sure how it'll work performance wise. (Backup plan would be to add CPoints in the positions of the control points - so SU's infere3nce engine will find them. But I hope I don't have to resort to that. I want to make a custom inference engine that prioritize the control points over the normal inference.)
                                            • 12
                                            • 13
                                            • 2 / 13
