    Keyboard Shortcuts
    45 Posts 16 Posters 14.2k Views 16 Watching
    • jeff hammondJ
      Jan - really? no space bar Select?
      that's probably my favorite shortcut key to use πŸ˜„
      not a keyboard shortcut but something else i have set up which is pretty sweet..
      i have the thumb mouse button set to regular orbit and the middle mouse button set to option/orbit which disables the gravity weighted navigation (ctrl/orbit on windows?)
      • jeff hammondJ
        here's a new one i've been testing out and i really think it's going to stick.. try it out
        (currently using N as that's become my test key for shortcuts but i'll think i'll assign it to an actual key shortly)
        Window/Show Dialogs (which will toggle with Hide Dialogs)
        reason.. i usually have the following windows stacked & collapsed on my screen and i open/close them as needed:
        entity info -- soften/smooth -- scenes -- shadows -- styles
        (and this will work with many of the other window dialogs as well)
        with this shortcut, i now leave all of the dialogs expanded down the right side of my screen then toggle the windows on/off via the keyboard which is a lot better than opening/closing with the mouse.. further, this allows for a wider drawing window.
        • Chris FullmerC
          I normally have that assigned to F-12. Its a good shortcut to keep around in my opinion.
            Arx
            Space - Select
            Shift + Space - Move
            Ctrl + Space - Rotate
            Alt + Space - PushPull
            ~ - Get Dimensions Plugin
            Shift + ~ - Model Info
            Alt + Z - Tape Mesure
            Shift + Z - Rectangle Tool
            H - Hide Rest of Model
            That way the most frequently used tools are all under my left hand, so I don't even have to look at the keyboard to use them.
              DavidBoulder's image of his key assignments makes me think it would be nice to have a keyboard with the various tool icons instead of letters.
                If you have a few greens to spare...
                http://www.artlebedev.com/everything/optimus/
                http://img.artlebedev.com/everything/optimus/optimus_maximus_01w.jpg
                If you go to the Demo page you can see a layout for Photoshop.
                http://www.artlebedev.com/everything/optimus/demo/
                  http://www.artlebedev.com/everything/optimus-tactus/
                  http://img.artlebedev.com/everything/optimus-tactus/optitact-color.jpg
                  http://img.artlebedev.com/everything/optimus-tactus/optitact-side.jpg
                  Apparently it will be cheaper than the Optimus because it doesn't have a screen per key.
                    Though I'm not sure how nice it would be to use a keyboard without physical keys... maybe just a habit adjustment...?
                      Cool! But $2400US. 😲
                      That would be really neat in conjunction with that tablet I'm eying.
                      I was thinking a bit lower tech. Like a keyboard with transparent key covers that could be removed and little icons printed on paper inserted.
                      ThinkGeek shows it at $1600US but not available.
                        That could be cool. I see your point but you could make it so frequently used keys are bigger or in easier to reach locations.
                        Even the Aux which appears to be only a prototype would be good.
                          It can display video on its surface. ...so maybe a 3d model...?
                            That would be neat.
                            I was looking at the Project Blog and there's a compact keyboard in the works with larger displays on the keys (64x64) and expected to sell for under $1000US. Of course that was from June. Who knows what's really going to be available.
                            • DavidBoulderD
                              DavidBoulder
                              I had thought it would be a nice interface to assign keyboard shortcuts to have a keyboard image that you could just drag tools into vs. the current method. Another thing that would be nice (short of improved GUI to assign keyboard shortcuts) is a plugin that would generate a keyboard shortcut screenshot based on your current settings.
                              David Goldwasser
                              OpenStudio Developer
                              National Renewable Energy Laboratory
                                David, those are great ideas. There's a plugin to generate a list of the assigned keyboard shortcuts. I wonder if it is possible to make a plugin that would paste PNG images at specified coordinates over a drawing of the keyboard.
                                • EarthMoverE
                                  EarthMover
                                  Drumming up an old thread....but is there anyway to access a list of assigned keyboard shortcuts and perhaps export them as .csv? I'm teaching my wife Sketchup and want to get her used to the shortcuts I have setup, but am being too lazy to write them all down.
                                  Content Creator at Skapeup
                                    There's a plugin that will create a list of the assigned shortcuts. I think it is called shortcuts.rb. I'll see if I can find the link.
                                    Here you go: http://rld.crai.archi.fr/rld/plugin_details.php?id=373
                                    You can then copy the shortcuts from the list and paste them into whatever sort of document you want.
                                      There's also this....
                                      http://forums.sketchucation.com/viewtopic.php?p=266379#p266379
                                      • N
                                        numerobis
                                        i have my standart modeling tools assigned to mouse buttons in combination with "shift", "strg" and "alt" (the mouse buttons no.3-5 have assigned the function keys "F3", and "F8" and "F10" assigned)
                                        I can select them without thinking. It's more like finger gestures that happen automatically.
                                        The resulting combinations are at the moment:
                                        F3..........................pointer/select
                                        F3+shift.................push/pull
                                        F3+ctrl...................mirror selection (plugin)
                                        F3+alt....................line
                                        F8..........................move
                                        F8+shift.................rotate
                                        F8+ctrl..................scale
                                        F8+alt...................rectangle
                                        F3+shift+ctrl..........tape measure
                                        F3+shift+alt...........circle
                                        F8+shift+ctrl..........fredo scale - box scaling
                                        F8+ctrl+alt............follow me
                                        F3+shift+ctrl+alt....paint bucket
                                        F8+shift+ctrl+alt....offset
                                        and some keyboard only:
                                        ^............................reverse face
                                        X............................toggle x-ray
                                        Q............................remove all materials
                                        H............................toggle hidden geometry
                                        G............................make group
                                        G+shift...................make component
                                        v............................field of view
                                        z............................zoom extends
                                        T+shift+ctrl............uv-frontface to backface
                                        T+shift+alt.............uv-backface to frontface
                                        T+shift+ctrl+alt......delete backside material
                                        and some standart shortcuts like
                                        shift+ctrl+v............paste in place
                                        T............................top view
                                        • 2 / 3
