    Keyboard Shortcuts
    45 Posts 16 Posters 12.6k Views 16 Watching
      Jim
      @wo3dan said:
      can't you do that with different shortcuts#1.dat to shortcuts#n.dat files. Depending on what you are planning for the day you import the appropriate *.dat file.
      Nice idea Gerrit - it never occurred to me. I was thinking shortcut sets could be done using Windows registry hacks, similar to this.
      • jeff hammondJ Offline
        hey Gerrit
        on mac, this is possible via the .plist files as i keep these synced between 3 computers along with my plugin folder.
        i do that so everything remains consistent but if i felt so inclined, i could have fully different sets of shortcuts that i could load relatively easily depending on the task..
        that said, for the 1-2 variable hot keys, i think it would probably just be easier to assign them the normal way (but workflow wise, if it's not possible to script the hotkey idea, i guess i'll stick to using the toolbars/menus)
        • pyrolunaP Offline
          pyroluna
          I have just a few shortcuts, but I use them A Lot.
          F = Follow me
          D = Offset
          ` or Ctrl+F = Edit\item\zoom extents
          • DavidBoulderD Offline
            DavidBoulder
            Here is my shortcut set for OpenStudio Plugin. I'm all about grouping common tools together vs. tryign to match the letter of the tool. (Selection tools together, modification tools together, view/camera tools, tools to create new objects)
            David Goldwasser
            OpenStudio Developer
            National Renewable Energy Laboratory
            • PixeroP Offline
              Pixero
              I have:
              Q = select
              W = move (alt+W = JSMoveTool)
              E = rotate
              R = scale
              T = tape
              U = arc
              O = offset
              P = pushpull
              A = zoom extents
              S = zoom selected
              G = group
              J = rotated rectangle
              K = rectangle
              L = line
              Γ– = Left Click Reverse Face Tool (scrtool.rb)
                Jan - really? no space bar Select?
                that's probably my favorite shortcut key to use πŸ˜„
                not a keyboard shortcut but something else i have set up which is pretty sweet..
                i have the thumb mouse button set to regular orbit and the middle mouse button set to option/orbit which disables the gravity weighted navigation (ctrl/orbit on windows?)
                  here's a new one i've been testing out and i really think it's going to stick.. try it out
                  (currently using N as that's become my test key for shortcuts but i'll think i'll assign it to an actual key shortly)
                  Window/Show Dialogs (which will toggle with Hide Dialogs)
                  reason.. i usually have the following windows stacked & collapsed on my screen and i open/close them as needed:
                  entity info -- soften/smooth -- scenes -- shadows -- styles
                  (and this will work with many of the other window dialogs as well)
                  with this shortcut, i now leave all of the dialogs expanded down the right side of my screen then toggle the windows on/off via the keyboard which is a lot better than opening/closing with the mouse.. further, this allows for a wider drawing window.
                  • Chris FullmerC Offline
                    I normally have that assigned to F-12. Its a good shortcut to keep around in my opinion.
                      Arx
                      Space - Select
                      Shift + Space - Move
                      Ctrl + Space - Rotate
                      Alt + Space - PushPull
                      ~ - Get Dimensions Plugin
                      Shift + ~ - Model Info
                      Alt + Z - Tape Mesure
                      Shift + Z - Rectangle Tool
                      H - Hide Rest of Model
                      That way the most frequently used tools are all under my left hand, so I don't even have to look at the keyboard to use them.
                        DavidBoulder's image of his key assignments makes me think it would be nice to have a keyboard with the various tool icons instead of letters.
                          If you have a few greens to spare...
                          http://www.artlebedev.com/everything/optimus/
                          http://img.artlebedev.com/everything/optimus/optimus_maximus_01w.jpg
                          If you go to the Demo page you can see a layout for Photoshop.
                          http://www.artlebedev.com/everything/optimus/demo/
                            http://www.artlebedev.com/everything/optimus-tactus/
                            http://img.artlebedev.com/everything/optimus-tactus/optitact-color.jpg
                            http://img.artlebedev.com/everything/optimus-tactus/optitact-side.jpg
                            Apparently it will be cheaper than the Optimus because it doesn't have a screen per key.
                              Though I'm not sure how nice it would be to use a keyboard without physical keys... maybe just a habit adjustment...?
                                Cool! But $2400US. 😲
                                That would be really neat in conjunction with that tablet I'm eying.
                                I was thinking a bit lower tech. Like a keyboard with transparent key covers that could be removed and little icons printed on paper inserted.
                                ThinkGeek shows it at $1600US but not available.
                                  That could be cool. I see your point but you could make it so frequently used keys are bigger or in easier to reach locations.
                                  Even the Aux which appears to be only a prototype would be good.
                                    It can display video on its surface. ...so maybe a 3d model...?
                                      That would be neat.
                                      I was looking at the Project Blog and there's a compact keyboard in the works with larger displays on the keys (64x64) and expected to sell for under $1000US. Of course that was from June. Who knows what's really going to be available.
                                        DavidBoulder
                                        I had thought it would be a nice interface to assign keyboard shortcuts to have a keyboard image that you could just drag tools into vs. the current method. Another thing that would be nice (short of improved GUI to assign keyboard shortcuts) is a plugin that would generate a keyboard shortcut screenshot based on your current settings.
                                        David Goldwasser
                                          David, those are great ideas. There's a plugin to generate a list of the assigned keyboard shortcuts. I wonder if it is possible to make a plugin that would paste PNG images at specified coordinates over a drawing of the keyboard.
                                          • EarthMoverE Offline
                                            EarthMover
                                            Drumming up an old thread....but is there anyway to access a list of assigned keyboard shortcuts and perhaps export them as .csv? I'm teaching my wife Sketchup and want to get her used to the shortcuts I have setup, but am being too lazy to write them all down.
                                            Content Creator at Skapeup
                                            • 2 / 3
