    Keyboard Shortcuts
    45 Posts 16 Posters 11.3k Views 16 Watching
      W = Weld
      X = Explode
      H = Hidden Geometry
      O = Offset
      F = Follow Me
      Shift + G = Group
      EEby..... = 1/2/3/4/5/6/7/8/9
      CTRL + S = Fredoscale
      V = Vertex Tools
      Shift + O = Offset on Surface
      Shift + L = Line on Surface
      Shift + A = Arc on Surface
      Shift + C = Circle on Surface
      Shift + E = Erase on Surface
      • jeff hammondJ Offline
        I use all of the defaults (just became used to them over the years even if some aren't very logical.)
        The self assigned ones are:
        X - Xray
        Shift X - Back edges
        W - weld
        Shift A- arc:center + 2pts
        Shift H- hidden geometry
        Shift V - paste in place
        Shift B - B spline
        U - follow me
        J - jpp
        Shift S - fredoscale
        Shift space - select curve
        Shift R - 3pt rectangle
        Shift Z - zoom extents
        V - protractor
          [edit]
          I made a [req] a while ago that I still think would be great.
          Basically, I'd have a key or two [say #1 & 2] that I could assign to various tools depending on the project at hand.
          Maybe I need to use fredostretch a lot for the day. I'd select stretch then maybe shift-1 and 1 would now be assigned to stretch. The next day I might need lathe quite a bit so I select the lathe tool then shift-1 and 1 is now lathe. And so on and so forth.
          For some odd reason, it's just too big of an ordeal for me to do this via prefs so I just keep going to the icons. If this hot key idea were possible, I'm pretty sure I'd have shortcuts to lesser used functions much more often. (you know, the functions that you use once a month but when you do use them, you might use them 50 times)
          • Wo3DanW Offline
            Wo3Dan
            [edit]
            ..... Basically, I'd have a key or two [say #1 & 2] that I could assign to various tools depending on the project at hand.
            .......If this hot key idea were possible, I'm pretty sure I'd have shortcuts to lesser used functions much more often. (you know, the functions that you use once a month but when you do use them, you might use them 50 times)
            Hi Jeff,
            (not the perfect solution but) can't you do that with different shortcuts#1.dat to shortcuts#n.dat files. Depending on what you are planning for the day you import the appropriate *.dat file.
            I'm not sure whether you need to restart SU again or wheter it is implemented instantly. But at least you could import a whole bunch of "project depending" shortcuts at once.
            Once again, it's not perfect but it's worth a try.
              jaceguay
              I´ve made some shortcuts like Blender. Most shortcuts are positioned for stationary left hand in the keyboard. 😄
              g = Move
              v = Line
              x = Delete
              z = Section Plane
              t = X-Ray
              u = Unhide selected
              h = Hide
              f = Orbit
              d = Pan
              s = Zoom
              a = Select none
              r = Rotate
              e = Eraser
              w = Reverse face
              q = Rectangle
              Shift+F = Push-Pull
              Shift+D = Tape measure Tool
              Shift+A = Arc
              Shift+E = Zoom extend
              Shift+R = Zoom window
              Shift+T = Fade rest of the model
              Shift+Y = Fade similar components
              Shift+W = Look arround
              Ctrl+F = Folow me
              Ctrl+R = Offset
              Ctrl+D = Scale
                Jim
                Nice idea Gerrit - it never occurred to me. I was thinking shortcut sets could be done using Windows registry hacks, similar to this.
                  hey Gerrit
                  on mac, this is possible via the .plist files as i keep these synced between 3 computers along with my plugin folder.
                  i do that so everything remains consistent but if i felt so inclined, i could have fully different sets of shortcuts that i could load relatively easily depending on the task..
                  that said, for the 1-2 variable hot keys, i think it would probably just be easier to assign them the normal way (but workflow wise, if it's not possible to script the hotkey idea, i guess i'll stick to using the toolbars/menus)
                  • pyrolunaP Offline
                    pyroluna
                    I have just a few shortcuts, but I use them A Lot.
                    F = Follow me
                    D = Offset
                    ` or Ctrl+F = Edit\item\zoom extents
                    • DavidBoulderD Offline
                      DavidBoulder
                      Here is my shortcut set for OpenStudio Plugin. I'm all about grouping common tools together vs. tryign to match the letter of the tool. (Selection tools together, modification tools together, view/camera tools, tools to create new objects)
                      David Goldwasser
                      OpenStudio Developer
                      National Renewable Energy Laboratory
                      • PixeroP Offline
                        Pixero
                        I have:
                        Q = select
                        W = move (alt+W = JSMoveTool)
                        E = rotate
                        R = scale
                        T = tape
                        U = arc
                        O = offset
                        P = pushpull
                        A = zoom extents
                        S = zoom selected
                        G = group
                        J = rotated rectangle
                        K = rectangle
                        L = line
                        Ö = Left Click Reverse Face Tool (scrtool.rb)
                          Jan - really? no space bar Select?
                          that's probably my favorite shortcut key to use 😄
                          not a keyboard shortcut but something else i have set up which is pretty sweet..
                          i have the thumb mouse button set to regular orbit and the middle mouse button set to option/orbit which disables the gravity weighted navigation (ctrl/orbit on windows?)
                            here's a new one i've been testing out and i really think it's going to stick.. try it out
                            (currently using N as that's become my test key for shortcuts but i'll think i'll assign it to an actual key shortly)
                            Window/Show Dialogs (which will toggle with Hide Dialogs)
                            reason.. i usually have the following windows stacked & collapsed on my screen and i open/close them as needed:
                            entity info -- soften/smooth -- scenes -- shadows -- styles
                            (and this will work with many of the other window dialogs as well)
                            with this shortcut, i now leave all of the dialogs expanded down the right side of my screen then toggle the windows on/off via the keyboard which is a lot better than opening/closing with the mouse.. further, this allows for a wider drawing window.
                            • Chris FullmerC Offline
                              I normally have that assigned to F-12. Its a good shortcut to keep around in my opinion.
                                Arx
                                Space - Select
                                Shift + Space - Move
                                Ctrl + Space - Rotate
                                Alt + Space - PushPull
                                ~ - Get Dimensions Plugin
                                Shift + ~ - Model Info
                                Alt + Z - Tape Mesure
                                Shift + Z - Rectangle Tool
                                H - Hide Rest of Model
                                That way the most frequently used tools are all under my left hand, so I don't even have to look at the keyboard to use them.
                                  DavidBoulder's image of his key assignments makes me think it would be nice to have a keyboard with the various tool icons instead of letters.
                                    If you have a few greens to spare...
                                    http://www.artlebedev.com/everything/optimus/
                                    http://img.artlebedev.com/everything/optimus/optimus_maximus_01w.jpg
                                    If you go to the Demo page you can see a layout for Photoshop.
                                    http://www.artlebedev.com/everything/optimus/demo/
                                      301 Moved Permanently
                                      (www.artlebedev.com)
                                      http://img.artlebedev.com/everything/optimus-tactus/optitact-color.jpg
                                      http://img.artlebedev.com/everything/optimus-tactus/optitact-side.jpg
                                      Apparently it will be cheaper than the Optimus because it doesn't have a screen per key.
                                        Though I'm not sure how nice it would be to use a keyboard without physical keys... maybe just a habit adjustment...?
                                          Cool! But $2400US. 😲
                                          That would be really neat in conjunction with that tablet I'm eying.
                                          I was thinking a bit lower tech. Like a keyboard with transparent key covers that could be removed and little icons printed on paper inserted.
                                          ThinkGeek shows it at $1600US but not available.
                                            That could be cool. I see your point but you could make it so frequently used keys are bigger or in easier to reach locations.
                                            Even the Aux which appears to be only a prototype would be good.
                                            • 2 / 3
