    Top 3 SU plugins
    80 Posts 40 Posters 23.0k Views 40 Watching
      I should have added Purge All.
      Like Jeff, I find both Curviloft and EEbyX useful. Sometimes I find one will do something the other won't.
      • jeff hammondJ Offline
        powerhouses aside, i use these daily (if it's a drawing day πŸ˜„)
        arc: center + 2pts. (didier)
        select curve (thomthom)
        selection toys (tt)
        exploded arc centerpoint (c.fullmer)
        work plane (tig)
        cline (jimF)
        fillet.rb (ohYeahCad)
        fredoscale (fredo)
        tangent tools (tig)
        skindigo (whaat)
        slice face horizontally (via 1001bit) (goh)
        3pt rectangle (google). Recently found it but something I've always wished for:)
        and it's great to have these when needed:
        perp. face tools (c.fullmer)
        vertex tools (tt)
        mirror (tig)
        SDS (whaat)
        profile builder (whaat)
        curve maker (drawMetal.com)
        shape bender (c.fullmer)
        selection memory (jimF)
        round corner (fredo)
        tools on surface (fredo)
        unfold (jimF)
        solid inspector (tt)
        1001bit's followme (goh)
        i have double+ that amount installed but these are the ones that have floated to the top as far as my technique is concerned.
        • EdsonE Offline
          Edson
          I forgot to mention good old add hidden layer, invaluable when you have many acenes already set up and decide to create a new layer.
          http://www.mahfuz.arq.br
            tfdesign
            My 3rd plugin may have to be Thom's UV Toolkit, which I'm still brewing the beer to give to Thom for!
            Let's face it (face those surfaces πŸ˜‰ ), They don't and won't look right without a tool like this πŸ˜„
            404 Not Found
            (forums.sketchucation.com)
            • Chris FullmerC Offline
              @dave r said:
              I end up using it once in awhile on models others send me but I have adopted a practice in which I never set any layer other than the default as active.
              Same here, but if you explode a group/component that was on a different layer, its entities will get moved onto the layer the group was on - thereby taking them off layer 0. So that has caused me some pain in the past.
                Chris, that's a good point and one I forgot about. I so rarely explode components (and don't use groups at all) in the first place and by the time I get to the stage in my modeling where I am making layers, the components are all pretty well fixed and I don't explode them at all, then. Interesting how a workflow can inadvertently bypass a behavior or is that a feature? πŸ˜„
                  tfdesign
                  πŸ˜† Ahh! Someone else who also feels my pain! πŸ˜†
                  So you are saying that this plug relieves that?
                    That plugin ensures that all edges and faces are located on Layer0
                    • TIGT Online
                      This http://forums.sketchucation.com/viewtopic.php?p=282640#p282640 puts exploded group's entities on the layers that they were on inside the group...
                      • jason_marantoJ Offline
                        jason_maranto
                        I had a hard time deciding but I set for myself the criteria of only selecting 3 free plugins that almost any user would benefit from having.
                        SketchyFFD: Massively useful and simple to free form distort geometry.
                        http://forums.sketchucation.com/viewtopic.php?f=323&t=25801&start=0
                        RoundCorner: Simple but powerful tool for rounding and beveling geometry.
                        http://forums.sketchucation.com/viewtopic.php?f=323&t=20485&hilit=Round+Corner
                        JointPushPull: Amazing upgrade to Sketchups native push/pull concept.
                        http://forums.sketchucation.com/viewtopic.php?f=323&t=6708
                        Best,
                        Jason.
                          Bertier
                          • Center of Gravity & it's repoter, thank you TIG
                          • Cutlist, thank you Steve
                          • Default Scene, thank you Pout
                          • EarthMoverE Offline
                            EarthMover
                            I have a lot of "favorite" plugins that do really cool stuff, but if there were a tracker on my PC that logged which plugins I used most often, it would probably be -
                            Selection Toys
                            Joint Push Pull
                            Edge Tools (Divide Face)
                            Although Purge All, Weld, Make Faces and Fredo Scale are probably also in the running for top 3 most used plugins in my arsenal.
                            Content Creator at Skapeup
                              mozzie
                              Put on Layer (most used)!
                              Points cloud v6 (relocatable origin version) - merci, Didier!
                              Curviloft (most extraordinary, and irreplaceable)
                              Also, Tools on surface, Pipe along Path, Weld, and Cleanup are wonderful.
                              • urgenU Offline
                                urgen
                                ....Unfortunately, the three major plug-in is not enough for me ... I often use in the same proportion in the 10-12 πŸ˜’
                                --pupil forever...------
                                • Bob JamesB Offline
                                  Bob James
                                  I've just downloaded "Default Layer Geometry": I really need that and it will undoubtedly become one of my frequently used plugins (I just must keep everything on layer 0 until everything is built!)
                                  I have many of the complex plugins that are indispensable when I need them (curviloft, vertex tools, Tools on Surface, Extrude Along....,etc.), but
                                  For every day general use:
                                  Nudge (Doesn't anyone use this: I'd be lost without it.)
                                  Options
                                  JSAlign
                                  Layer Tools and Layer Manager
                                  Edge Styles
                                  1001bit Tools
                                  And, somewhat less often, but still a lot:
                                  Round Corner
                                  Profile Builder
                                  BZ Toolbar
                                  Weld
                                  Extrude Lines
                                  Arc Centerpoint Finder
                                  Tube along path
                                  For final tuning:
                                  Repaint and Cleanup
                                  And, of course, when the model is ready:
                                  Thea Exporter
                                  • PixeroP Offline
                                    Pixero
                                    JSAlign
                                    Wow, I made it on the list. Thanks. πŸ˜„
                                      Prisoner
                                      For me it's
                                      • round corner (using it all the time)
                                      • Fredo Scale (dito)
                                      • 1001bit tools (they speed up so many things for me)
                                      Oh, and never go without Purge; couldn't survive without it, since I hate poly/texture size/whatever counting.
                                      A great UV toolset would instantly appear on my list... hint hint.
                                        tfdesign
                                        What is wrong with the UV toolset written by Thom? Could you not use those? πŸ˜„
                                          Bob James
                                          @pixero said:
                                          JSAlign
                                          Actually it's QJSAlign, but that's just to get the neat icons πŸ˜„
                                            Prisoner
                                            Right, I should give it a try again. Last time I used it it couldn't do what I needed (mapping imported 3ds files), have to give it another try. Thanks for reminding me.
                                            • 3 / 4
