    Top 3 SU plugins
    80 Posts 40 Posters 23.0k Views 40 Watching
    • arquitectomaracuchoA Offline
      arquitectomaracucho
      Curviloft 😍
      1001 bit Tools
      joint push pull
      tools on surface
      • EdsonE Offline
        Edson
        @chris fullmer said:
        @haynesc said:
        Default Layer Gemometry
        I totally agree on this one. It is invaluable to me. Move all geometry to layer 0 while keeping all groups, images, components on the layer they were on. Absolute must for clean modeling habits.
        I gather you mean to say "move all loose geometry, that is, not grouped or turned into a component".
        http://www.mahfuz.arq.br
          tfdesign
          Chris, why is that so important/ invaluable?
            Edson, the plugin Chris refers to does move all geometry whether it is loose or in a component/group to the Default layer as he wrote. It is very handy for cleaning up models. I end up using it once in awhile on models others send me but I have adopted a practice in which I never set any layer other than the default as active.
            • jeff hammondJ Offline
              BezierSpline
              Curviloft
              ExtrudeEdges Suite
              JPP
              (weld is a given. 100% should not be a ruby)
              (Curviloft and EEbyX might seem redundant but I use lathe a lot as well as extrude vector.. I still skin with it as well in certain instances. )
                I should have added Purge All.
                Like Jeff, I find both Curviloft and EEbyX useful. Sometimes I find one will do something the other won't.
                  powerhouses aside, i use these daily (if it's a drawing day πŸ˜„)
                  arc: center + 2pts. (didier)
                  select curve (thomthom)
                  selection toys (tt)
                  exploded arc centerpoint (c.fullmer)
                  work plane (tig)
                  cline (jimF)
                  fillet.rb (ohYeahCad)
                  fredoscale (fredo)
                  tangent tools (tig)
                  skindigo (whaat)
                  slice face horizontally (via 1001bit) (goh)
                  3pt rectangle (google). Recently found it but something I've always wished for:)
                  and it's great to have these when needed:
                  perp. face tools (c.fullmer)
                  vertex tools (tt)
                  mirror (tig)
                  SDS (whaat)
                  profile builder (whaat)
                  curve maker (drawMetal.com)
                  shape bender (c.fullmer)
                  selection memory (jimF)
                  round corner (fredo)
                  tools on surface (fredo)
                  unfold (jimF)
                  solid inspector (tt)
                  1001bit's followme (goh)
                  i have double+ that amount installed but these are the ones that have floated to the top as far as my technique is concerned.
                  • EdsonE Offline
                    Edson
                    I forgot to mention good old add hidden layer, invaluable when you have many acenes already set up and decide to create a new layer.
                      tfdesign
                      My 3rd plugin may have to be Thom's UV Toolkit, which I'm still brewing the beer to give to Thom for!
                      Let's face it (face those surfaces πŸ˜‰ ), They don't and won't look right without a tool like this πŸ˜„
                      404 Not Found
                      (forums.sketchucation.com)
                      • Chris FullmerC Offline
                        Same here, but if you explode a group/component that was on a different layer, its entities will get moved onto the layer the group was on - thereby taking them off layer 0. So that has caused me some pain in the past.
                          Chris, that's a good point and one I forgot about. I so rarely explode components (and don't use groups at all) in the first place and by the time I get to the stage in my modeling where I am making layers, the components are all pretty well fixed and I don't explode them at all, then. Interesting how a workflow can inadvertently bypass a behavior or is that a feature? πŸ˜„
                            tfdesign
                            πŸ˜† Ahh! Someone else who also feels my pain! πŸ˜†
                            So you are saying that this plug relieves that?
                              That plugin ensures that all edges and faces are located on Layer0
                              • TIGT Online
                                This http://forums.sketchucation.com/viewtopic.php?p=282640#p282640 puts exploded group's entities on the layers that they were on inside the group...
                                • jason_marantoJ Offline
                                  jason_maranto
                                  I had a hard time deciding but I set for myself the criteria of only selecting 3 free plugins that almost any user would benefit from having.
                                  SketchyFFD: Massively useful and simple to free form distort geometry.
                                  http://forums.sketchucation.com/viewtopic.php?f=323&t=25801&start=0
                                  RoundCorner: Simple but powerful tool for rounding and beveling geometry.
                                  http://forums.sketchucation.com/viewtopic.php?f=323&t=20485&hilit=Round+Corner
                                  JointPushPull: Amazing upgrade to Sketchups native push/pull concept.
                                  http://forums.sketchucation.com/viewtopic.php?f=323&t=6708
                                  Best,
                                  Jason.
                                    Bertier
                                    • Center of Gravity & it's repoter, thank you TIG
                                    • Cutlist, thank you Steve
                                    • Default Scene, thank you Pout
                                    • EarthMoverE Offline
                                      EarthMover
                                      I have a lot of "favorite" plugins that do really cool stuff, but if there were a tracker on my PC that logged which plugins I used most often, it would probably be -
                                      Selection Toys
                                      Joint Push Pull
                                      Edge Tools (Divide Face)
                                      Although Purge All, Weld, Make Faces and Fredo Scale are probably also in the running for top 3 most used plugins in my arsenal.
                                      Content Creator at Skapeup
                                        mozzie
                                        Put on Layer (most used)!
                                        Points cloud v6 (relocatable origin version) - merci, Didier!
                                        Curviloft (most extraordinary, and irreplaceable)
                                        Also, Tools on surface, Pipe along Path, Weld, and Cleanup are wonderful.
                                        • urgenU Offline
                                          urgen
                                          ....Unfortunately, the three major plug-in is not enough for me ... I often use in the same proportion in the 10-12 πŸ˜’
                                          --pupil forever...------
                                          • Bob JamesB Offline
                                            Bob James
                                            I've just downloaded "Default Layer Geometry": I really need that and it will undoubtedly become one of my frequently used plugins (I just must keep everything on layer 0 until everything is built!)
                                            I have many of the complex plugins that are indispensable when I need them (curviloft, vertex tools, Tools on Surface, Extrude Along....,etc.), but
                                            For every day general use:
                                            Nudge (Doesn't anyone use this: I'd be lost without it.)
                                            Options
                                            JSAlign
                                            Layer Tools and Layer Manager
                                            Edge Styles
                                            1001bit Tools
                                            And, somewhat less often, but still a lot:
                                            Round Corner
                                            Profile Builder
                                            BZ Toolbar
                                            Weld
                                            Extrude Lines
                                            Arc Centerpoint Finder
                                            Tube along path
                                            For final tuning:
                                            Repaint and Cleanup
                                            And, of course, when the model is ready:
                                            Thea Exporter
                                            • 3 / 4
