    Top 3 SU plugins
    80 Posts 40 Posters 24.3k Views 40 Watching
      That plugin ensures that all edges and faces are located on Layer0
        @chris fullmer said:
        @dave r said:
        I end up using it once in awhile on models others send me but I have adopted a practice in which I never set any layer other than the default as active.
        Same here, but if you explode a group/component that was on a different layer, its entities will get moved onto the layer the group was on - thereby taking them off layer 0. So that has caused me some pain in the past.
        This http://forums.sketchucation.com/viewtopic.php?p=282640#p282640 puts exploded group's entities on the layers that they were on inside the group...
        • jason_marantoJ
          jason_maranto
          I had a hard time deciding but I set for myself the criteria of only selecting 3 free plugins that almost any user would benefit from having.
          SketchyFFD: Massively useful and simple to free form distort geometry.
          http://forums.sketchucation.com/viewtopic.php?f=323&t=25801&start=0
          RoundCorner: Simple but powerful tool for rounding and beveling geometry.
          http://forums.sketchucation.com/viewtopic.php?f=323&t=20485&hilit=Round+Corner
          JointPushPull: Amazing upgrade to Sketchups native push/pull concept.
          http://forums.sketchucation.com/viewtopic.php?f=323&t=6708
          Best,
          Jason.
          • B
            Bertier
            • Center of Gravity & it's repoter, thank you TIG
            • Cutlist, thank you Steve
            • Default Scene, thank you Pout
            • EarthMoverE
              EarthMover
              I have a lot of "favorite" plugins that do really cool stuff, but if there were a tracker on my PC that logged which plugins I used most often, it would probably be -
              Selection Toys
              Joint Push Pull
              Edge Tools (Divide Face)
              Although Purge All, Weld, Make Faces and Fredo Scale are probably also in the running for top 3 most used plugins in my arsenal.
              Content Creator at Skapeup
                mozzie
                Put on Layer (most used)!
                Points cloud v6 (relocatable origin version) - merci, Didier!
                Curviloft (most extraordinary, and irreplaceable)
                Also, Tools on surface, Pipe along Path, Weld, and Cleanup are wonderful.
                • urgenU
                  urgen
                  ....Unfortunately, the three major plug-in is not enough for me ... I often use in the same proportion in the 10-12 πŸ˜’
                  --pupil forever...------
                  • Bob JamesB
                    Bob James
                    I've just downloaded "Default Layer Geometry": I really need that and it will undoubtedly become one of my frequently used plugins (I just must keep everything on layer 0 until everything is built!)
                    I have many of the complex plugins that are indispensable when I need them (curviloft, vertex tools, Tools on Surface, Extrude Along....,etc.), but
                    For every day general use:
                    Nudge (Doesn't anyone use this: I'd be lost without it.)
                    Options
                    JSAlign
                    Layer Tools and Layer Manager
                    Edge Styles
                    1001bit Tools
                    And, somewhat less often, but still a lot:
                    Round Corner
                    Profile Builder
                    BZ Toolbar
                    Weld
                    Extrude Lines
                    Arc Centerpoint Finder
                    Tube along path
                    For final tuning:
                    Repaint and Cleanup
                    And, of course, when the model is ready:
                    Thea Exporter
                    • PixeroP
                      Pixero
                      JSAlign
                      Wow, I made it on the list. Thanks. πŸ˜„
                      • P
                        Prisoner
                        For me it's
                        • round corner (using it all the time)
                        • Fredo Scale (dito)
                        • 1001bit tools (they speed up so many things for me)
                        Oh, and never go without Purge; couldn't survive without it, since I hate poly/texture size/whatever counting.
                        A great UV toolset would instantly appear on my list... hint hint.
                        • T
                          tfdesign
                          What is wrong with the UV toolset written by Thom? Could you not use those? πŸ˜„
                          • Bob JamesB
                            Bob James
                            @pixero said:
                            JSAlign
                            Actually it's QJSAlign, but that's just to get the neat icons πŸ˜„
                            • P
                              Prisoner
                              Right, I should give it a try again. Last time I used it it couldn't do what I needed (mapping imported 3ds files), have to give it another try. Thanks for reminding me.
                              • utilerU
                                utiler
                                Options
                                JSAlign
                                Edge Styles
                                1001bit Tools
                                Round Corner
                                Profile Builder
                                BZ Toolbar
                                Weld
                                Extrude Lines
                                Tube along path
                                For final tuning:
                                Repaint and Cleanup
                                Thea Exporter
                                Hey, that's a good top 3, Bob..... πŸ˜‰
                                Just Curious...
                                • Bob JamesB
                                  Bob James
                                  Oh, I thought it was the top three categories 😎
                                  Seriously, the top three depend heavily on what project I'm working on. But since you've busted me here are my
                                  top three non-project-dependent rubies:
                                  Nudge
                                  Options
                                  QJSAlign
                                    Nudge ?
                                    Nudge orbit by Tig ?
                                    • Bob JamesB
                                      Bob James
                                      Nudge by Todd Burch (it's on Smustard).
                                      It's $16.00, but worth every penny (It was $8.00 when I bought it back in 2006 😎). It's old, but, for me, very useful every day.
                                      I tried "moveit", but it only works on groups and components (at least when I tried it).
                                        Thx for the info πŸ˜„
                                        • jeff hammondJ
                                          and that differs 16 bucks worth from standard move ??
                                          i don't get it. πŸ˜• ❓
                                            Dragoonprogramming
                                            mine have to be:
                                            1Roof maker(roofs are a pain and this plugin makes it considerably easier)
                                            2Scf Power Toolbar
                                            3Curve tool
                                            "...And if he says that one more time i'll punch him right in the throat" - Armstrong and Getty
                                            My website http://dragoonprogramming.weebly.com/
                                            • 3 / 4
