    Tgi3D plugins -
    76 Posts 31 Posters 19.9k Views 31 Watching
    • jeff hammondJ
      @jason_maranto said:
      Griping about their pricing policy is pretty pointless.
      ha. ok.
      • KrisidiousK
        Krisidious
        how is it a free tool? there's a training version but does it allow you to save it? and use the model? I don't think it's pointless.... in fact I bet their reading it... and I also bet they had these same arguments.
        By: Kristoff Rand
        • jason_marantoJ
          jason_maranto
          Yes and yes... maybe you should use it before you comment.
          • KrisidiousK
            Krisidious
            I've tried... it doesn't work and I've had no response to my bug report.
            By: Kristoff Rand
            • KrisidiousK
              Krisidious
              it had a really kool installer though... found all my installations on all my drives and installed to each simultaneously. and if you look at their website these guys love to code... lots of nooks and crannies, very tight.
              By: Kristoff Rand
              • EarthMoverE
                EarthMover
                Not sure if this is the issue, but when you install the set of Free training tools, you will at first get a menu of grayed out icons. You have to click on the last one and enter your name to register the toolbar, then restart Sketchup. After that the tools work fine, although they are limited by the number of verticies they will process. For example the Upsample tool (right click menu) won't work on anything complicated, but will work only on small areas with only a few dozen verts. For me, the Select and Cross Section tools alone make the plugin worth checking out. I just wish they would allow you select loops as well as manipulate them. It seems if you can find loops to be manipulated, it would easy enough to also add a feature to select edge loops as well.
                Content Creator at Skapeup
                • KrisidiousK
                  Krisidious
                  I get an error when I open that says "No such file to load -- tgi3d/imain" the file is there.
                  there is an extension in the list and it is check marked... but there is no menu options or plugins in the list nor are there any toolbars.
                  By: Kristoff Rand
                  • charly2008C
                    charly2008
                    Hi Kristoff,
                    Do you have all the TGI-Folders and Files in your plugin folder? And did you activate the TGi3D toolbar?
                    Charly
                    • EarthMoverE
                      EarthMover
                      Installer is not working for SU 7. I installed on 7 & 8 and got the same error on 7, but not on 8. Probably a file mix up on their part.
                      • unclebimU
                        unclebim
                        @earthmover said:
                        Installer is broken for SU 7. I installed on 7 & 8 and got the same error on 7, but not on 8.
                        I got the same error on 8 but not on 7.
                        • KrisidiousK
                          Krisidious
                          Hi Kristoff,
                          Charly
                          yes I have all of that... and the imain.rbs is in the folder.
                          By: Kristoff Rand
                            It installed on my PC v7 and v8 with no issues?
                              d12dozr
                              I also have it installed in SU7 and SU8 (PC) with no problems.
                              http://goo.gl/f7ooYh
                              • KrisidiousK
                                Krisidious
                                are any of you using a external or extra harddrive for SU?
                                By: Kristoff Rand
                                  d12dozr
                                  Nope
                                    Me neither.
                                    • CadFatherC
                                      CadFather
                                      there is a plugin conflict somewhere - remove all and leave only tgi3d - that way it will work and you can try it
                                        JuanV.Soler
                                        Diego Rodriguez,
                                        it is so embarrassing to read you in this Plugin´s Creators forum...
                                        Edit : %(#000080)[Sorry Diego for my last words, I thought you were taking advantage.
                                        Lo siento. Salud]
                                        • sadyoS
                                          sadyo
                                          I have experienced exactly the same problem with you when trying to use "Tgi3D SU Amorph Training Edition v1.14"...
                                          I think they fixed that problem now, because they just released a new versions of Tgi3D SU plug-ins (v1.15).
                                          I already try that new version and error message "No such file to load -- tgi3d/imain" is Gone now...
                                          • KrisidiousK
                                            Krisidious
                                            thanks I'll try again...
                                            By: Kristoff Rand
                                            • 4 / 4
